单片机
LED 驱动控制专用电路 TM1628 AVR 测试程序源代码
2019-12-04 来源:eefocus
#include
#include
#define TM1628_DIO_PORTNAME     B
#define TM1628_DIO_BIT          5
#define TM1628_CLK_PORTNAME     B
#define TM1628_CLK_BIT          7
#define TM1628_STB_PORTNAME     B
#define TM1628_STB_BIT          4
#ifndef _CONCAT_
#define _CONCAT_
#define CONCAT(a, b)            a ## b
#define CONCAT_DDR(portname)    CONCAT(DDR, portname)
#define CONCAT_PORT(portname)   CONCAT(PORT, portname)
#define CONCAT_PIN(portname)    CONCAT(PIN, portname)
#endif /* CONCAT */
#define TM1628_DIO_DDR          CONCAT_DDR(TM1628_DIO_PORTNAME)
#define TM1628_DIO_PORT         CONCAT_PORT(TM1628_DIO_PORTNAME)
#define TM1628_DIO_PIN          CONCAT_PIN(TM1628_DIO_PORTNAME)
#define TM1628_DIO_0            TM1628_DIO_PORT &= ~(1 << TM1628_DIO_BIT)
#define TM1628_DIO_1            TM1628_DIO_PORT |= (1 << TM1628_DIO_BIT)
#define TM1628_DIO_VALUE        (TM1628_DIO_PIN & (1 << TM1628_DIO_BIT))
#define TM1628_CLK_DDR          CONCAT_DDR(TM1628_CLK_PORTNAME)
#define TM1628_CLK_PORT         CONCAT_PORT(TM1628_CLK_PORTNAME)
#define TM1628_CLK_PIN          CONCAT_PIN(TM1628_CLK_PORTNAME)
#define TM1628_CLK_0            TM1628_CLK_PORT &= ~(1 << TM1628_CLK_BIT)
#define TM1628_CLK_1            TM1628_CLK_PORT |= (1 << TM1628_CLK_BIT)
#define TM1628_STB_DDR          CONCAT_DDR(TM1628_STB_PORTNAME)
#define TM1628_STB_PORT         CONCAT_PORT(TM1628_STB_PORTNAME)
#define TM1628_STB_PIN          CONCAT_PIN(TM1628_STB_PORTNAME)
#define TM1628_STB_0            TM1628_STB_PORT &= ~(1 << TM1628_STB_BIT)
#define TM1628_STB_1            TM1628_STB_PORT |= (1 << TM1628_STB_BIT)
#define SEG_NULL      0x00
#define SEG_P         0x73
#define SEG_N         0x37
#define SEG_U         0x3e
#define SEG_L         0x38
#define SEG_H         0x76
#define SEG_NEG       0x40
#define LEFT          0
#define RIGHT         1
unsigned char _data[10], brightness = 0;
long n = 0;
unsigned char number[] =
    0x3f,0x06,0x5b,0x4f,
    0x66,0x6d,0x7d,0x07,
    0x7f,0x6f,0x77,0x7c,
    0x39,0x5e,0x79,0x71
void TM1628_TxByte(unsigned char _data)
    unsigned char i = 0;
    TM1628_CLK_1;
    TM1628_DIO_DDR |= (1 << TM1628_DIO_BIT);
    for (i = 0; i < 8; i++)
        TM1628_CLK_0;
        if (_data & 0x01)
            TM1628_DIO_1;
        else
            TM1628_DIO_0;
        TM1628_CLK_1;
        _data >>= 1;
    _delay_us(2);
unsigned char TM1628_RxByte(void)
    unsigned char _data = 0, i = 0;
    TM1628_CLK_1;
    TM1628_DIO_DDR &= ~(1 << TM1628_DIO_BIT);
    TM1628_DIO_1;
        TM1628_CLK_0;
        _data >>= 1;
        TM1628_CLK_1;
        _delay_us(1);
        if (TM1628_DIO_VALUE)
            _data |= 0x80;
    return _data;
void TM1628_WriteCommand(unsigned char command)
    TM1628_STB_0;
    TM1628_TxByte(command);
    TM1628_STB_1;
void TM1628_Display(unsigned char *p_data, unsigned char brightness)
    unsigned char i = 0, j = 0, temp = 0;
    unsigned char dis_arr[14] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
    for (i = 0; i < 7; i++)
        temp = 0;
        for (j = 0; j < 8; j++)
            if(p_data[j] & (1 << i))
                temp |= (1 << j);
        dis_arr[i << 1] = temp;
        temp = 0;
        for (j = 0; j < 2; j++)
            if(p_data[j + 8] & (1 << i))
                temp |= (1 << j);
