单片机
STM32:DMA方式接收SPI总线数据,并按照协议进行处理
2018-06-08 来源:eefocus
一、前言
为满足高速数据传输的要求,采用SPI总线。MCU端(STM32F072  Cortex-M0)接收CPU发送的SPI数据(数据18个字节为一包,起始包为0xAA,最后一包为CheckSum校验),接收完成后,将校验正确的数据分配给RF发送给接收端。
二、硬件电路
如下图所示,SPI部分使用SPI2即PB12 PB13 PB14 PB15
三、程序流程
3.1 SPI初始化
 SPI初始化为从模式,代码如下:
  1. void BSP_SPI2_Init(void)
  2. {   SPI_InitTypeDef  SPI_InitStructure;
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  5.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  6.         /*!< Configure SPI_FLASH_SPI pins: NSS */
  7.         GPIO_InitStructure.GPIO_Pin    = GPIO_Pin_12;
  8.         GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_AF;
  9.         GPIO_InitStructure.GPIO_OType  = GPIO_OType_PP;
  10.         GPIO_InitStructure.GPIO_Speed  = GPIO_Speed_50MHz;
  11.         GPIO_InitStructure.GPIO_PuPd   = GPIO_PuPd_NOPULL;
  12.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  13.         /*!< Configure SPI_FLASH_SPI pins: SCK */
  14.         GPIO_InitStructure.GPIO_Pin    = GPIO_Pin_13;
  15.         GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_AF;
  16.         GPIO_InitStructure.GPIO_OType  = GPIO_OType_PP;
  17.         GPIO_InitStructure.GPIO_Speed  = GPIO_Speed_50MHz;
  18.         GPIO_InitStructure.GPIO_PuPd   = GPIO_PuPd_NOPULL;
  19.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  20.       /*!< Configure SPI_FLASH_SPI pins: MISO */
  21.         GPIO_InitStructure.GPIO_Pin    = GPIO_Pin_14;
  22.         GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_AF;
  23.         GPIO_InitStructure.GPIO_OType  = GPIO_OType_PP;
  24.         GPIO_InitStructure.GPIO_Speed  = GPIO_Speed_50MHz;
  25.         GPIO_InitStructure.GPIO_PuPd   = GPIO_PuPd_NOPULL;
  26.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  27.          /*!< Configure SPI_FLASH_SPI pins: MOSI */
  28.         GPIO_InitStructure.GPIO_Pin    = GPIO_Pin_15;
  29.         GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_AF;
  30.         GPIO_InitStructure.GPIO_OType  = GPIO_OType_PP;
  31.         GPIO_InitStructure.GPIO_Speed  = GPIO_Speed_50MHz;
  32.         GPIO_InitStructure.GPIO_PuPd   = GPIO_PuPd_NOPULL;
  33.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  34.         /*!< PinAFConfig */
  35.         GPIO_PinAFConfig(GPIOB,GPIO_PinSource12,GPIO_AF_0);
  36.     GPIO_PinAFConfig(GPIOB,GPIO_PinSource13,GPIO_AF_0);
  37.     GPIO_PinAFConfig(GPIOB,GPIO_PinSource14,GPIO_AF_0);
  38.     GPIO_PinAFConfig(GPIOB,GPIO_PinSource15,GPIO_AF_0);
  39.     /* Deselect the FLASH: Chip Select high */
  40.     /* SPI2 configuration */
  41.     SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  42.     SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  43.     SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  44.     SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  45.     SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;////
  46.     SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;////
  47.     SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
  48.     SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  49.     SPI_InitStructure.SPI_CRCPolynomial = 7;
  50.     SPI_Init(SPI2, &SPI_InitStructure);
  51.     SPI_RxFIFOThresholdConfig(SPI2, SPI_RxFIFOThreshold_QF);
  52.     SPI_NSSInternalSoftwareConfig(SPI2, SPI_NSSInternalSoft_Reset);
  53.     SPI_NSSPulseModeCmd(SPI2,DISABLE);
  54.     //SPI_I2S_ITConfig(SPI2, SPI_I2S_IT_RXNE, ENABLE);
  55.     /* Configure IT */
  56.     /* Enable SPI2  */
  57.
  58.     SPI_Cmd(SPI2, ENABLE);
  59.
  60.
  61.
