C51单片机数字时钟系统原理解析
2023-09-04 来源:elecfans
有关的硬件原理图:
c程序:
//温馨提示:
/*程序还没有调试完成,实际电路板调节时间时时-分-秒都会有闪烁现象,其实我是不知道的,why,也求解释
#include //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义
#include //与_nop_有关
sbit duan=P2^2; //定义锁存使能端口 段锁存
sbit wei=P2^3; // 位锁存
sbit key1 = P1^1;
sbit key2 = P1^2;
sbit key3 = P1^3;
sbit key4 = P1^4;
unsigned char code duanma[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; // 显示段码值0~9
unsigned char code weima[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; //分别对应相应的数码管点亮,即位码
unsigned char temp[8]; //存储显示值的全局变量
char hour; minute; second, num, t, i;
//函数声明
void delay(unsigned int t);
void initial();
void delay20ms();
void keyscan();
void caifen();
void display();
主函数
void main()
initial(); //调用初始化程序
while(1)
keyscan(); //调用键盘扫描
caifen(); //调用拆分以时-分-秒的形式
display(); //调用时间的显示程序
//初始化程序
void initial()
TMOD = 0x01; //设置T1工作于定时方式1(有16位计数)
TH0 = (65536 - 2000)/256; //定时器1赋初值,是TH1而不是TH0噢(若要设置是定时器0的话,把1改为0,下同);计数了2000次,即为2ms
TL0 = (65536 - 2000)%256;
EA = 1; //开中断
TR0 = 1; //开定时器0
ET0 = 1; //开启定时器中断0
hour = 23; //赋初值
minute = 59; //赋初值
second = 57; //赋初值
//中断服务程序
void time0(void) interrupt 1
TH0 = (65536 - 2000)/256; //重新赋值
num ++; //中断500次后 即2ms X 500 = 1000MS = 1S,(一般可计数久点如50000ms,中断20次,这样误差就不会太大)
if (num == 500)
num = 0;
second ++;
if (second == 60) //秒为60则miao置0,minute加一
second = 0;
minute ++;
if (minute == 60) //分为60则minute置0,hour加一
minute = 0;
hour ++;
if (hour == 24) //小时为24则hour置0
hour = 0;
//键盘扫描程序,可执行时分的加减
void keyscan()
if(key1 == 0)
delay20ms(); //延时20ms,去抖动
while(key1 == 0); //等待(上升沿则执行下一行,TRO = 0)
TR0 = 0; //关定时器0
t ++; //t++与调节时分秒有关
switch(t) //选择调节时分秒有关,与上面的t相关联
case 1:
if(key2 == 0)
delay20ms();
if(key2 == 0)
while(key2 == 0);
hour ++;
if(hour == 24)
hour = 0;
if(key3 == 0)
delay20ms();
if(key3 == 0)
while(key3 == 0);
hour --;
if(hour == -1) //因为hour是char型,所以可以有负数,若是unsigned char则不允许,下面的minute同理
hour =23;
break;
case 2:
if(key2 == 0)
delay20ms();
if(key2 == 0)
while(key2 == 0);
minute ++;
if(minute == 60)
minute = 0;
if(key3 == 0)
delay20ms();
