单片机
KS0108 128X64 LCD C语言AVR程序
2017-12-13 来源:eefocus
LCD引脚定义
1---GND
2---VCC
3---VLCD
4---D/I
5---R/W
6---E
7到14 D0-D7
15--CS1
16--CS2
17--RESET
18--VEE
19--SW
20--NC
#include
#include
unsigned char CurOffset,CurRow,CurPage,CurCol;
/*  常量定义  */
#define LCD_STATUS_BUSY 0x80
#define  START_LINE0   0xc0
#define  DISPLAY_ON    0x3f
#define  DISPLAY_OFF   0x3e
#define  PARA1         0x40
//PORTA---数据口  PORTB----控制口
volatile unsigned char *LCD_DIR_PORT = &DDRA;
volatile unsigned char *LCD_IP_PORT  = &PINA;
volatile unsigned char *LCD_OP_PORT  = &PORTA;
volatile unsigned char *LCD_EN_PORT  = &PORTB;
volatile unsigned char *LCD_CS2_PORT = &PORTB;
volatile unsigned char *LCD_CS1_PORT = &PORTB;
volatile unsigned char *LCD_RW_PORT  = &PORTB;
volatile unsigned char *LCD_DI_PORT  = &PORTB;
char LCD_EN_BIT  = BIT(4);
char LCD_CS2_BIT = BIT(3);
char LCD_CS1_BIT = BIT(2);
char LCD_RW_BIT  = BIT(1);
char LCD_DI_BIT  = BIT(0);
#define SET_LCD_E                  *LCD_EN_PORT |= LCD_EN_BIT    //LCD使能
#define CLEAR_LCD_E               *LCD_EN_PORT &= ~LCD_EN_BIT   //LCD禁止
#define SET_LCD_DATA              *LCD_DI_PORT |= LCD_DI_BIT    //选择指令端口
#define SET_LCD_CMD               *LCD_DI_PORT &= ~LCD_DI_BIT   //选择数据端口
#define SET_LCD_READ              *LCD_RW_PORT |= LCD_RW_BIT    //读模式
#define SET_LCD_WRITE              *LCD_RW_PORT &= ~LCD_RW_BIT   //写模式
#define SET_LCD_CS2              *LCD_CS2_PORT |= LCD_CS2_BIT  //左屏选择禁止
#define CLEAR_LCD_CS2              *LCD_CS2_PORT &= ~LCD_CS2_BIT //左屏选择使能
#define SET_LCD_CS1              *LCD_CS1_PORT |= LCD_CS1_BIT  //左屏选择禁止
#define CLEAR_LCD_CS1              *LCD_CS1_PORT &= ~LCD_CS1_BIT //左屏选择使能
#define LEFT 0
#define RIGHT 1
#define CMD 0
#define DATA 1
void LCD_BUSY(unsigned char lr) //判断忙标志
    unsigned char status;
    CLI();
    if(lr==LEFT)
        CLEAR_LCD_CS2; //cs2=0
        SET_LCD_CS1;   //cs1=1
    else
        SET_LCD_CS2;   //cs2=1
        CLEAR_LCD_CS1; //cs1=0
    SET_LCD_CMD;
    *LCD_DIR_PORT = 0x00;
    *LCD_OP_PORT = 0xff;
    SET_LCD_READ;
    SET_LCD_E;
    asm('nop');    asm('nop');
    while((*LCD_IP_PORT) & LCD_STATUS_BUSY)
        CLEAR_LCD_E;
        SET_LCD_E;
    CLEAR_LCD_E;
    SET_LCD_WRITE;
    SEI();
void write_LCD(unsigned char lr,unsigned char cd,unsigned char data) /*写入指令或数据*/
    CLI();
    LCD_BUSY(lr);
    if(cd==CMD)    SET_LCD_CMD;
    else SET_LCD_DATA;
    SET_LCD_WRITE;
    SET_LCD_E;
    *LCD_DIR_PORT = 0xff;
    *LCD_OP_PORT = data;
    CLEAR_LCD_E;
    SEI();
unsigned char read_LCD(unsigned char lr)      /*  读显示数据 */
    unsigned char data;
    CLI();
    LCD_BUSY(lr);
    SET_LCD_DATA;
    SET_LCD_READ;
    SET_LCD_E;
    data=*LCD_IP_PORT;
    CLEAR_LCD_E;
    SET_LCD_WRITE;
    LCD_BUSY(lr);
    SET_LCD_DATA;
    SET_LCD_READ;
    SET_LCD_E;
    data=*LCD_IP_PORT;
    CLEAR_LCD_E;
    SET_LCD_WRITE;
    SEI();
    return data;
void set_start_line_L(unsigned char line) /*设置显示起始行*/ //0-63
    write_LCD(LEFT,CMD,0xc0|line);
void set_start_line_R(unsigned char line) /*设置显示起始行*/ //0-63
