电源管理
MAX860, MAX861 50mA、频率可选的开关电容电
2011-05-30
The MAX860/MAX861 charge-pump voltage converters invert input voltages ranging from +1.5V to +5.5V, or double input voltages ranging from +2.5V to +5.5V. Because of their high switching frequencies, these devices use only two small, low-cost capacitors. Their 50mA output makes switching regulators unnecessary, eliminating inductors and their associated cost, size, and EMI. Greater than 90% efficiency over most of the load-current range, combined with a typical operating current of only 200µA (MAX860), provides ideal performance for both battery-powered and board-level voltage-conversion applications.
A frequency-control (FC) pin provides three switching-frequencies to optimize capacitor size and quiescent current and to prevent interference with sensitive circuitry. Each device has a unique set of three available frequencies. A shutdown (active-low SHDN) pin reduces current consumption to less than 1µA. The MAX860/MAX861 are suitable for use in applications where the ICL7660 and MAX660's switching frequencies are too low. The MAX860/MAX861 are available in 8-pin µMax and SO packages.
MAX860, MAX861 关键特性
  • 8-Pin, 1.11mm High µMAX Package
  • Invert or Double the Input Supply Voltage
  • Three Selectable Switching Frequencies
  • High Frequency Reduces Capacitor Size
  • 87% Efficiency at 50mA
  • 200µA Quiescent Current (MAX860)
  • 1µA Shutdown Supply Current
  • 600mV Voltage Drop at 50mA Load
  • 12Ω Output Resistance
  • MAX860, MAX861 pdf datasheet
    MAX860, MAX861 应用/使用
    手持式仪表(PDA、掌上电脑)
  • 接口供电
  • 医疗仪器
  • 运算放大器电源
  • 便携式计算机
    MAX860, MAX861 应用电路
    MAX860,MAX861:典型工作电路
    典型工作电路
    进入电源管理查看更多内容>>
      热门新闻
    相关视频
    • 直播回放: Keysight 小探头,大学问,别让探头拖累你的测试结果!
    • 控制系统仿真与CAD
    • MIT 6.622 Power Electronics
    • 直播回放:基于英飞凌AIROC™ CYW20829低功耗蓝牙芯片的无线组网解决方案
    • 直播回放:ADI & WT·世健MCU痛点问题探索季:MCU应用难题全力击破!
    • Soc Design Lab - NYCU 2023
    精选电路图
    • 单稳态控制电路设计与分析
    • IGBT模块通过控制门极阻断过电流
    • 开关电源的基本组成及工作原理
    • 比较常见的功率整流器和滤波电路
    • 基于CA3193的热电偶放大器电路
    • 基于TDA1554的立体声放大器电路
      相关电子头条文章
