工业控制
简单伺服测试仪电路
2011-05-25
    简单伺服测试仪电路--Simple Servo Tester
click here to download schematic in pdf
This is a simple servo tester which will comprehensively test the capabilities of almost any modern servo. It has two pushbuttons, CENTRE and SWEEP and a potentiometer which works as follows:
- CENTRE Does exactly that, centers the servo, afterwards the potentiometer determines position.
- SWEEP Sweeps the servo back and forth at a rate determined by the potentiometer setting.
The PIC uses its internal timer to set up a constant frame duration of 20ms and the on/off ratio is set by the user.
Have Fun
ed
PCB board (download it below)
suggested panel decal
Parts List
R1 = 1K
R2 = 10K
R3 = 82R
R4 = 10K
R5 = 5K potentiometer
C1 = 27pF
C2 = 27pF
C3 = 100nF
D1 = 4,7V zener diode
Q1 = 10MHz crytal
IC1 = PIC12F675
进入工业控制查看更多内容>>
相关视频
  • 控制系统仿真与CAD
  • PLC功能指令应用详解
  • 非线性控制理论(浙大)
  • 对话ADI和世健 看工业市场发展的新机遇
  • 电力工程信号处理应用
  • 周公系列讲座——温度仪表
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 用数字电路CD4069制作的万能遥控轻触开关
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何构建一个触摸传感器电路
  • 基于ICL296的大电流开关稳压器电源电路
    相关电子头条文章
