1602LCD显示器的使用
2016-04-13 来源:eefocus
DB==P0
RD==P2.6
WR==P2.5
指令码:
清屏:
光标归位:
读状态输入:RS=L,RW=H,E=H 输出:DB0~DB7=状态字
写指令输入:RS=L,RW=L,E=下降沿脉冲,DB0~DB7=指令码输出:无
读数据输入:RS=H,RW=H,E=H 输出:DB0~DB7=数据
写数据输入:RS=H,RW=L,E=下降沿脉冲,DB0~DB7=数据输出:无
上次写的驱动:
#include
#include'LCD1602.h'
#include
#include
#include
#include
#include
sbit lcdrs =P3^0;//数据/命令选择端(H/L)
sbit lcdrw =P3^1;//读/写选择端(H/L)
sbit lcden =P3^2;//使能信号端
char
char
char LCDBuffer[16]={''};
char ctrlStr[7]={'.4f'};
void delayms(int xms)
int i, j;
for(i=xms;i>0;i--)
for(j=121;j>0;j--);
void write_com(char com)//写命令
lcdrs=0;
P0=com;
delayms(1);
lcden=1;
delayms(1);
lcden=0;
void write_data(char mydata)////写数据
lcdrs=1;
P0=mydata;
delayms(1);
lcden=1;
delayms(1);
lcden=0;
void initLCD()//初始化
//02,显示回车:1,数据指针清零。
void write_position(char position)//字符要显示在LCD哪个位置
lcdrs=0;
lcdrw=0;
lcden=0;
P0=position;
delayms(1);
lcden=1;
delayms(1);
lcden=0;
///功能函数部分
void displayOneCharacter(char mydata,char position)
write_position(position);
write_data(mydata);
void loadAndDisplay(bit judge)
if(judge==0)
displayOneCharacter(LCDBuffer[0],0x80);
displayOneCharacter(LCDBuffer[1],0x81);
displayOneCharacter(LCDBuffer[2],0x82);
displayOneCharacter(LCDBuffer[3],0x83);
displayOneCharacter(LCDBuffer[4],0x84);
displayOneCharacter(LCDBuffer[5],0x85);
displayOneCharacter(LCDBuffer[6],0x86);
displayOneCharacter(LCDBuffer[7],0x87);
displayOneCharacter(LCDBuffer[8],0x88);
displayOneCharacter(LCDBuffer[9],0x89);
displayOneCharacter(LCDBuffer[10],0x8A);
displayOneCharacter(LCDBuffer[11],0x8B);
displayOneCharacter(LCDBuffer[12],0x8C);
displayOneCharacter(LCDBuffer[13],0x8D);
displayOneCharacter(LCDBuffer[14],0x8E);
displayOneCharacter(LCDBuffer[15],0x8F);
if(judge==1)
displayOneCharacter(LCDBuffer[1],0xC1);
displayOneCharacter(LCDBuffer[2],0xC2);
displayOneCharacter(LCDBuffer[3],0xC3);
displayOneCharacter(LCDBuffer[4],0xC4);
displayOneCharacter(LCDBuffer[5],0xC5);
displayOneCharacter(LCDBuffer[6],0xC6);
displayOneCharacter(LCDBuffer[7],0xC7);
displayOneCharacter(LCDBuffer[8],0xC8);
displayOneCharacter(LCDBuffer[9],0xC9);
displayOneCharacter(LCDBuffer[10],0xCA);
displayOneCharacter(LCDBuffer[11],0xCB);
displayOneCharacter(LCDBuffer[12],0xCC);
displayOneCharacter(LCDBuffer[13],0xCD);
displayOneCharacter(LCDBuffer[14],0xCE);
displayOneCharacter(LCDBuffer[15],0xCF);
void setCursorPosition(char position) //移动光标位置
write_com(0x02);//光标归位
for(i=0;i write_com(0x14);//右移 } //下面的代码用于动态显示字符的,主要的东西在上面 void moveLeftOneStep(void)//左右移动 { if(cursorPosition==0)//表明要通过翻页左移 { if(startAddress!=0)//表明还可左移一次 剩下情况没法移动 { startAddress--;//确定显示的结束位置 if(expressLength-startAddress>=16)//表明显示满了 { endAddress=startAddress+15; return; } else//表明后面还有几个空要填满 { endAddress=expressLength-1; } } } else//表明无需翻页 { cursorPosition--; } } void moveRightOneStep(void) { if(startAddress+cursorPosition==endAddress+1) return; if(cursorPosition==15)//表明要考虑是否进行翻页 { if(startAddress+16 //表明 startAddress+15得到的是LCD最后一位对应express的地址 再加1表示长度 { startAddress++; endAddress=startAddress+15; displayExpress(); } else if(startAddress+16==expressLength)//表明当前已是最后一个字符 { startAddress++; endAddress=startAddress+14;//光标处应该是空 displayExpress(); } else//表明光标处并没有显示字符 { return; } } else//表明无需翻页 { if(cursorPosition==endAddress+1)//已到最后一个位置,光标不能再动了 { return; } cursorPosition++; endAddress=expressLength-1; setCursorPosition(cursorPosition); } } void moveLeft(void)//startAddress+cursorPosition是光标对应express中的地址 { if(startAddress+cursorPosition==0)//跳转到最后 { if(expressLength>15) { endAddress=expressLength-1; startAddress=endAddress-14; } cursorPosition=endAddress-startAddress+2; } if(startAddress+cursorPosition-1>=0&&express[startAddress+cursorPosition-1]=='n')//tan,sin,ln { if(startAddress+cursorPosition-6>=0&&express[startAddress+cursorPosition-6]=='a'&&express[startAddress+cursorPosition-6+1]=='r') //arctan,arcsin…… { moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); } else if(express[startAddress+cursorPosition-2]=='l')//表明为ln { moveLeftOneStep(); moveLeftOneStep(); } else //表明为sin或tan { moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); } } else if(startAddress+cursorPosition-1>=0&&startAddress+cursorPosition-1>=0&&express[startAddress+cursorPosition-1]=='g')//lg { moveLeftOneStep(); moveLeftOneStep(); } else