    write_LCD(RIGHT,CMD,0xc0|line);
void set_page_L(unsigned char page)    /*设置X地址 设置页*/  //0-7
    write_LCD(LEFT,CMD,0xb8|page);
void set_page_R(unsigned char page)    /*设置X地址 设置页*/ //0-7
    write_LCD(RIGHT,CMD,0xb8|page);
void set_col_addr_L(unsigned char col) /*设置Y地址*/ //0-63
    write_LCD(LEFT,CMD,0x40|col);
void set_col_addr_R(unsigned char col) /*设置Y地址*/ //0-63
    write_LCD(RIGHT,CMD,0x40|col);
void init_lcd(void) /*初始化函数*/
    set_start_line_L(0); /*显示起始行为0*/
    set_start_line_R(0); /*显示起始行为0*/
    write_LCD(LEFT,CMD,DISPLAY_ON); /*  开显示  */
    write_LCD(RIGHT,CMD,DISPLAY_ON); /*  开显示  */
void clr_lcd(void) /*清屏函数*/
    unsigned char pages,i;
    for(pages=0;pages<8;pages++)
            set_page_L(pages);  /* X 页地址 */
            set_page_R(pages);  /* X 页地址 */
            for(i=0;i<64;i++)
                    set_col_addr_L(i);//Y
                    set_col_addr_R(i);//Y
                    write_LCD(LEFT,DATA,0x0);
                    write_LCD(RIGHT,DATA,0x0);
//ASCII 字模宽度及高度
#define ASC_CHR_WIDTH    8
#define ASC_CHR_HEIGHT    12
typedef struct typFNT_ASC16    /* 汉字字模显示数据结构 */
    char Index[1];
    char Msk[16];
struct typFNT_ASC16 const ASC_16[] = {    /* 显示为8*16  Curier 10 常规*/
'1',0x00,0x00,0x08,0x08,0xFC,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x07,0x04,0x04,0x00,
'2',0x00,0x00,0x08,0x04,0x84,0x44,0x38,0x00,0x00,0x00,0x06,0x05,0x04,0x04,0x04,0x00,
'3',0x00,0x00,0x08,0x04,0x44,0x44,0xB8,0x00,0x00,0x00,0x02,0x04,0x04,0x04,0x03,0x00,
'4',0x00,0x00,0x80,0x60,0x18,0xFC,0x00,0x00,0x00,0x00,0x01,0x01,0x05,0x07,0x05,0x00,
'5',0x00,0x00,0x7C,0x44,0x44,0x44,0x84,0x00,0x00,0x00,0x02,0x04,0x04,0x04,0x03,0x00,
'6',0x00,0x00,0xF0,0x48,0x44,0x44,0x80,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x03,0x00,
'7',0x00,0x00,0x0C,0x04,0x84,0x64,0x1C,0x00,0x00,0x00,0x00,0x06,0x01,0x00,0x00,0x00,
'8',0x00,0x00,0xB8,0x44,0x44,0x44,0xB8,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x03,0x00,
'9',0x00,0x00,0x38,0x44,0x44,0x44,0xF8,0x00,0x00,0x00,0x00,0x04,0x04,0x02,0x01,0x00,
'0',0x00,0x00,0xF8,0x04,0x04,0x04,0xF8,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x03,0x00,
'.',0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,
',',0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x04,0x00,0x00,0x00,
':',0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,
';',0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x04,0x00,0x00,0x00,
'-',0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
'_',0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
'A',0x00,0x00,0x80,0x64,0x1C,0x60,0x80,0x00,0x00,0x04,0x07,0x05,0x01,0x05,0x07,0x04,
'B',0x00,0x04,0xFC,0x44,0x44,0x44,0x44,0xB8,0x00,0x04,0x07,0x04,0x04,0x04,0x04,0x03,
'C',0x00,0xF0,0x08,0x04,0x04,0x04,0x04,0x08,0x00,0x01,0x02,0x04,0x04,0x04,0x04,0x02,
'D',0x00,0x04,0xFC,0x04,0x04,0x04,0x08,0xF0,0x00,0x04,0x07,0x04,0x04,0x04,0x02,0x01,
'E',0x00,0x04,0xFC,0x44,0x44,0xE4,0x04,0x0C,0x00,0x04,0x07,0x04,0x04,0x04,0x04,0x06,
