单片机
外设一个一个学 for_ARM interrupt keyboard
2016-08-05 来源:eefocus
关于中断按键:上原理图
外层板子原理图
外设一个一个学 for_ARM interrupt keyboard - KeVen.w - Study Hard And Make
四层板原理图(核心板子)
本板子总共使用了留个按键分别是EINT1~EINT7
所以对应的寄存器是GPH1_1~GPH0_7..
首先来查看芯片手册查看关于GPH0寄存器的descriptor
GPH0,1,2,3: 32 in/out pin –CAM IF channel, Key pad, External Wakeup (up-to 32-bit)
大概意思主要想表达GPHO是可被外部唤醒的.
GPH0CON[7]  [31:28]  0000 = Input, 0001 = Output, 0010 = WU_INT[7]  0000
GPH0CON[6]  [27:24]  0000 = Input, 0001 = Output, 0010 = WU_INT[6]  0000
GPH0CON[5]  [23:20]  0000 = Input, 0001 = Output, 0010 = WU_INT[5]  0000
GPH0CON[4]  [19:16]  0000 = Input, 0001 = Output, 0010 = WU_INT[4]  0000
GPH0CON[3]  [15:12]  0000 = Input, 0001 = Output, 0010 = WU_INT[3]  0000
GPH0CON[2]  [11:8]  0000 = Input, 0001 = Output, 0010 = WU_INT[2]  0000
GPH0CON[1]  [7:4]  0000 = Input, 0001 = Output, 0010 = WU_INT[1]  0000
PAD CONTROL    S5PC100 USER’S MANUAL (REV1.0)
2.2-36
GPH0CON[0]  [3:0]  0000 = Input, 0001 = Output, 0010 = WU_INT[0]  0000
那么我们看看可唤醒中断配置寄存器:
5.6.1 Wakeup Interrupt 0_7 Configuration (WU_INT0_7_CON, R/W, Address = 0xE030_0E00)
The value of WU_INTx_y_CON[n] means that 000 = Low level, 001 = High level, 010 = Falling edge triggered,
011 = Rising edge triggered, 100 = Both edge triggered
意思是唤醒中断配置寄存器
000 为低电平有效 001为高电平有效 010为下降沿触发 011为上升沿触发有效 100为两种沿都可以
在看看可唤醒中断掩码寄存器:
Wakeup Interrupt 0_7 Mask (WU_INT0_7_MASK, R/W, Address = 0xE030_0F00)
The value of FLTENx_y[n] means that 0= disable, 1=enable. The value of FLTSELx_y[n]means that 0 = delay
filter, 1 = digital filter
FLTENx_y[n] 0 为使能关闭 1 为使能打开
FLTSELx_y[n] 0为延迟过滤器 1为数字滤波器
Reserved [31:8]  Reserved
WU_INT0_7_MASK [n]  [n]
Mask for WU_INT[n]
0 = Enabled,1 = Masked (n=0~7)
看完这些寄存器就可以实现按键中断了:
首先了解中断流程:(这里为GPH0)
①:使能引脚的中断方式 --- 也就是上述GPH0CON = GPH0CON & (~(0xf)) | 0x2<<4 <------- >GPH0CON[1]这里暂时用的是key1、根据原理图key1为enter1既为GPH0CON[1]
②:设置中断的触发方式(也就是配置可唤醒中断寄存器)
为WKUP_INT0_7_CON[1]
WKUP_INT0_7_CON = ( WKUP_INT0_7_CON & (~(0x7<<4)))  | (0X2<<4);
设置下降沿触发
010
0111<<4
~11100000 = 0001 1111 | 0010 <<4
0001 1111 | 0010 0000
= 0011 1111
所以4-6位该是011 所以就对了上面共八位是0 – 7
③:使能中断屏蔽寄存器(mask)
WKUP_INT0_7_MASK = WKUP_INT0_7_MASK &(~(0x1<<1)) ;
0010 ~ =0 故0为使能关闭中断。
④:使能VIC关于GPH0中断
VIC0INTERRUPT.VIC0INTENABLE |=1<<1; //从下往上数为第2个所以为1
这里为什么使用VIC0呢、是芯片手册给我们提供的。
⑤:注册中断函数并且实现do_irq函数和中断服务函数并且到最后清除中断位
VIC0VECTADDR.VIC0VECTADDR1 = (unsigned int )key1_int;
void key1_int()
    printf('key1_int\n');
    VIC0ADDRESS =0;
    VIC1ADDRESS =0;
    VIC2ADDRESS =0;
    WKUP_INT0_7_PEND = 1<<1;
/*这是关于等待中断WAKEU_PENDING的描述
*/ Wakeup Interrupt 0_7 Pending (WU_INT0_7_PEND, R/W, Address = 0xE030_0F40)
Field  Bit  Description  Reset Value
Reserved [31:8]  Reserved  0
WU_INT0_7_PEND [n]  [n]
This bit is set if WU_INT [n] is pending.
Writing ‘1’ makes this bit clear. (n=0~7)
Note. Even though WU_INT0_7_MASK [n] is masked, this can be pended.
void do_irq()  /*do_irp函数的实现()*/
    printf('VIC0ADDRESS = %x\n',VIC0ADDRESS );
    ( (  void(*)(void)  )VIC0ADDRESS)();
关于( (  void(*)(void)  )VIC0ADDRESS)();
这其实是一个函数指针的强转。
完全可以理解为void (*)();
这样去理解。
通过上述就可以实现一个按键中断。
printf('keven');
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 开关电源的基本组成及工作原理
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何构建一个触摸传感器电路
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
    相关电子头条文章
