PIC单片机滚动码解码C程序
2016-11-16 来源:eefocus
// Interrupt based receive routine
// Compiled using HiTech PIC C compiler v.7.93
#define CLOCK 4 // MHz
#define TE 400 // us
#define OVERSAMPLING 3
#define PERIOD TE/OVERSAMPLING*4/CLOCK
#define NBIT 65 // number of bit to receive -1(HCS300 66-1=65)
unsigned char B[9]; // receive buffer
static byte RFstate; // receiver state
static sbyte RFcount; // timer counter
static byte Bptr; // receive buffer pointer
static byte BitCount; // received bits counter
word XTMR; // 16 bit extended timer
volatile bit RFFull; // buffer full
volatile bit RFBit; // sampled RF signal
#define TRFreset 0
#define TRFSYNC 1
#define TRFUNO 2
#define TRFZERO 3
#define HIGH_TO -10 // longest high Te
#define LOW_TO 10 // longest low Te
#define SHORT_HEAD 20 // shortest Thead accepted 2,7ms
#define LONG_HEAD 45 // longest Thead accepted 6,2ms
#pragma int_rtcc // install as interrupt handler (comment for HiTech!)
void interrupt rxi(void) //this routine gets called every time TMR0 overflows
RFBit = RFIn; // sampling RF pin verify!!!
TMR0 -= PERIOD; // reload
T0IF = 0;
XTMR++; // extended 16 long timer update
if (RFFull) // avoid overrun
{ return;}
switch( RFstate) // state machine main switch
case TRFUNO:
if ( RFBit)
{ // while high
RFcount--;
if ( RFcount < HIGH_TO)
RFstate = TRFreset; // reset if too long
else
{ // falling edge detected ----+
RFstate= TRFZERO;
break;
case TRFZERO:
if ( RFBit)
{ // rising edge detected +----
RFstate= TRFUNO;
B[Bptr] >>= 1; // rotate
if ( RFcount >= 0)
{ B[Bptr]+=0x80; } // shift in bit
RFcount = 0; // reset length counter
if ( ( ++BitCount & 7) == 0)
{ Bptr++; } // advance one byte
if (BitCount == NBIT)
RFstate = TRFreset; // finished receiving
RFFull = TRUE;
else
{ // still low
RFcount++;
if ( RFcount >= LOW_TO) // too long low
RFstate = TRFSYNC; // fall back into RFSYNC state
Bptr = 0; // reset pointers, while keep counting on
BitCount = 0;
break;
case TRFSYNC:
if ( RFBit)
{ // rising edge detected +---+ +---..
// | | <-Theader-> |
if ( ( RFcount < SHORT_HEAD) || ( RFcount >= LONG_HEAD))
RFstate = TRFreset;
break; // too short/long, no header
else
RFcount =0; // restart counter
RFstate= TRFUNO; //合适的长低电平信号出现
else
{ // still low
RFcount++;
break;
case TRFreset: //初始状态
default:
RFstate = TRFSYNC; // reset state machine in all other cases
RFcount = 0;
Bptr = 0;
BitCount = 0;
break;
} // switch
} // rxi
void InitReceiver()
T0IF = 0;
T0IE = 1; // TMR0 overflow interrupt
GIE = 1; // enable interrupts
RFstate = TRFreset; // reset state machine in all other cases
RFFull = 0; // start with buffer empty
XTMR = 0; // start extende
- 贸泽开售Microchip Technology PIC32CZ CA MCU 保护工业和汽车应用安全
- Microchip推出搭载硬件安全模块的PIC32CK 32位单片机, 轻松实现嵌入式安全功能
- Microchip推出集成微型FPGA的PIC16 微控制器,售价不到 50 美分
- Microchip 发布PIC16F13145系列MCU,促进可定制逻辑的新发展
- Microchip推出PIC18-Q24 系列单片机 为增强代码安全性设置新标准
- 基于AT45DB161B存储器和PIC16LC73B单片机实现微型压力测量装置设计
- 贸泽备货Microchip PIC32CM Lx MCU 同时支持安全子系统和Arm TrustZone技术
- Microchip推出32位单片机PIC32CXMT系列产品
- Microchip推出基于Arm®的新型PIC®单片机系列产品
- Microchip推出PIC32CM JH微控制器 基于Arm® Cortex®-M0+架构打造