  62. }
3.2 DMA初始化
查阅数据手册,SPI2_RX的DMA通道为4,由于需要持续从SPI中获取数据,DMA设置为Circle模式。由于这里SPI接收的数据长度固定为18,所以我们可以把BufferSize也设置为18,这样做的好处是我们不需要去查询DMA传输完成的标志,只需要去查询BUFFER中的数据是否有变化,一旦有变化从头到尾直接Load数据就可以了。当然这样处理只适用于固定长度的数据接收,如果DMA接收的数据不是固定长度的,则需要通过DMA的计数值CNTR这个寄存器的值来比较。
  1. void SPI2_DMA_Init(void)
  2.  {
  3.   DMA_Cmd(DMA1_Channel4, DISABLE);
  4.   DMA_DeInit(DMA1_Channel4);
  5.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  6.   //DMA_InitStructure.DMA_FIFOMode
  7.   DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(SPI2->DR));
  8.   DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)DstBuffer;
  9.   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  10.   DMA_InitStructure.DMA_BufferSize = 18;
  11.   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  12.   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  13.   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  14.   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  15.   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal DMA_Mode_Circular
  16.   DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  17.   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  18.   DMA_Init(DMA1_Channel4, &DMA_InitStructure);
  19.     /* Enable DMA1 Channel1 Transfer Complete interrupt */
  20.   #if 0
  21.     DMA_ITConfig(DMA1_Channel4, DMA_IT_TC, ENABLE);
  22.   /* Enable DMA1 channel4 IRQ Channel */
  23.   NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_5_6_7_IRQn;
  24.   NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
  25.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  26.   NVIC_Init(&NVIC_InitStructure);
  27.     #endif
  28.   SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);//
  29.   /* Enable DMA1 Channel4 transfer */
  30.   DMA_Cmd(DMA1_Channel4, ENABLE);
  31.  }
3.3 数据比较与更新
这部分内容的作用是,循环读取DMABuffer中的数据,如果其中的数据发送变化,表面有新的数据产生,将这个数据取出并进行协议处理,如果没有数据变化,则不进行任何处理。
  1.  /*******************************************************************************
  2. * @Function    : UpdateBuff
  3. * @Description : Compare 2 strings , if different return 1 and Update to Target
  4. * @Input       : buf1 buf2 size
  5. * @Output      : None
  6. * @Return      : None
  7. * @Auth        : Solen           2016/8/30
  8. *******************************************************************************/
  9.  uint8_t UpdateBuff(uint8_t *Src,uint8_t *Taget,uint8_t Size)
  10.  {
  11.      uint8_t Data_Updated = 0;
  12.       for(uint8_t i = 0;i
  13.      {
  14.          if(Src[i]!=Taget[i])
  15.          {
  16.              Taget[i] = Src[i];
  17.              Data_Updated = 1;
  18.          }
  19.      }
  20.      if(Data_Updated == 1)
  21.          return 1;
  22.      else
  23.          return 0;
  24.  }
3.4 协议分析
根据3.3的结果,如果有新数据,则进行协议分析。即以AA为数据头,获取包数据。数据处理结束。
  2. * @Function    : Packet_Align
  3. * @Description : Mainly Used for DBG to certificate SPI - DMA
  4. * @Input       : None
  5. * @Output      : None
  6. * @Return      : None
  9.  void Packet_Align(void)
  10.  {
  11.      static uint8_t Packet_Index = 0;
  12.      static uint8_t Find_Header = 0;
  13.     for(uint8_t i = 0; i < 18 ; i++)
  14.      {
  15.            if(Find_Header == 0) //Need to Find Headerk
  16.              {
  17.                  if(TgtBuffer[i] == 0xAA)
  18.                  {
  19.                      Find_Header = 1;
  20.                      Packet_Index = 0;
  21.                      ThrDimen_Packet_Data[Packet_Index] = 0xAA;
  22.                  }
  23.              }
  24.              else
  25.              {
  26.                     Packet_Index++;
  27.                   ThrDimen_Packet_Data[Packet_Index] = TgtBuffer[i];
  28.                   if(Packet_Index >=17)
  29.                     {
  30.                         Find_Header = 0;
  31.                         Data_Finished = 1;
  32.                     }
  33.              }
  34.      }
  35.  }
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 红外线探测报警器
  • 短波AM发射器电路设计图
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 开关电源的基本组成及工作原理
  • 带有短路保护系统的5V直流稳压电源电路图
    相关电子头条文章
