单片机
24c02开机计数器程序
2018-01-11 来源:eefocus
LED1    EQU    08H
LED2    EQU    09H
LED3    EQU    0AH
LED4    EQU    0BH
LedT0    EQU    0CH    ;0-3 轮流点亮4个数据管
SDA    EQU    P2.0
SCL    EQU    P2.1
Address    EQU    0EH
I2CData    EQU    0FH
    ORG 0000H
    LJMP START;转入主程序
    ORG    000BH
;定时器0中断入口
INT_TO:
    PUSH    ACC
    PUSH    PSW
    CLR    TF0        ;清定时0中断标志
     MOV     TH0,#0F6H    ;2.5MS
     MOV     TL0,#03DH    ;
     MOV     A,#11110000B    ;关数码管
    ORL    P2,A
     MOV     A,LedT0
    CJNE    A,#0,INT_T0_1
     MOV     A,LED1
     MOV C    A,@A+DPTR
     MOV     P0,A
    CLR    P2.7
     MOV     LedT0,#1
    LJMP    INT_T0_END
 INT_T0_1:
     MOV     A,LedT0
    CJNE    A,#1,INT_T0_2
     MOV     A,LED2
     MOV C    A,@A+DPTR
     MOV     P0,A
    CLR    P2.6
     MOV     LedT0,#2
    LJMP    INT_T0_END
 INT_T0_2:
      MOV     A,LedT0
    CJNE    A,#2,INT_T0_3
     MOV     A,LED3
     MOV C    A,@A+DPTR
     MOV     P0,A
    CLR    P2.5
     MOV     LedT0,#3
    LJMP    INT_T0_END
 INT_T0_3:
     MOV     A,LED4
     MOV C    A,@A+DPTR
     MOV     P0,A
    CLR    P2.4
     MOV     LedT0,#0
    LJMP    INT_T0_END
 INT_T0_END:
    POP    PSW
    POP    ACC
RETI
START:
     MOV     SP,#60H
    CALL    DELAY10MS
    CALL    DELAY10MS
    CALL    DELAY10MS
    CALL    AT24C01_READ_ALL
     MOV     A,LED1
    CJNE    A,#10,$+3    ;A<10 ,C=1
    JNC    START_RESET_24C01
     MOV     A,LED2
     MOV     A,LED3
     MOV     A,LED4
    JMP    START_INC
;第一次使用复位内部数值
START_RESET_24C01:
     MOV     LED1,#0
     MOV     LED2,#0
     MOV     LED3,#0
     MOV     LED4,#0
    JMP    START_INC_END
;加1
START_INC:
    INC    LED4
     MOV     A,LED4
    CJNE    A,#10,START_INC_END    ;等于10,进位
     MOV     LED4,#00
    INC    LED3
     MOV     A,LED3
     MOV     LED3,#00
    INC    LED2
     MOV     A,LED2
     MOV     LED2,#00
    INC    LED1
     MOV     A,LED1
     MOV     LED1,#00
     MOV     LED2,#00
     MOV     LED3,#00
     MOV     LED4,#00
START_INC_END:
    ;储存
    CALL    AT24C01_WRITE_ALL
     MOV     TMOD,#01H    ;设定T0为十六位定时模式。
     MOV     TH0,#0F6H    ;2MS
     MOV     TL0,#03DH    ;
    SETB    TR0        ;开定时器0
    SETB    ET0        ;致能定时0中断
    CLR    TF0        ;清定时0中断标志
    SETB    EA        ;开总中断
     MOV     LedT0,#00H
     MOV     DPTR,#TABLE
SCAN:
    ;按键扫描
    JB    P3.2,$
    LCALL    DELAY10MS    ;去抖动
    JNB    P3.2,KEY_RESET
    LJMP    SCAN
KEY_RESET:
     MOV     LED1,#00
     MOV     LED2,#00
     MOV     LED3,#00
     MOV     LED4,#00
    ;储存
    ;检测按键是否放开
    JNB    P3.2,$
    JMP    SCAN
DELAY10MS:
     MOV  R4,#20
DELAY10MSA:
     MOV  R5,#247
    DJNZ R5,$
    DJNZ R4,DELAY10MSA
RET
TABLE:
    DB    00101000B    ;0
    DB    11101011B    ;1
    DB    00110010B    ;2
    DB    10100010B    ;3
    DB    11100001B    ;4
