单片机
8*8点阵流水显示程序与原理
2017-12-29 来源:eefocus
首先是让汉字能够静态显示,显示一段时间后(时间可能很短)把所显示的汉字编码移一位重新送出,比如要向左移动,原本显示在第一列的数据就丢弃了,把第二列的数据送到第一列上显示,依次移动显示一屏,显示一段时间再进行一次移动,人们看起来也就是移动的了。
这是程序:调试过的
硬件连接可以去这里:
#include
//sbit A=P2^0;
//sbit B=P2^1;
//sbit C=P2^2;
//sbit select=P2^3;
sbit clk=P3^0;        //595串行时钟端
sbit da=P3^1;         //595串行数据端
sbit enable=P3^2;
/************************************字库**********************************************/
unsigned char code stable[]={/*--  文字:  天  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
0x00,0x00,0x80,0x40,0x40,0x42,0x20,0x42,0x10,0x42,0x08,0x42,0x06,0x42,0x01,0xFE,
0x02,0x42,0x04,0x42,0x08,0x42,0x10,0x42,0x30,0x42,0x60,0x42,0x20,0x40,0x00,0x00,
/*--  文字:  天  --*/
/*--  文字:  快  --*/
0x00,0x70,0x00,0x00,0xFF,0xFF,0x00,0x08,0x80,0xB0,0x40,0x88,0x30,0x88,0x0E,0x88,
0x01,0xFF,0x06,0x88,0x08,0x88,0x30,0x88,0x60,0xF8,0xC0,0x80,0x40,0x80,0x00,0x00,
/*--  文字:  乐  --*/
0x00,0x00,0x20,0x00,0x18,0x40,0x0C,0xFC,0x07,0x44,0x12,0x44,0x20,0x44,0x40,0x46,
0x3F,0xFA,0x00,0x42,0x00,0x43,0x02,0x43,0x0C,0x42,0x38,0x40,0x10,0x00,0x00,0x00,
/*--  文字:  !  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xF8,0xDF,0xFC,
0xDF,0xFC,0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  欢  --*/
0x20,0x14,0x10,0x24,0x4C,0x44,0x43,0x84,0x43,0x64,0x2C,0x1C,0x20,0x20,0x10,0x18,
0x0C,0x0F,0x03,0xE8,0x06,0x08,0x18,0x08,0x30,0x28,0x60,0x18,0x20,0x08,0x00,0x00,
/*--  文字:  迎  --*/
0x40,0x40,0x20,0x41,0x1F,0xCE,0x20,0x04,0x40,0x00,0x47,0xFC,0x42,0x04,0x41,0x02,
0x40,0x02,0x5F,0xFC,0x40,0x04,0x42,0x04,0x44,0x04,0x43,0xFC,0x40,0x00,0x00,0x00,
/*--  文字:  来  --*/
0x20,0x00,0x20,0x80,0x10,0x84,0x10,0x84,0x08,0x94,0x04,0xA4,0x02,0xC4,0xFF,0xFF,
0x01,0x84,0x02,0xC4,0x04,0xB4,0x08,0x94,0x18,0x84,0x30,0x84,0x10,0x80,0x00,0x00,
/*--  文字:  我  --*/
0x04,0x20,0x04,0x20,0x42,0x22,0x82,0x22,0x7F,0xFE,0x01,0x21,0x01,0x21,0x10,0x20,
0x10,0x20,0x08,0xFF,0x07,0x20,0x1A,0x22,0x21,0xAC,0x40,0x20,0xF0,0x20,0x00,0x00,
/*--  文字:  的  --*/
0x00,0x00,0x7F,0xF8,0x10,0x8C,0x10,0x8B,0x10,0x88,0x3F,0xF8,0x00,0x40,0x00,0x30,
0x00,0x8F,0x03,0x08,0x26,0x08,0x40,0x08,0x20,0x08,0x1F,0xF8,0x00,0x00,0x00,0x00,
/*--  文字:  空  --*/
0x00,0x10,0x40,0x0C,0x40,0x84,0x41,0x44,0x41,0x24,0x41,0x14,0x41,0x05,0x7F,0x06,
0x41,0x04,0x41,0x14,0x41,0x24,0x41,0x44,0x40,0x84,0x40,0x14,0x00,0x0C,0x00,0x00,
/*--  文字:  间  --*/
0x00,0x00,0xFF,0xF8,0x00,0x01,0x00,0x06,0x00,0x00,0x07,0xF0,0x04,0x92,0x04,0x92,
0x04,0x92,0x04,0x92,0x07,0xF2,0x40,0x02,0x80,0x02,0x7F,0xFE,0x00,0x00,0x00,0x00,
/*--  文字:  天  --*/
                                 行显示子程序
                     实质是给当前行中的所有列传送两字节的数据
void hang_disp(unsigned char temp1,unsigned char temp2)
unsigned char i;
for(i=0;i<16;i++)
      if(i==8)temp2=temp1;          /***前8位即一字节传送完之后,传送该行的第二字节***/
      if(temp2&0x01)da=1;          /****数据从端口输出****/
      else          da=0;          /****生成一上升沿,595上升沿接受数据****/
      clk=0;clk=1;clk=0;
      temp2=temp2>>1;
  enable=0;enable=1;enable=0;      /****595并行输出使能****/
                             清行子程序
   如果没有清行程序,该行显示完转到下一行时595的输出还没有变,还是上一行的数据 ,因为程序中是先选定行,
再向595传数据的,所以下一行开始时有一段时间是显示合一行的内容的,这段时间就是向595传两个字节数据的时间。
void hang_clear()
unsigned char i;
for(i=0;i<16;i++)
      da=0;     /***595的输出连接的是点阵的阴极,所以让595输出高电平,可以使得该行的LED熄灭****/
      clk=0;clk=1;clk=0;
unsigned int count=0;
unsigned char move=0;
void disp()
unsigned char i;
unsigned int j;
count++;
for(i=0;i<16;i++)
   P2=i;                                           /*****选定行*****/
   //hang_disp(stable[2*(i+move)],stable[2*(i+move)+1]);          /***从字库中取数据****/
  hang_disp(~stable[2*(i+move)],~stable[2*(i+move)+1]);   /***从字库中取数据再取反,能实现反显****/
   for(j=0;j<10;j++);   /***显示和清零间加以延时,以便显示明显,可以自行调节,也可以去掉***/
   hang_clear();
if(count==10)     /***调节移动的速度***/
    count=0;
    move++;
    if(move==192)    /***调节移动的字数***n=move/16***/
         move=0;
main()
while(1)
     disp();
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • PIC单片机控制的遥控防盗报警器电路
  • 短波AM发射器电路设计图
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 如何构建一个触摸传感器电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