        dis_arr[(i << 1) + 1] = temp;
    TM1628_WriteCommand(0x03);
    TM1628_WriteCommand(0x40);
    TM1628_STB_0;
    TM1628_TxByte(0xc0);
    _delay_us(1);
    for (i = 0; i < 14; i++)
        TM1628_TxByte(dis_arr[i]);
    TM1628_STB_1;
    if (brightness > 7)
        brightness = 7;
    TM1628_WriteCommand(0x88 + brightness);
//数据,进制,起始位置,占用位数,对齐方式,亮度
void TM1628_DisplayNumber(long n, unsigned char ary, unsigned char start, unsigned char size, unsigned char left_right, unsigned char brightness)
    unsigned char i = 0, temp[size], neg_flag = 0, length = 0;
    if (-n > 0)
        n = -n;
        neg_flag = 1;
    for (i = 0; ((i < size) && (n > 0)); i++)
        temp[i] = number[n % ary];
        n /= ary;
    if (i == 0)
        temp[i] = number[0];
        i = 1;
    if (neg_flag && (i < size))
        temp[i] = SEG_NEG;
        i++;
    length = i;
    if (left_right == LEFT)
        for (i = 0; i < length; i++)
            _data[start + i] = temp[length - i - 1];
        for (i = length; i < size; i++)
            _data[start + i] = SEG_NULL;
    else if (left_right == RIGHT)
        for (i = 0; i < size - length; i++)
        for (i = size - length; i < size; i++)
            _data[start + i] = temp[size - i - 1];
    TM1628_Display(_data, brightness);
unsigned char TM1628_ReadKey(void)
    unsigned char i = 0, temp = 0;
    TM1628_STB_0;
    TM1628_TxByte(0x42);
    _delay_us(100);
    for (i = 0; i < 5; i++)
        _delay_us(2);
        temp = TM1628_RxByte();
        if (temp)
            break;
    TM1628_STB_1;
    if (temp & 0x03)
        temp = (2 * i + 1) + ((temp & 0x03) - 1) * 10;
    else if (temp & 0x18)
        temp = (2 * (i + 1)) + (((temp & 0x18) >> 3) - 1) * 10;
    return temp;
void key_process(unsigned char key)
    if (key != 0)
        TM1628_DisplayNumber(key, 10, 2, 2, LEFT, brightness);
    if (key == 1 && brightness < 7)
        brightness++;
        TM1628_DisplayNumber(brightness, 10, 0, 1, LEFT, brightness);
    else if (key == 11 && brightness > 0)
        brightness--;
    else if (key == 10)
        n++;
        TM1628_DisplayNumber(n, 10, 5, 5, RIGHT, brightness);
    else if (key ==20)
        n--;
int main(void)
    unsigned char i = 0, key = 0, now = 0, repeat_flag = 0;
    unsigned int repeat_count = 0;
    _delay_ms(100);
    TM1628_STB_1;
    TM1628_STB_DDR |= (1 << TM1628_STB_BIT);
    TM1628_CLK_1;
    TM1628_CLK_DDR |= (1 << TM1628_CLK_BIT);
    for (i = 0; i < 10; i++)
        _data[i] = SEG_H;
        TM1628_Display(_data, i + 1);
        _delay_ms(100);
        TM1628_Display(_data, 7 - i);
        _delay_ms(100);
        _data[i] = SEG_NULL;
    while (1)
        key = TM1628_ReadKey();
        if (key != now)
            now = key;
            repeat_flag = 0;
            repeat_count = 0;
            key_process(key);
        else
            if (repeat_flag)
                key_process(key);
                _delay_ms(50);
            else
                repeat_count++;
                if (repeat_count > 5000)
                    repeat_flag = 1;
                    repeat_count = 0;
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 短波AM发射器电路设计图
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 如何调制IC555振荡器
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
