单片机
MEGA16读AD7705程序
2016-10-28 来源:eefocus
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define Add_key  PINC
#define CS_1        (PORTB|= (1<<4 ))
#define CS_0        (PORTB&= ~(1<<4 ))
#define LED_1       (PORTB|= (1<<0 ))
#define LED_0       (PORTB&= ~(1<<0 ))
#define LED1_1       (PORTB|= (1<<1 ))
#define LED1_0       (PORTB&= ~(1<<1 ))
#define DRDY        (PINB& 0x08)
#define ADDR        (PINC& 0x01)
#define SPE_1       (SPCR|= (1<<6 ))
uint value,value1,value2;
//**********************短延时程序50us**************************//
void delay50us(uint t)
    uint j;
    for(;t>0;t--)
        for(j=0;j<70;j++)
//**********************短延时程序5us**************************//
void delay5us(uint t)
    uint j;
    for(;t>0;t--)
        for(j=0;j<7;j++)
//**********************长延时程序50ms**************************//
void delay50ms(uint t)
        uint i;
        for(;t>0;t--)
                for(i=0;i<52642;i++)
//**************************端口初始化*************************//
void IO_Init(void)
 DDRC=0x00;
 PORTC=0x00;
  DDRB=0b10110111;   //PB3\PB6输入
 PORTB=0b11110111; //MISO输入加上拉电阻
void spi_init(void)
 SPCR = 0b01011111; //使能SPI,MSB先发送,主机,SCK空闲高,模式三,128分频
 SPSR = 0x00; //setup SPI,主机倍频
 //CS_0;    //使能SPI器件
//******************SPI写寄存器函数*******************************//
void WriteToReg_ADC(uint byteword)
   CS_0;    //使能SPI器件
  //SPE_1;
  SPDR=byteword;       //发送数据
  while(!(SPSR & (1<    CS_1;    //禁止SPI器件
//  delay5us(10);
//******************SPI读函数*******************************//
unsigned char Read_Byte_SPI(void)
    SPDR = 0xff;  //发送数据,给AD7705提供脉冲
    while (!(SPSR &(1<     return SPDR;
//******************SPI读数据寄存器函数*******************************//
uint Read_ADC16BitValue(void)
    uchar temp1=0;
    uint temp=0;
         CS_0;    //使能SPI器件
        temp=Read_Byte_SPI();
        temp=temp<<8;
        temp1=Read_Byte_SPI();
        temp=temp|temp1;
         CS_1;    //禁止SPI器件
        return temp;
//******************绿灯闪烁******************************//
void greenled(void)
           LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
          LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
void yellowled(void)
           LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
          LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
//**************************AD初始化*************************//
void ADC_Init(void)
  uchar i;
   for(i=10;i>0;i--)
    {WriteToReg_ADC(0xff);}  //持续DIN高电平写操作,恢复AD7705接口
 WriteToReg_ADC(0x20);       //通道1,下一个写时钟寄存器
 WriteToReg_ADC(0x0c);       //写时钟寄存器设置更新速率为200hz
 WriteToReg_ADC(0x10);       //通道1,下一个写设置寄存器
 WriteToReg_ADC(0x44);       //自校准,增益1,单极,无缓冲
 delay50us(100);              //延时
//WriteToReg_ADC(0x21);       //通道2,下一个写时钟寄存器
// WriteToReg_ADC(0x0c);       //写时钟寄存器设置更新速率为200hz
// WriteToReg_ADC(0x11);       //通道2,下一个写设置寄存器
//WriteToReg_ADC(0x44);       //自校准,增益1,单极,无缓冲
// delay50us(100);
//***************************读取****************************//
void ceshi(void)
  if(DRDY==0)     //数据准备好
           WriteToReg_ADC(0x38);       //下一操作为读数据寄存器1
           value1=Read_ADC16BitValue();//读取
          LED_1;                 //进入AD,指示等灭
           yellowled();           //黄灯闪烁
  greenled();               //绿灯闪烁
void main(void)
        delay50us(100);   //延时等待外围器件稳定
        IO_Init();
        spi_init();
        ADC_Init();
        while(1)
         ceshi();         //读取AD数据
AD7705精度在16位,第一次用16位的AD,很好....先前一直不能正确读取数值.是因为AD7705坏了,损坏的原因是设计上的失误,我把REF IN+接地了,REF IN-接参考电压..后来重新焊接了一个板子,把REF IN+修改了.就好了,哎,不是问题的问题!!
大家看下面的图,REF IN+接错了,其它的还是比较准确的,程序已经测试过了,谁要用的着的,可以看看,
MEGA16读AD7705程序 - 潇洒一回 - 芯的起点
两个通道依次读取,注意写通讯寄存器的数值,
#include
#include
uchar ch_flag=0;
    uint j;
    for(;t>0;t--)
        for(j=0;j<70;j++)
    uint j;
    for(;t>0;t--)
        for(j=0;j<7;j++)
        uint i;
        for(;t>0;t--)
void IO_Init(void)
 DDRC=0x00;
 PORTC=0x00;
void spi_init(void)
 //CS_0;    //使能SPI器件
//******************SPI写寄存器函数 8BIT*******************************//
void WriteToReg_ADC(uchar byteword)
   CS_0;    //使能SPI器件
  //SPE_1;
//  delay5us(10);
//******************SPI读函数 8BIT*******************************//
//******************SPI读数据寄存器函数 16BIT****************************//
    uchar temp1=0;
    uint temp=0;
         CS_0;    //使能SPI器件
        temp=temp<<8;
        temp=temp|temp1;
         CS_1;    //禁止SPI器件
        return temp;
void greenled(void)
           LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
          LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
           LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
          LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
void ADC_Init(void)
  uchar i;
   for(i=10;i>0;i--)
 WriteToReg_ADC(0x0a);       //写时钟寄存器设置更新速率为200hz
 WriteToReg_ADC(0x40);       //自校准,增益1,双极,缓冲
 delay50us(100);
//***************************按照通道1读取****************************//
void Read_ch1(void)
  uint temp1=0;
  if(DRDY==0)     //数据准备好
           temp1=Read_ADC16BitValue();//读取
           LED_1;                 //进入AD,指示等灭
           yellowled();           //黄灯闪烁
    greenled();               //绿灯闪烁
        value1=temp1;
        WriteToReg_ADC(0x39);// 下一操作为读数据寄存器2
//***************************按照通道2读取****************************//
void Read_ch2(void)
  uint temp2=0;
  if(DRDY==0)     //数据准备好
           temp2=Read_ADC16BitValue();//读取
           LED_1;                 //进入AD,指示等灭
           yellowled();           //黄灯闪烁
    greenled();               //绿灯闪烁
        value2=temp2;
//********************获取两个通道模拟量数值***************//
void get_ad(void)
  if(DRDY==0)     //数据准备好
    ch_flag++;
        if(ch_flag==0x03)
        {ch_flag=0x00;}
  if(ch_flag==0x01)
  { Read_ch1();}
  if(ch_flag==0x02)
  { Read_ch2();}
//***********************主程序*********************************//
void main(void)
        IO_Init();
        spi_init();
        ADC_Init();
        while(1)
   get_ad();
        greenled(); greenled(); greenled();               //绿灯闪烁
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 光控音效发生器电路
  • 非常简单的150W功放电路图
  • 一个简单的警笛电路图
  • 一个简单的立体声平衡指示器电路
  • 分享一个电网倾角计电路
  • 使用NE555和磁簧开关的橱柜照明电路
    相关电子头条文章
