读内部R/C时钟及ID号C语言参考程序
eefocus 2018-01-12
#include<reg51.h>
#include<intrins.h>
sfr IAP_CONTR = 0xC7;
sbit MCU_Start_LED = P1^7;
//unsigned char self_command_array[4] = {0x22,0x33,0x44,0x55};
#define Self_Define_ISP_Download_Command 0x22
#define RELOAD_COUNT 0xfb //18.432MHz,12T,SMOD=0,9600bps
void serial_port_initial();
void send_UART(unsigned char);
void UART_Interrupt_Receive(void);
void SOFt_reset_to_ISP_Monitor(void);
void delay(void);
void display_MCU_Start_Led(void);
void main(void)
unsigned char i = 0;
unsigned char j = 0;
unsigned char idata *idata_point;
serial_port_initial(); //串口初始化
// display_MCU_Start_Led(); //点亮发光二极管表示 单片机 开始工作
// send_UART(0x34); //串口发送数据表示 单片机 串口正常工作
// send_UART(0xa7); //串口发送数据表示 单片机 串口正常工作
idata_point = 0xF1;
for(j=0;j<15;j++)
i = *idata_point;
send_UART(i);
idata_point++;
while(1);
SCON = 0x50; //0101,0000 8位可变波特率,无奇偶校验位
TMOD = 0x21; //0011,0001 设置顶时器1为8位自动重装计数器
TH1 = RELOAD_COUNT; //设置定时器1自动重装数
TL1 = RELOAD_COUNT;
TR1 = 1; //开定时器1
ES = 1; //允许串口中断
EA = 1; //开总中断
void send_UART(unsigned char i)
ES = 0; //关串口中断
TI = 0; //清零串口发送完成中断请求标志
SBUF = i;
while(TI ==0); //等待发送完成
ES = 1; //允许串口中断
void UART_Interrupt_Receive(void) interrupt 4
unsigned char k = 0;
if(RI==1)
RI = 0;
k = SBUF;
if(k==Self_Define_ISP_Download_Command) //是自定义下载命令
delay(); //延时1秒就足够了
delay(); //延时1秒就足够了
soft_reset_to_ISP_Monitor(); //软复位到系统ISP监控区
send_UART(k);
else
TI = 0;
void soft_reset_to_ISP_Monitor(void)
IAP_CONTR = 0x60; //0110,0000 软复位到系统ISP监控区
void delay(void)
unsigned int j = 0;
unsigned int g = 0;
for(j=0;j<5;j++)
for(g=0;g<60000;g++)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
for(i=0;i<3;i++)
MCU_Start_Led = 0; //顶亮MCU开始工作指示灯
delay();
MCU_Start_Led = 1; //熄灭MCU开始工作指示灯
delay();
相关文章
