模拟电子
RT9173B应用电路及参数资料
2011-04-07
The regulator is designed to convert voltage supplies ranging from 1.7V to 6V into a desired output voltage of which adjusted by two external voltage divider resistors. The regulator is capable of sourcing or sinking up to 2A of current while regulating an output voltage to within 40mV.
The RT9173B, used in conjunction with series termination resistors, provides an excellent voltage source for active termination schemes of high speed transmission lines as those seen in high speed memory buses and distributed backplane designs. The voltage output of the regulator can be used as a termination voltage for DDR SDRAM.
Current limits in both sourcing and sinking mode, plus on-chip thermal shutdown make the circuit tolerant of the output fault conditions.
The RT9173B are available in the popular 5-lead TO-252 and fused SOP-8 (the multiple VCNTL pins on the SOP-8 package are internally connected but lowest thermal resistance) surface mount packages.
• Support Both DDR I (1.25VTT) and DDR II (0.9VTT) Requirements
• SOP-8 and TO-252-5 Packages
• Capable of Sourcing and Sinking Current
• Current-limiting Protection
• Thermal Protection
• Integrated Power MOSFETs
• Generates Termination Voltages for SSTL-2
• High Accuracy Output Voltage at Full-Load
• Adjustable VOUT by External Resistors
• Minimum External Components
• Shutdown for Standby or Suspend Mode Operation with High-impedance Output
• RoHS Compliant and 100% Lead (Pb)-Free
Application
• DDR Memory Termination Supply
• Active Termination Buses
• Desktop PC/AGP Graphics
• Set Top Box/IPC
• Supply Splitter
Typical Applications Circuit
R1 = R2 = 100kW, RTT = 50W / 33W / 25W
COUT(MIN) = 10mF (Ceramic) + 1000mF under the worst case testing condition
RDUMMY = 1kW as for VOUT discharge when VIN is not present but VCNTL is present
CIN = 470mF (Low ESR), CCNTL = 47mF
进入模拟电子查看更多内容>>
相关视频
  • 嵌入式开发入门模电(模拟电路)基础
  • 世健KOL: A2B及音频处理系统解决方案介绍
  • 运算放大器视频教程
  • 功率半导体器件
  • 模拟电子电路
  • 德州仪器全系列直流降压产品详解
精选电路图
  • 永不缺相启动运行的电动机控制电路
  • MT3608构成3.7V转12V的升压电路图
  • 比较常见的功率整流器和滤波电路
  • 一个简单的红外耳机电路
  • 基于CA3193的热电偶放大器电路
  • 基于TDA1554的立体声放大器电路
    相关电子头条文章
