STM32模拟I2C程序
2018-05-20 来源:eefocus
测试平台:STM32F103ZET6最小系统
static void i2cDelay()
volatile int i = 7;
while (i)
i--;
// SCL高电平期间,SDA出现下降沿为起始信号
static bool i2cStart()
SDA_OUT;
SCL_H;
SDA_H;
i2cDelay();
if (!sdaRead) // 如果SDA为低电平,则总线忙,退出
return false;
SDA_L;
if (sdaRead) // 如果SDA为高电平,则总线忙,退出
return false;
SDA_L;
return true;
// SCL高电平期间,SDA出现上升沿为停止信号
static void i2cStop(void)
SDA_OUT;
SCL_L;
SDA_L;
i2cDelay(); // STOP:when CLK is high DATA from low to high
SCL_H;
SDA_H;
i2cDelay();
static void i2cAck(void)
SDA_OUT;
SCL_L;
i2cDelay();
SDA_L;
i2cDelay();
SCL_H;
i2cDelay();
SCL_L;
static void i2cNoAck(void)
SDA_OUT;
SCL_L;
i2cDelay();
SDA_H;
i2cDelay();
SCL_H;
i2cDelay();
SCL_L;
// SCL高电平期间,SDA电平被从设备拉低表示应答
static bool i2cWaitAck(void)
uint8_t errTimes = 0;
SDA_IN;
SDA_H;
i2cDelay();
SCL_H;
i2cDelay();
while (sdaRead) {
if (errTimes++ > 20) {
SCL_L;
return false;
i2cDelay();
SCL_L;
return true;
// 发送数据,数据从高位到低位传输
static void i2cSendByte(uint8_t byte)
uint8_t i = 8;
SDA_OUT;
while (i--) {
SCL_L; // 时钟信号为低电平期间,允许数据线电平变化
i2cDelay();
if (byte & 0x80)
SDA_H;
else
SDA_L;
byte <<= 1;
i2cDelay();
SCL_H;
i2cDelay();
SCL_L;
static uint8_t i2cReceiveByte()
uint8_t i = 8;
uint8_t byte = 0;
SDA_IN;
SDA_H;
while (i--) {
byte <<= 1;
SCL_H;
i2cDelay();
if (sdaRead) {
byte |= 0x01;
SCL_L;
i2cDelay();
SCL_L;
return byte;
void i2cInit()
GPIO_InitTypeDef GPIO_InitStructure;
/* Enable GPIOB clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
/* Configure GPIOB.6 & GPIOB.7 as open-drain output */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
* 通过I2C总线写一字节数据
* @param[in] dev:设备I2C地址
* @param[in] reg:寄存器地址
* @param[in] data:要写入的数据
bool i2cWriteOneByte(uint8_t dev, uint8_t reg, uint8_t data)
if (!i2cStart())
return false;
i2cSendByte(dev << 1); // 从机地址由高7位+读写位构成
if (!i2cWaitAck()) {
i2cStop();
return false;
i2cSendByte(reg);
i2cWaitAck();
i2cSendByte(data);
i2cWaitAck();
return true;
* @param[in] len:字节数
* @param[in] data:待写入的数据
bool i2cWriteBytes(uint8_t dev, uint8_t reg, uint8_t len, uint8_t *data)
uint8_t i;
if (!i2cStart())
return false;
i2cStop();
return false;
i2cSendByte(dev);
i2cWaitAck();
for (i = 0; i < len; i++) {
i2cSendByte(data[i]);
i2cStop();
return false;
i2cStop();
return true;
* 从I2C设备中读取数据
* @param[in] len:数据字节数
* @param[out] data:读出的数据
bool i2cReadBytes(uint8_t dev, uint8_t reg, uint8_t len, uint8_t *data)
if (!i2cStart())
return false;
i2cStop();
return false;
i2cSendByte(reg);
i2cWaitAck();
i2cStart();
i2cSendByte((dev << 1) | 0x01); // 器件地址+读命令
i2cWaitAck();
while (len) {
*data = i2cReceiveByte();
if (len == 1)
i2cNoAck(); // 最后一个字节不应答
else
i2cAck();
data++;
len--;
i2cStop();
return true;
