基于LTC2259-16的16位模-数转换方案
2011-02-21
Linear 公司的LTC2259-16是 16位模-数转换器,适用于对高频宽动态范围的信号进行数字化.它的SNR为73.1dB,SFDR为88dB,单电源1.8V工作,功率89mW,具有CMOS, DDR CMOS 或DDR LVDS输出,可选择的输入范围从1VP-P 到 2VP-P,主要用于通信,蜂窝基站,SDR,手提医疗图像设备,多路数据采集和非破坏性测试.本文介绍了LTCR2259-16主要特性, 功能方框图, 采用变压器模拟输入(5MHz-70MHz)电路图,以及70MHz到170MHz, 170MHz到270MHz, 大于270MHz和采用高速差分放大器的前端输入电路图, LTC2259-16典型应用电路图.
The LTCR2259-16 is a sampling 16-bit A/D converter designed for digitizing high frequency, wide dynamic range signals. It is perfect for demanding communications applications with AC performance that includes 73.1dB SNR and 88dB spurious free dynamic range (SFDR). Ultralow jitter of 0.17psRMS allows undersampling of IF frequencies with excellent noise performance. DC specs include ±4LSB INL (typical) and ±0.5LSB DNL (typical).
The digital outputs can be either full-rate CMOS, doubledata rate CMOS, or double-data rate LVDS. A separate output power supply allows the CMOS output swing to range from 1.2V to 1.8V.
The ENC+ and ENC– inputs may be driven differentially or single ended with a sine wave, PECL, LVDS, TTL or CMOS inputs. An optional clock duty cycle stabilizer allows high performance at full speed for a wide range of clock duty cycles.
LTCR2259-16主要特性:
73.1dB SNR
88dB SFDR
Low Power: 89mW
Single 1.8V Supply
CMOS, DDR CMOS or DDR LVDS Outputs
Selectable Input Ranges: 1VP-P to 2VP-P
800MHz Full-Power Bandwidth S/H
Optional Data Output Randomizer
Optional Clock Duty Cycle Stabilizer
Shutdown and Nap Modes
Serial SPI Port for Configuration
40-Pin (6mm x 6mm) QFN Package
LTCR2259-16应用:
Communications
Cellular Base Stations
Software Defi ned Radios
Portable Medical Imaging
Multi-Channel Data Acquisition
Nondestructive Testing
图1.LTCR2259-16功能方框图
图2.LTCR2259-16采用变压器模拟输入(5MHz-70MHz)电路图
图3.LTCR2259-16 70MHz到170MHz前端输入电路图
图3.LTCR2259-16 170MHz到270MHz前端输入电路图
图4.LTCR2259-16 大于270MHz前端输入电路图
图5.LTCR2259-16 采用高速差分放大器的前端输入电路图
图6.LTC2259-16 应用电路
- 国产高精度、高速率ADC芯片,正在崛起
- 贸泽开售用于快速开发精密数据采集系统的 Analog Devices ADAQ7767-1 μModule DAQ解决方案
- 采用电容型PGA,纳芯微推出高精密多通道24/16位Δ-Σ型ADC
- 安森美CEO亮相慕尼黑Electronica展,推出Treo平台
- ADALM2000实验:变压器
- 意法半导体推出灵活、节省空间的车载音频 D类放大器,新增针对汽车应用优化的诊断功能
- 高信噪比MEMS麦克风驱动人工智能交互
- 全差分放大器为精密数据采集信号链提供高压低噪声信号
- 安森美推出业界领先的模拟和混合信号平台
- 集Hi-Fi、智能和USB多通道等特征于一体的微控制器——迎接数字音频新时代
