STM32F407外扩SRAM配置
2018-07-23 来源:eefocus
以下SRAM的程序是在清时代STM32F407开发板上测试通过
开发板PCB完整工程连接:http://www.cirmall.com/circuit/7 ... F%EF%BC%81#/details
淘宝连接:https://item.taobao.com/item.htm?id=557618550100
bsp_SRAM.c文件
#include 'sram.h'
#include 'usart.h'
//本程序只供学习使用,未经作者许可,不得用于其它任何用途
//STM32F407开发板
//外部SRAM 驱动代码
//All rights reserved
//使用NOR/SRAM的 Bank1.sector3,地址位HADDR[27,26]=10
//对IS61LV25616/IS62WV25616,地址线范围为A0~A17
//对IS61LV51216/IS62WV51216,地址线范围为A0~A18
#define Bank1_SRAM3_ADDR ((u32)(0x68000000))
//初始化外部SRAM
void FSMC_SRAM_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef readWriteTiming;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOG, ENABLE);//使能PD,PE,PF,PG时钟
RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);//使能FSMC时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;//PB15 推挽输出,控制背光
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化 //PB15 推挽输出,控制背光
GPIO_InitStructure.GPIO_Pin = (3<<0)|(3<<4)|(0XFF<<8);//PD0,1,4,5,8~15 AF OUT
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化
GPIO_InitStructure.GPIO_Pin = (3<<0)|(0X1FF<<7);//PE0,1,7~15,AF OUT
GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化
GPIO_InitStructure.GPIO_Pin = (0X3F<<0)|(0XF<<12);//PF0~5,12~15
GPIO_Init(GPIOF, &GPIO_InitStructure);//初始化
GPIO_InitStructure.GPIO_Pin =(0X3F<<0)| GPIO_Pin_10;//PG0~5,10
GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化
GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);//PD0,AF12
GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);//PD1,AF12
GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource11,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);//PD15,AF12
GPIO_PinAFConfig(GPIOE,GPIO_PinSource0,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource1,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);//PE7,AF12
GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);//PE15,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource0,GPIO_AF_FSMC);//PF0,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource1,GPIO_AF_FSMC);//PF1,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource2,GPIO_AF_FSMC);//PF2,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource3,GPIO_AF_FSMC);//PF3,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource4,GPIO_AF_FSMC);//PF4,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource5,GPIO_AF_FSMC);//PF5,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource12,GPIO_AF_FSMC);//PF12,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource13,GPIO_AF_FSMC);//PF13,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource14,GPIO_AF_FSMC);//PF14,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource15,GPIO_AF_FSMC);//PF15,AF12
GPIO_PinAFConfig(GPIOG,GPIO_PinSource0,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource1,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource2,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource3,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource4,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource5,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource10,GPIO_AF_FSMC);
readWriteTiming.FSMC_AddressSetupTime = 0x02;//地址建立时间(ADDSET)为1个HCLK 1/36M=27ns
readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到
readWriteTiming.FSMC_DataSetupTime = 0x08; ////数据保持时间(DATAST)为9个HCLK 6*9=54ns
readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
readWriteTiming.FSMC_CLKDivision = 0x00;
readWriteTiming.FSMC_DataLatency = 0x00;
readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;//模式A
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;// 这里我们使用NE3 ,也就对应BTCR[4],[5]。
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM; //SRAM
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;//存储器写使能
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // 读写使用相同的时序
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; //读写同样时序
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); //初始化FSMC配置
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE); // 使能BANK1区域3
bsp_SRAM.h头文件
#ifndef __SRAM_H
#define __SRAM_H
#include 'sys.h'
//STM32开发板
//外部SRAM 驱动代码
void FSMC_SRAM_Init(void);
#endif
SRAM测试函数
#define EXT_SRAM_ADDR ((uint32_t)0x68000000)
#define EXT_SRAM_SIZE (1 * 1024 * 1024)
* 函 数 名: bsp_TestExtSRAM
* 功能说明: 扫描测试外部SRAM
* 形 参: 无
* 返 回 值: 0 表示测试通过; 大于0表示错误单元的个数。
uint8_t bsp_TestExtSRAM(void)
uint32_t i;
uint32_t *pSRAM;
uint8_t *pBytes;
uint32_t err;
const uint8_t ByteBuf[4] = {0x55, 0xA5, 0x5A, 0xAA};
/* 写SRAM */
pSRAM = (uint32_t *)EXT_SRAM_ADDR;
for (i = 0; i < EXT_SRAM_SIZE / 4; i++)
*pSRAM++ = i;
/* 读SRAM */
err = 0;
if (*pSRAM++ != i)
err++;
if (err > 0)
return (4 * err);
#if 0
/* 对SRAM 的数据求反并写入 */
*pSRAM = ~*pSRAM;
pSRAM++;
/* 再次比较SRAM的数据 */
err = 0;
if (*pSRAM++ != (~i))
err++;
if (err > 0)
return (4 * err);
#endif
/* 测试按字节方式访问, 目的是验证 FSMC_NBL0 、 FSMC_NBL1 口线 */
pBytes = (uint8_t *)EXT_SRAM_ADDR;
for (i = 0; i < sizeof(ByteBuf); i++)
*pBytes++ = ByteBuf[i];
/* 比较SRAM的数据 */
err = 0;
if (*pBytes++ != ByteBuf[i])
err++;
if (err > 0)
return err;
return 0;
多次复位,多次测试后稳定正常测试通过
在GUI上电应用只要传入地址即可
