RT9711应用电路及参数资料
2011-04-07
Theis a low voltage, single N-MOSFET high-side power switch, optimized for self-powered and bus- powered Universal Serial Bus (USB) applications. The RT9711 equipped with a charge pump circuitry to drive the internal MOSFET switch; the switch's low RDS(ON), 80mW, meets USB voltage drop requirements; and a flag output is available to indicate fault conditions to the local USB controller.
Additional features include soft-start to limit inrush current during plug-in, thermal shutdown to prevent catastrophic switch failure from high-current loads, under-voltage lockout (UVLO) to ensure that the device remains off unless there is a valid input voltage present. The maximum current is limited to typically 2.5A in dual ports in accordance with the USB power requirements, lower quiescent current as 25uA making this device ideal for portable battery-operated equipment.
The RT9711 is available in SOT-23-5 and SOP-8 packages requiring minimum board space and smallest components.
• Compliant to USB Specifications
• Built-In N-MOSFET
► Typical RDS(ON) : 80mW (SOT-23-5), 90mW (SOP-8)
• Output Can Be Forced Higher Than Input (Off-State)
• Low Supply Current :
25uA Typical at Switch On State
1uA Typical at Switch Off State
• Guaranteed 1.5A Continuous Load Current
• Wide Input Voltage Ranges : 2.5V to 5.5V
• Open-Drain Fault Flag Output
• Hot Plug-In Application (Soft-Start)
• 1.7V Typical Under-Voltage Lockout (UVLO)
• Current Limiting Protection
• Thermal Shutdown Protection
• Reverse Current Flow Blocking (no body diode)
• UL Approved-E219878
• RoHS Compliant and 100% Lead (Pb)-Free
Application
• USB Bus/Self Powered Hubs
• USB Peripherals
• ACPI Power Distribution
• PC Card Hot Swap
• Notebook, Motherboard PCs
• Battery-Powered Equipment
• Hot-Plug Power Supplies
• Battery-Charger Circuits
Typical Applications Circuit
上一篇:高效率升压转换器应用技巧
下一篇:RT9173B应用电路及参数资料
- 国产高精度、高速率ADC芯片,正在崛起
- 贸泽开售用于快速开发精密数据采集系统的 Analog Devices ADAQ7767-1 μModule DAQ解决方案
- 采用电容型PGA,纳芯微推出高精密多通道24/16位Δ-Σ型ADC
- 安森美CEO亮相慕尼黑Electronica展,推出Treo平台
- ADALM2000实验:变压器
- 意法半导体推出灵活、节省空间的车载音频 D类放大器,新增针对汽车应用优化的诊断功能
- 高信噪比MEMS麦克风驱动人工智能交互
- 全差分放大器为精密数据采集信号链提供高压低噪声信号
- 安森美推出业界领先的模拟和混合信号平台
- 集Hi-Fi、智能和USB多通道等特征于一体的微控制器——迎接数字音频新时代
