单片机
S3C2440 2440init.s分析第一篇(二)
2016-05-04 来源:eefocus
;//2.根据工作频率设置pll
;这里介绍一下计算公式
;//Fpllo=(m*Fin)/(p*2^s)
;//m=MDIV+8,p=PDIV+2,s=SDIV
;The proper range of P and M: 1<=P<=62, 1<=M<=248
;Fpllo必须大于20Mhz小于66Mhz
;Fpllo*2^s必须小于170Mhz
;如下面的PLLCON设定中的M_DIV P_DIV S_DIV是取自option.h中
;#elif (MCLK==40000000)
;#define PLL_M (0x48)
;#define PLL_P (0x3)
;#define PLL_S (0x2)
;所以m=MDIV+8=80,p=PDIV+2=5,s=SDIV=2
;硬件使用晶振为10Mhz,即Fin=10Mhz
;Fpllo=80*10/5*2^2=40Mhz
    ;To reduce PLL lock time, adjust the LOCKTIME register.
    ldr    r0,=LOCKTIME
    ldr    r1,=0xffffff
    str    r1,[r0]
;//设置PLL的重置延迟
    [ PLL_ON_START
    ; Added for confirm clock divide. for 2440.
    ; Setting value Fclk:Hclk:Pclk
    ldr    r0,=CLKDIVN
    ldr    r1,=CLKDIV_VAL        ; 0=1:1:1, 1=1:1:2, 2=1:2:2, 3=1:2:4, 4=1:4:4, 5=1:4:8, 6=1:3:3, 7=1:3:6.
    str    r1,][r0]                ;//数据表示分频数
    ;//Configure UPLL Fin=12.0MHz UFout=48MHz
    ldr    r0,=UPLLCON
    ldr    r1,=((U_MDIV<<12)+(U_PDIV<<4)+U_SDIV) ;//USB PLL CONFIG
    str    r1,[r0]
    nop    ;// Caution: After UPLL setting, at least 7-clocks delay must be inserted for setting hardware be completed.
    nop
    nop
    nop
    nop
    nop
    nop
    ;//Configure MPLL Fin=12.0MHz MFout=304.8MHz
    ldr    r0,=MPLLCON
    ldr    r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV)
    str    r1,[r0]
;//Check if the boot is caused by the wake-up from SLEEP mode.
    ldr    r1,=GSTATUS2
    ldr    r0,[r1]
    tst    r0,#0x2        ;test if bit[1] is 1 or 0 0->C=1
                                            1->C=0
    ;In case of the wake-up from SLEEP mode, go to SLEEP_WAKEUP handler.
    bne    WAKEUP_SLEEP    ;C=0,jump
    EXPORT StartPointAfterSleepWakeUp
;//3.置存储相关寄存器的程序
;这是设置SDRAM,flash ROM 存储器连接和工作时序的程序,片选定义的程序
;SMRDATA map在下面的程序中定义
;SMRDATA中涉及的值请参考memcfg.s程序
;具体寄存器各位含义请参考s3c44b0 spec
    ;Set memory control registers
     ldr    r0,=SMRDATA
    ldr    r1,=BWSCON    ;BWSCON Address
    add    r2, r0, #52    ;End address of SMRDATA
    ldr    r3, [r0], #4
    str    r3, [r1], #4
    cmp    r2, r0
    bne    %B0
;//set memory registers
;//4.初始化各模式下的栈指针
         ;Initialize stacks
    bl    InitStacks
;//5.设置缺省中断处理函数
      ; Setup IRQ handler
    ldr    r0,=HandleIRQ       ;This routine is needed
    ldr    r1,=IsrIRQ      ;if there isn't 'subs pc,lr,#4' at 0x18, 0x1c
    str    r1,[r0]
    ;//initialize the IRQ 将普通中断判断程序的入口地址给HandleIRQ
;//6.将数据段拷贝到ram中 将零初始化数据段清零 跳入C语言的main函数执行到这步结束bootloader初步引导结束
    ;If main() is used, the variable initialization will be done in __main().
      :LNOT:USE_MAIN    ;initialized {FALSE}
                          ;Copy and paste RW data/zero initialized data
    LDR     r0, =|Image$$RO$$Limit| ; Get pointer to ROM data
    LDR     r1, =|Image$$RW$$Base| ; and RAM copy
    LDR     r3, =|Image$$ZI$$Base|
    ;Zero init base => top of initialised data
    CMP     r0, r1      ; Check that they are different just for debug??????????????????????????
    BEQ     %F2
    CMP     r1, r3      ; Copy init data
    LDRCC   r2, ][r0], #4    ;--> LDRCC r2, [r0] + ADD r0, r0, #4
    STRCC   r2, [r1], #4    ;--> STRCC r2, [r1] + ADD r1, r1, #4
    BCC     %B1
    LDR     r1, =|Image$$ZI$$Limit| ; Top of zero init segment
    MOV     r2, #0
    CMP     r3, r1      ; Zero init
    STRCC   r2, [r3], #4
    BCC     %B3
    [ :LNOT:THUMBCODE    ;if thumbcode={false} bl main
        bl    Main        ;Don't use main() because ......
