单片机
Atmega16l单相逆变器SPWM原理图PCB及源程序
2019-10-21 来源:51hei
Altium Designer画的原理图和PCB图
Atmega16l单片机源码如下:
#include
#include
#define uint unsigned int
#define uchar unsigned char
uchar zd=0,c=0;
uint iv=0,ii=0,ov=0,oi=0,sj=0,b=0;
uchar table[3]={8,8,8};
#pragma data:code
flash uint table1[]={0X3f,0X06,0X5b,0X4f,0X66,0X6d,0X7d,0X07,0X7f,0X6f,0X77,0X7c,0X39,0X5e,0X79,0X71,0X00,
0X40,0XFF};
flash uint table2[]={
0,5,10,16,21,27,32,38,43,48,54,59,64,69,75,80,85,90,95,100,
105,110,115,120,124,129,134,138,143,147,152,156,160,164,168,172,176,180,184,187,
191,194,198,201,204,207,210,213,216,219,221,224,226,228,230,233,234,236,238,240,
241,242,244,245,246,247,247,248,249,249,249,249,250,249,249,249,249,248,247,247,
246,245,244,242,241,240,238,236,234,233,230,228,226,224,221,219,216,213,210,207,
204,201,198,194,191,187,184,180,176,172,168,164,160,156,152,147,143,138,134,129,
125,120,115,110,105,100,95,90,85,80,75,69,64,59,54,48,43,38,32,27,
21,16,10,5,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0};
flash uint table3[]={
0,0,0,0,
21,16,10,5};
#pragma interrupt_handler timer2_capt_isr:5
#pragma interrupt_handler adc_sj:15
void timer2_capt_isr()
   TCNT2=5;
   c++;
   if(c>=2)
     c=0;
         OCR1AH=0;
         OCR1AL=table2[b];
         OCR1BH=0;
     OCR1BL=table3[b];
         b++;
         if(b>=288){b=0;zd++;}
void timer1_init()
    TCCR2=0X01;
        TCNT2=5;
        OCR1AH=0;
        OCR1AL=0;
        OCR1BH=0;
        OCR1BL=0;
        ICR1=250;
        TCCR1A=0XA0;
        TCCR1B=0X11;
void init_devices()
        DDRD|=BIT(4);
        DDRD|=BIT(5);
        timer1_init();
        MCUCR=0X00;
        GICR=0X00;
        TIMSK=0X40;
        SREG|=BIT(7);
void led()//正常指示灯
    PORTB|=BIT(3);
        PORTB&=~BIT(4);
void led1()//故障指示灯
   PORTB&=~BIT(3);
   PORTB|=BIT(4);
void led2()//报警指示灯
   PORTB|=BIT(4);
   PORTB|=BIT(3);
void ad_init(uchar a)//AD转换
  // uint sj;
   SFIOR=0;//设置ADC为连续工作模式
   ADMUX=a;//设置那一路ADC转换
   ADCSR=0X80;//ADC转换使能
   ADCSR|=BIT(ADSC);//启动ADC
   ADCSR|=BIT(ADIE);
   SREG|=BIT(7);
//  while(!(ADCSR&(BIT(ADIF))));//等待ADC转换完成
//  sj=ADCL;
//  sj=sj+256*ADCH;
  // ADCSR|=BIT(ADIF);
  // ADCSR=0X00;//关闭ADC
  // return sj;
void  show(uchar bai,uchar shi,uchar ge )
         PORTC=table1[bai];
         PORTA|=BIT(7);
         PORTA&=~BIT(7);
         PORTC=table1[shi];
         PORTA|=BIT(6);
         PORTA&=~BIT(6);
         PORTC=table1[ge];
         PORTA|=BIT(5);
         PORTA&=~BIT(5);
void adc_sj()
   sj=ADCL;
   sj=sj+256*ADCH;
   ADCSR|=BIT(ADIF);
   ADCSR=0X00;//关闭ADC
void  delay(uint ms)
           uint  x,y;
          for(x=0;x          {
             for(y=0;y<1141;y++);
void main()
   uchar f=0;
   uint ci=0;
        DDRC=0XFF;
        DDRA|=BIT(5);
        DDRA|=BIT(6);
        DDRA|=BIT(7);
        PORTC=0X00;
    PORTA&=~BIT(7);
        PORTA&=~BIT(6);
        PORTA&=~BIT(5);
        DDRA&=~BIT(1);
        PORTA&=~BIT(1);
        DDRA&=~BIT(4);
        PORTA&=~BIT(4);
    DDRB|=BIT(3);
    DDRB|=BIT(4);
    PORTB&=~BIT(3);
    PORTB&=~BIT(4);
    DDRB|=BIT(6);
    PORTB&=~BIT(6);
    init_devices();
   while(1)
    if(zd>=80)
            zd=0;
                switch(f)
                  case 0: table[0]=1;table[1]=17;table[2]=17;f++;ad_init(0x44);
                  break;
                  case 1:sj=sj/51;iv=sj;table[0]=iv/100;table[1]=iv%100/10;table[2]=iv%10;f++;sj=0;led();
                  break;
                  case 2: table[0]=2;table[1]=17;table[2]=17;f++;
                  break;
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
最新器件
精选电路图
  • CCD图像传感器在微光电视系统中的应用
  • 如何利用ESP8266制作一个简单的四轴飞行器
  • 非常简单的150W功放电路图
  • 基于IC555的可变PWM振荡器电路
  • 优化电路板布局的简单方法
  • 分享一个电网倾角计电路
    相关电子头条文章