if(startAddress+cursorPosition-1>=0&&express[startAddress+cursorPosition-1]=='s') { if(startAddress+cursorPosition-6>=0&&express[startAddress+cursorPosition-6]=='a'&&express[startAddress+cursorPosition-6+1]=='r') //arctan,arcsin…… { moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); } else { moveLeftOneStep(); moveLeftOneStep(); moveLeftOneStep(); } } else//表明为单个字符 { moveLeftOneStep(); } } void moveRight(void) { if(endAddress-startAddress+1==cursorPosition)//表明光标到了最后 { if(expressLength>15) { endAddress=15; startAddress=0; } cursorPosition=0; } else if(express[startAddress+cursorPosition]=='s'||express[startAddress+cursorPosition]=='t'||express[startAddress+cursorPosition]=='c')//sin,tan { moveRightOneStep(); moveRightOneStep(); moveRightOneStep(); } else if(express[startAddress+cursorPosition]=='a')//arctan,arcsin之类的 { moveRightOneStep(); moveRightOneStep(); moveRightOneStep(); moveRightOneStep(); moveRightOneStep(); moveRightOneStep(); } else if(express[startAddress+cursorPosition]=='l')//lg,ln { moveRightOneStep(); moveRightOneStep(); } else//表明为单字符 moveRightOneStep(); } void displayExpress(void)//从startAddress显示到endAddress { char i; write_position(0x80);//从这里开始显示 for(i=startAddress;i<=endAddress;i++) { write_data(express[i]); } for(i=endAddress+1;i<16+startAddress;i++)//后面的写空格 { write_data(' '); } } void insertOneAndDisplay(void) { expressLength++; if(cursorPosition>=0&&cursorPosition<15)//表明是在和前面当中插入的 { //查看当前显示状态 if(endAddress-startAddress==15)//表明当前已经满显了 { endAddress--; } else//表明未满显 { endAddress++; } cursorPosition++; } else if(cursorPosition==15)//表明光标在显示器第16个显示单元处 此时 startAddress得变 { if(endAddress-startAddress==15)//表明当前已经满显未满显的情况已在isModifyInput中处理 { startAddress++; endAddress++; } } } void deleteOneAndDisplay(void) { moveExpressForward(cursorPosition+startAddress,1); expressLength--; if(cursorPosition==0) { startAddress--; //确定endAddress的位置 if(expressLength-startAddress>=16)//表明显示满了 { endAddress=startAddress+15; } else//表明后面还有几个空要填满 { endAddress=expressLength-1; } } else { cursorPosition--;//光标位置要-- if(expressLength-startAddress>=16)//表明显示满了 { endAddress=startAddress+15; } else//表明后面还有几个空要填满 { endAddress=expressLength-1; } } } void deleteAndDisplay(void) { if(startAddress==0&&cursorPosition==0)//表明没法删除了 { return; } if(express[cursorPosition-1+startAddress]=='s')//表明为cos { if(cursorPosition-6+startAddress>=0&&express[cursorPosition-6+startAddress]=='a') { deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); } else { deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); } } else if(express[cursorPosition-1+startAddress]=='n')//表明为sin tan { if(express[cursorPosition-2+startAddress]=='l')//表明为ln { deleteOneAndDisplay(); deleteOneAndDisplay(); } { deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); } else//表明为sin、tan { deleteOneAndDisplay(); deleteOneAndDisplay(); deleteOneAndDisplay(); } } else if(express[cursorPosition-1+startAddress]=='g') { deleteOneAndDisplay(); deleteOneAndDisplay(); } else//表明删除一个 { deleteOneAndDisplay(); } } void displayInputExpress(void)//输入时调用的 { if(keyCode=='=') { return; } if(cursorPosition==15&&startAddress+1<=100) { startAddress++; endAddress=14+startAddress; return; } else //仅能提供第一次输入时的显示 { endAddress=expressLength-1; cursorPosition++; return; } warning('error 1'); } void displayModifyExpress(void) { if(keyCode=='=') { return; } if(keyCode==129||keyCode==130||keyCode==131)//表明为三个字符要输入 { insertOneAndDisplay(); insertOneAndDisplay(); insertOneAndDisplay(); } else if(keyCode==139||keyCode==140) { insertOneAndDisplay(); insertOneAndDisplay(); } else if(keyCode>=141&&keyCode<=142) { insertOneAndDisplay(); insertOneAndDisplay(); insertOneAndDisplay(); insertOneAndDisplay(); insertOneAndDisplay(); insertOneAndDisplay(); } else { insertOneAndDisplay(); } } void dispaly_dataA(void); void dispaly_dataA(void) { if(dataA>=pow(10,36)) { warning('Answer Over Flow!'); dataA=0; dispaly_dataA(); } else { sprintf(LCDBuffer,'g',dataA); loadAndDisplay(1); } } void warning(char *p) { sprintf(LCDBuffer,'s',p); loadAndDisplay(0); delayms(500); sprintf(LCDBuffer,'s',' ');//清屏 loadAndDisplay(0); displayExpress(); } void moveLogo(void)//把字符向前移动 { temp=LCDBuffer[0]; for(i=0;i<15;i++) { LCDBuffer[i]= LCDBuffer[i+1];//前移动 } LCDBuffer[15]=temp; } void showLogo(void) { for(i=0;i<19;i++) { loadAndDisplay(0); moveLogo(); delayms(100); } }