'F',0x00,0x04,0xFC,0x44,0x44,0xE4,0x04,0x0C,0x00,0x04,0x07,0x04,0x04,0x00,0x00,0x00,
' ',0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
'=',0x00,0x00,0xA0,0xA0,0xA0,0xA0,0xA0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
'(',0x00,0x00,0x00,0xE0,0x18,0x04,0x00,0x00,0x00,0x00,0x00,0x03,0x0C,0x10,0x00,0x00,
')',0x00,0x00,0x00,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x00,0x10,0x0C,0x03,0x00,0x00,
'V',0x00,0x04,0x3C,0xC4,0x00,0xC4,0x3C,0x04,0x00,0x00,0x00,0x01,0x06,0x01,0x00,0x00,
'm',0x00,0x20,0xE0,0x20,0xC0,0x20,0xC0,0x00,0x00,0x04,0x07,0x00,0x07,0x00,0x07,0x04,
'H',0x00,0x04,0xFC,0x44,0x40,0x44,0xFC,0x04,0x00,0x04,0x07,0x04,0x00,0x04,0x07,0x04,
'*',0x90,0x90,0x60,0xFC,0x60,0x90,0x90,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x00,
#define ASC_Hz_WIDTH    12
//#define ASC_HZ_HEIGHT    12
typedef struct typFNT_GB16    /*12*16 汉字字模显示数据结构 */
    char Index[2];
    char Msk[24];
struct typFNT_GB16 const GB_16[] = {    /* 宋体 9 显示为12*16 */
'科',0x8A,0x6A,0xFE,0x29,0x49,0x80,0x92,0xA4,0x80,0xFF,0x40,0x00,0x01,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,
'技',0x44,0x44,0xFF,0x24,0x00,0x64,0xA4,0x3F,0xA4,0x64,0x04,0x00,0x04,0x04,0x07,0x00,0x04,0x04,0x02,0x01,0x02,0x04,0x04,0x00,
'有',0x42,0x22,0x12,0xFA,0x4E,0x4B,0x4A,0x4A,0xFA,0x02,0x02,0x00,0x00,0x00,0x00,0x07,0x01,0x01,0x01,0x05,0x07,0x00,0x00,0x00,
'限',0xFF,0x81,0x99,0xE7,0x00,0xFF,0x25,0xE5,0x25,0xBF,0x40,0x00,0x07,0x00,0x00,0x00,0x00,0x07,0x04,0x02,0x01,0x02,0x04,0x00,
'公',0x20,0x10,0x08,0x07,0xC0,0x30,0x83,0x0C,0x10,0x20,0x20,0x00,0x00,0x04,0x06,0x05,0x04,0x04,0x02,0x03,0x06,0x00,0x00,0x00,
'司',0x08,0x09,0xE9,0x29,0x29,0x29,0xED,0x09,0x01,0xFF,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x04,0x04,0x07,0x00,0x00,
unsigned char GetPage(void) /*得到当前页*/
    return CurPage;
unsigned char GetCol(void) /*得到当前列*/
    return CurCol;
void SetPageCol(unsigned char upage, unsigned char ucol) /* 设置液晶的页和列 */
    CurPage = upage;
    CurCol = ucol;
    if(ucol<64)
        set_page_L(upage);
        set_col_addr_L(ucol);
    else
        set_page_R(upage);
        set_col_addr_R(ucol-64);
/* 设置当前显示的页和列 */
void SetRowCol(unsigned char urow, unsigned char ucol)
    unsigned char page;
    CurRow = urow;
    CurCol = ucol;
    switch(urow)
        case 1:
            page=0;
            CurOffset=1;
            break;
        case 2:
            page=1;
            CurOffset=2;
            break;
        case 3:
            page=3;
            CurOffset=1;
            break;
        case 4:
            page=4;
            CurOffset=2;
            break;
        case 5:
            page=6;
            CurOffset=1;
            break;
    SetPageCol(page,ucol);
void disp_ch(unsigned char c)
    unsigned char k,j,uPage,uCol,ch_r,ch_w;
    unsigned char width;
    unsigned char len;
    uPage = GetPage();
    uCol = GetCol();
    len=sizeof(ASC_16)/sizeof(ASC_16[0]);
    for(k=0;k    {
        if(c == ASC_16[k].Index[0] ) break;
    if(k    {
        if(c==’-’||c==’:’)
