基于单片机的温湿度监测系统设计(程序)
2022-04-01 来源:eefocus
#include #include '1602.h' #include 'dht.h' #include '2402.h' //定义三个LED灯 sbit Led_qushi=P1^6; //去湿灯 sbit Led_jiangwen=P1^5; //降温灯 sbit Led_shengwen=P1^4; //升温灯 sbit Key_TH1 = P3^2; sbit Key_TH2 = P3^3; sbit Key_HH1 = P3^4; sbit Key_HH2 = P3^5; //定义标识 volatile bit FlagStartRH = 0; //开始温湿度转换标志 volatile bit FlagKeyPress = 0; //有键按下 //定义温湿度传感器用外部变量 extern U8 U8FLAG,k; extern U8 U8count,U8temp; extern U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata; extern U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp; extern U8 U8comdata; extern U8 count, count_r; U16 temp; S16 temperature, humidity; S16 idata TH, HH; //温度上限和湿度上限 char * pSave; U8 keyvalue, keyTH1, keyTH2, keyHH1, keyHH2; //定义变量 U16 RHCounter; //数据初始化 void Data_Init() { RHCounter = 0; Led_qushi = 1; Led_jiangwen = 1; Led_shengwen = 1; TH = 40; HH = 85; keyvalue = 0; keyTH1 = 1; keyTH2 = 1; keyHH1 = 1; keyHH2 = 1; } //定时器0初始化 void Timer0_Init() { ET0 = 1; //允许定时器0中断 TMOD = 1; //定时器工作方式选择 TL0 = 0x06; TH0 = 0xf8; //定时器赋予初值 TR0 = 1; //启动定时器 } //定时器0中断 void Timer0_ISR (void) interrupt 1 using 0 { TL0 = 0x06; TH0 = 0xf8; //定时器赋予初值 //每2秒钟启动一次温湿度转换 RHCounter ++; if (RHCounter >= 1000) { FlagStartRH = 1; RHCounter = 0; } } //存入设定值、 void Save_Setting() { pSave = (char *)&TH; //地址低位对应低8位,高位对应高8位 wrteeprom(0, *pSave); //存温度上限值TH低8位 DELAY(500); pSave ++; wrteeprom(1, *pSave); //存温度上限值TH高8位 DELAY(500); pSave = (char *)&HH; wrteeprom(2, *pSave); //存湿度上限值RH低8位 DELAY(500); pSave ++; wrteeprom(3, *pSave); //存湿度上限值RH高8位 DELAY(500); } //载入设定值、 void Load_Setting() { pSave = (char *)&TH; *pSave++ = rdeeprom(0); *pSave = rdeeprom(1); pSave = (char *)&HH; *pSave++ = rdeeprom(2); *pSave = rdeeprom(3); if ((TH>99)||(TH<0)) TH = 40; if ((HH>99)||(HH<0)) HH = 85; } void KeyProcess(uint num) { switch (num) { case 1: if (TH<99) TH++; L1602_char(1, 15, TH/10+48); L1602_char(1, 16, TH%10+48); break; case 2: if (TH>1) TH--; L1602_char(1, 15, TH/10+48); L1602_char(1, 16, TH%10+48); break; case 3: if (HH<99) HH++; L1602_char(2, 15, HH/10+48); L1602_char(2, 16, HH%10+48); break; case 4: if (HH>1) HH--; L1602_char(2, 15, HH/10+48); L1602_char(2, 16, HH%10+48); break; default: break; } Save_Setting(); } /******************************************************************** * 名称 : Main() * 功能 : 主函数 ***********************************************************************/ void main() { U16 i, j, testnum; EA = 0; Timer0_Init(); //定时器0初始化 Data_Init(); EA = 1; L1602_init(); L1602_string(1,1,' Welcome to T&H '); L1602_string(2,1,' Control System! '); //延时 for (i=0;i<500;i++) for (j=0;j<1000;j++) {;} //清屏 L1602_string(1,1,' '); L1602_string(2,1,' '); L1602_string(1,1,'Tem: C TH:'); L1602_string(2,1,'Hum: % HH:'); //载入温度上限和湿度上限设定值 Load_Setting(); L1602_char(1, 15, TH/10+48); L1602_char(1, 16, TH%10+48); L1602_char(2, 15, HH/10+48); L1602_char(2, 16, HH%10+48); while(1) { //温湿度转换标志检查 if (FlagStartRH == 1) { TR0 = 0; testnum = RH(); FlagStartRH = 0; TR0 = 1; //读出温湿度,只取整数部分 humidity = U8RH_data_H; temperature = U8T_data_H; //显示温湿度 L1602_int(1,5,temperature); L1602_int(2,5,humidity); } //温湿度控制 if (temperature > TH) Led_jiangwen = 0; else Led_jiangwen = 1; //降温 if (humidity > HH) Led_qushi = 0; else Led_qushi = 1; //去湿 //键盘查询,在弹起时响应 if ((Key_TH1)&&(keyTH1==0)) {FlagKeyPress = 1; keyvalue = 1;} else if ((Key_TH2)&&(keyTH2==0)) {FlagKeyPress = 1; keyvalue = 2;} else if ((Key_HH1)&&(keyHH1==0)) {FlagKeyPress = 1; keyvalue = 3;} else if ((Key_HH2)&&(keyHH2==0)) {FlagKeyPress = 1; keyvalue = 4;} if (FlagKeyPress == 1) { KeyProcess(keyvalue); FlagKeyPress = 0; } if (!Key_TH1) keyTH1 = 0; else keyTH1 = 1; if (!Key_TH2) keyTH2 = 0; else keyTH2 = 1; if (!Key_HH1) keyHH1 = 0; else keyHH1 = 1; if (!Key_HH2) keyHH2 = 0; else keyHH2 = 1; } }
