STM32F4的IO设置测试
2016-12-18 来源:eefocus
环境:
主机:WIN7
开发环境:MDK4.72
MCU:STM32F407VGT6
说明:
目标板上有一个LED,有一个按键,按键实现LED状态翻转.
LED:PE2,低电平亮,高电平灯灭
按键:PC13,低电平按下,高电平松开
源代码:
main.c
* 主文件
* (c)copyright 2014,jdh
* All Right Reserved
*新建日期:2014/3/25 by jdh
* 头文件
#include 'main.h'
#include 'stm32f4xx_rcc.h'
#include 'stm32f4xx_gpio.h'
* 全局变量
static __IO uint32_t TimingDelay;
* 函数定义
void Delay(__IO uint32_t nTime);
* 函数
int main(void)
//定义IO初始化结构体
GPIO_InitTypeDef GPIO_InitStructure;
//系统时钟:1ms滴答1次
if (SysTick_Config(SystemCoreClock / 1000))
while (1);
//设置LED的IO口
//初始化时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
//管脚模式:输出口
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
//类型:推挽模式
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
//上拉下拉设置:不使能
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
//IO口速度
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
//管脚指定
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
//初始化
GPIO_Init(GPIOE, &GPIO_InitStructure);
//设置按键的IO口
//初始化时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
//管脚模式:输出口
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
//类型:推挽模式
//上拉下拉设置:不使能
//IO口速度
//管脚指定
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
//初始化
GPIO_Init(GPIOC, &GPIO_InitStructure);
while (1)
//GPIO_SetBits(GPIOE,GPIO_Pin_2);
//Delay(500);
//GPIO_ResetBits(GPIOE,GPIO_Pin_2);
//Delay(500);
//按键检测
if (GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13) == 0)
GPIO_ToggleBits(GPIOE,GPIO_Pin_2);
Delay(500);
* @brief Inserts a delay time.
* @param nTime: specifies the delay time length, in milliseconds.
* @retval None
TimingDelay = nTime;
while(TimingDelay != 0);
* @brief Decrements the TimingDelay variable.
* @param None
* @retval None
void TimingDelay_Decrement(void)
if (TimingDelay != 0x00)
TimingDelay--;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf('Wrong parameters value: file %s on line %d\r\n', file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
上一篇:STM32F103停机模式测试
下一篇:w5100实现dns解析功能