    DB    10100100B    ;5
    DB    00100100B    ;6
    DB    11101010B    ;7
    DB    00100000B    ;8
    DB    10100000B    ;9
    DB    01100000B    ;A
    DB    00100101B    ;b
    DB    00111100B    ;C
    DB    00100011B    ;d
    DB    00110100B    ;E
    DB    01110100B    ;F
    DB    11110111B    ;-
    DB    11111111B    ;
;读出全部数据
AT24C01_READ_ALL:
     MOV     Address,#00H
    CALL    I2C_READ
     MOV     LED1,A        ;读出数据
     MOV     Address,#01H
    CALL    I2C_READ
     MOV     LED2,A        ;读出数据
     MOV     Address,#02H
    CALL    I2C_READ
     MOV     LED3,A        ;读出数据
     MOV     Address,#03H
    CALL    I2C_READ
     MOV     LED4,A        ;读出数据
RET
;写入全部数据
AT24C01_WRITE_ALL:
     MOV     Address,#00H
     MOV     A,LED1
     MOV     I2CData,A
    CALL    I2C_WRITE    ;写入数据
     MOV     Address,#01H
     MOV     A,LED2
     MOV     I2CData,A
     MOV     Address,#02H
     MOV     A,LED3
     MOV     I2CData,A
     MOV     Address,#03H
     MOV     A,LED4
     MOV     I2CData,A
RET
;写一个字节    Address地址    I2CDatata写入的数据
I2C_WRITE:
    I2C_WRITE_A:
    LCALL    I2C_START
     MOV     A,#10100000B
    LCALL    I2C_SEND8BIT
    LCALL    I2C_ACK
    JC    I2C_WRITE_A    ;=1,表示无确认,再次发送
     MOV     A,Address
    LCALL    I2C_SEND8BIT
    LCALL    I2C_ACK
     MOV     A,I2CData
    LCALL    I2C_SEND8BIT
    LCALL    I2C_ACK
    LCALL    I2C_STOP
RET
;读一个字节    Address地址    Data读出的数据
I2C_READ:
    I2C_READ_A:
    LCALL    I2C_START
     MOV     A,#10100000B
    LCALL    I2C_SEND8BIT
    LCALL    I2C_ACK
    JC    I2C_READ_A    ;=1,表示无确认,再次发送
     MOV     A,Address
    LCALL    I2C_SEND8BIT
    LCALL    I2C_ACK
    I2C_READ_B:
    LCALL    I2C_START
     MOV     A,#10100001B
    LCALL    I2C_SEND8BIT
    LCALL    I2C_ACK
    JC    I2C_READ_B
    LCALL    I2C_RECEIVE8BIT
     MOV     I2CData,A
    LCALL    I2C_ACK
    LCALL    I2C_STOP
RET
;发送开始信号
I2C_START:
    SETB    SCL
    SETB    SDA
    NOP
    NOP
    CLR    SDA
    NOP
    NOP
    CLR    SCL
RET
;发送结束信号
I2C_STOP:
    CLR    SDA
    NOP
    NOP
    SETB    SCL
    NOP
    NOP
    SETB    SDA
RET
;发送接收确认信号
I2C_ACk:
    SETB    SDA
    SETB    SCL
    NOP
    NOP
    JB    SDA,I2C_ACK0
    CLR    C
    SJMP    I2C_ACK_END
    I2C_ACK0:
    SETB    C
    I2C_ACK_END:
    CLR    SCL
RET
;送八位数据
I2C_SEND8BIT:
     MOV     B,#08H
I2C_SEND8BIT_A:
    RLC    A
     MOV     SDA,C
    SETB    SCL
    NOP
    NOP
    CLR    SCL
    DJNZ    B,I2C_SEND8BIT_A
RET
;接收八位数据
I2C_RECEIVE8BIT:
     MOV     B,#08H
    CLR    A
    SETB    SDA
I2C_RECEIVE8IT_A:
    SETB    SCL
    NOP
    NOP
     MOV     C,SDA
    RLC    A
    CLR    SCL
    DJNZ    B,I2C_RECEIVE8IT_A
RET
END
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 红外线探测报警器
  • 短波AM发射器电路设计图
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