            width=ASC_CHR_WIDTH-2;
        else if(c==’|’)
            width=ASC_HZ_WIDTH-ASC_CHR_WIDTH;
        else
            width=ASC_CHR_WIDTH;
        if(CurOffset==1) //下半部是写半个字节
            for(j=0;j            {
                SetPageCol(uPage,uCol+j);
                ch_w=ASC_16[k].Msk[j];
                if(uCol+j<64)    write_LCD(LEFT,DATA,ch_w);
                else write_LCD(RIGHT,DATA,ch_w);
            SetPageCol(uPage+1,uCol);
            for(j=0;j            {
                SetPageCol(uPage+1,uCol+j);
                if(uCol+j<64) ch_r=read_LCD(LEFT);
                else ch_r=read_LCD(RIGHT);
                ch_r&=0xf0;
                ch_w=ASC_16[k].Msk[ASC_CHR_WIDTH+j]&0x0f;
                ch_w|=ch_r;
        else //上半部是写半个字节
            for(j=0;j            {
                ch_r&=0x0f;
                ch_w=ch_w<<4;
                ch_w|=ch_r;
            for(j=0;j            {
                ch_r=ASC_16[k].Msk[j];
                ch_w=ASC_16[k].Msk[ASC_CHR_WIDTH+j];
                ch_r=ch_r>>4;
                ch_w=ch_w<<4;
                ch_w|=ch_r;
    SetPageCol(uPage,uCol+width);
void disp_hz(unsigned char *hz)
    uPage = GetPage();
    uCol = GetCol();
    for(k=0;k    {
        if(hz[0] == GB_16[k].Index[0] && hz[1] == GB_16[k].Index[1])
            break;
    if(CurOffset==1)
    for(j=0;j    {
        ch_w=GB_16[k].Msk[j];
    for(j=0;j    {
        ch_r&=0xf0;
        ch_w=GB_16[k].Msk[ASC_HZ_WIDTH+j]&0x0f;
        ch_w|=ch_r;
    SetPageCol(uPage,uCol+ASC_HZ_WIDTH);
    else //汉字上半部是写半个字节
    for(j=0;j    {
        ch_r&=0x0f;
        ch_w=ch_w<<4;
        ch_w|=ch_r;
    for(j=0;j    {
        ch_r=GB_16[k].Msk[j];
        ch_w=GB_16[k].Msk[ASC_HZ_WIDTH+j];
        ch_r=ch_r>>4;
        ch_w=ch_w<<4;
        ch_w|=ch_r;
void disp_str(unsigned char *p)
    unsigned char i=0;
    while(p[i]>0)
        if(p[i] < 128)
        {    /* ASCII */
            disp_ch(p[i]);
        else
        {    /* 中文 */
            disp_hz(&p[i]);
            i++;
        i++;
/*             绘点函数              */
/* XX--(0-128) YY--(0-63) FLAG=1绘点   FLAG=0 清点 */
void pixel(unsigned char xx,unsigned char yy,unsigned char flag)
    unsigned int y,ch;
    ch=yy%8;  //余数
    y=1;
    for(;ch!=0;)
            y=y*2;
            ch--;
    if(xx<64)
            set_page_L(yy/8);
            set_col_addr_L(xx);
            ch=read_LCD(LEFT);
            set_col_addr_L(xx);
            if(flag)
                write_LCD(LEFT,DATA,ch|y);
            else
                y=~y;
                ch&=y;
    else
            set_page_R(yy/8);
            set_col_addr_R(xx-64);
            ch=read_LCD(RIGHT);
            if(flag)
                write_LCD(RIGHT,DATA,ch|y);
            else
                y=~y;
                ch&=y;
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • CCD图像传感器在微光电视系统中的应用
  • 如何利用ESP8266制作一个简单的四轴飞行器
  • 非常简单的150W功放电路图
  • 基于IC555的可变PWM振荡器电路
  • 分享一个电网倾角计电路
  • 使用NE555和磁簧开关的橱柜照明电路
    相关电子头条文章