;//if thumbcod={ture}
    [ THUMBCODE         ;for start-up code for Thumb mode
        orr    lr,pc,#1
        bx    lr
        CODE16
        CODE32
;function initializing stacks
InitStacks
    ;Don't use DRAM,such as stmfd,ldmfd......
    ;SVCstack is initialized before
    ;Under toolkit ver 2.5, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
    mrs    r0,cpsr
    bic    r0,r0,#MODEMASK
    orr    r1,r0,#UNDEFMODE|NOINT
    msr    cpsr_cxsf,r1        ;UndefMode
    ldr    sp,=UndefStack        ; UndefStack=0x33FF_5C00
    orr    r1,r0,#ABORTMODE|NOINT
    msr    cpsr_cxsf,r1        ;AbortMode
    ldr    sp,=AbortStack        ; AbortStack=0x33FF_6000
    orr    r1,r0,#IRQMODE|NOINT
    msr    cpsr_cxsf,r1        ;IRQMode
    ldr    sp,=IRQStack        ; IRQStack=0x33FF_7000
    orr    r1,r0,#FIQMODE|NOINT
    msr    cpsr_cxsf,r1        ;FIQMode
    ldr    sp,=FIQStack        ; FIQStack=0x33FF_8000
    bic    r0,r0,#MODEMASK|NOINT
    orr    r1,r0,#SVCMODE
    msr    cpsr_cxsf,r1        ;SVCMode
    ldr    sp,=SVCStack        ; SVCStack=0x33FF_5800
    ;USER mode has not be initialized.
    ;//为什么不用初始化user的stacks,系统刚启动的时候运行在哪个模式下???????????????????
    mov    pc,lr
    ;The LR register won't be valid if the current mode is not SVC mode.?????????????
;//系统一开始运行就是SVCmode????????????????????????????????????????
; Clock division test
; Assemble code, because VSYNC time is very short
    EXPORT CLKDIV124
    EXPORT CLKDIV144
CLKDIV124
    ldr     r0, = CLKDIVN
    ldr     r1, = 0x3        ; 0x3 = 1:2:4
    str     r1, [r0]
   wait until clock is stable
    nop
    nop
    nop
    nop
    nop
    ldr     r0, = REFRESH
    ldr     r1, [r0]
    bic        r1, r1, #0xff
    bic        r1, r1, #(0x7<<8)
    orr        r1, r1, #0x470    ; REFCNT135
    str     r1, [r0]
    nop
    nop
    nop
    nop
    nop
    mov     pc, lr
CLKDIV144
    ldr     r0, = CLKDIVN
    ldr     r1, = 0x4        ; 0x4 = 1:4:4
    str     r1, [r0]
    nop
    nop
    nop
    nop
    nop
    ldr     r0, = REFRESH
    ldr     r1, [r0]
    bic        r1, r1, #0xff
    orr        r1, r1, #0x630    ; REFCNT675 - 1520
    str     r1, [r0]
    nop
    nop
    nop
    nop
    nop
    mov     pc, lr
;存储器控制寄存器的定义区
    LTORG
SMRDATA DATA
; Memory configuration should be optimized for best performance
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK<=75Mhz.
    DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
    DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC))   ;GCS0
    DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC))   ;GCS1
    DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC))   ;GCS2
    DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC))   ;GCS3
    DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC))   ;GCS4
    DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC))   ;GCS5
    DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN))    ;GCS6
    DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN))    ;GCS7
    DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)
    DCD 0x32        ;SCLK power saving mode, BANKSIZE 128M/128M
    DCD 0x30        ;MRSR6 CL=3clk
    DCD 0x30        ;MRSR7 CL=3clk
    ALIGN
    AREA RamData, DATA, READWRITE
     _ISR_STARTADDRESS        ; _ISR_STARTADDRESS=0x33FF_FF00
HandleReset      4
HandleUndef      4
HandleSWI         4
HandlePabort     4
HandleDabort     4
HandleReserved #   4
HandleIRQ         4
HandleFIQ         4
;Don't use the label 'IntVectorTable',
;The value of IntVectorTable is different with the address you think it may be.
;IntVectorTable
;@0x33FF_FF20
HandleEINT0         4
HandleEINT1         4
HandleEINT2         4
HandleEINT3         4
HandleEINT4_7     4
HandleEINT8_23     4
HandleCAM               ; Added for 2440.
HandleBATFLT     4
HandleTICK         4
HandleWDT         4
HandleTIMER0      4
HandleTIMER1      4
HandleTIMER2      4
HandleTIMER3      4
HandleTIMER4      4
HandleUART2       4
;@0x33FF_FF60
HandleLCD          4
HandleDMA0         4
HandleDMA1         4
HandleDMA2         4
HandleDMA3         4
HandleMMC         4
HandleSPI0         4
HandleUART1         4
HandleNFCON               ; Added for 2440.
HandleUSBD         4
HandleUSBH         4
HandleIIC         4
HandleUART0      4
HandleSPI1          4
HandleRTC          4
HandleADC          4
;@0x33FF_FFA0
    END
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
最新器件
精选电路图
  • 单稳态控制电路设计与分析
  • MT3608构成3.7V转12V的升压电路图
  • 比较常见的功率整流器和滤波电路
  • 基于M66T旋律发​​生器的电路图解析
  • 一个简单的红外耳机电路
  • 基于TDA1554的立体声放大器电路
    相关电子头条文章
