单片机
STM32L0低功耗设计5: STOP_RTC模式的真实功耗
2018-09-10 来源:eefocus
    本例程测试STOP_RTC模式的真实功耗,主程序如下:
int main(void)
while(1)
    HAL_Delay(5000);
Target.HAL.Rtc.EnterStopRtcMode();
Target.HAL.SystemClock.SetMode(2);
    系统进入主循环后,先进行5秒延时,然后进入低功耗模式,低功耗模式设置的RTC时间为4秒,4秒过后退出低功耗模式,重新进行时钟设置。
    在进入main函数之前,执行了3个操作:时钟设置、低功耗设置和RTC设置,如下面程序:
class CHAL
public:
CSystemClock SystemClock;
CSystemLowPower SystemLowPower;
CRtc Rtc;
    时钟设置相关程序如下:
void CClock::SetMode(uint8_t mode)
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInit;
__HAL_RCC_PWR_CLK_ENABLE();
if (mode  == 0)
//Configure the main internal regulator output voltage
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
//Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_8;
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_3;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Target.ErrorHandler(__FILE__, __LINE__);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
PeriphClkInit.Usart2ClockSelection = RCC_USART2CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
//Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
//SysTick_IRQn interrupt configuration
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
else if (mode  == 1)
|RCC_PERIPHCLK_USB;
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL;
else if (mode == 2)
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI | RCC_OSCILLATORTYPE_HSE | RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 0x10; //HSIÐÞÕýÖµ
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2|RCC_PERIPHCLK_RTC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
    低功耗设置相关程序如下:
CLowPower::CLowPower(uint8_t mode)
if (mode == 1)
GPIO_InitTypeDef GPIO_InitStructure;
HAL_PWREx_EnableUltraLowPower(); //ʹÄܳ¬µÍ¹¦ºÄ
    HAL_PWREx_EnableFastWakeUp(); //ʹÄÜ¿ìËÙ»½ÐÑ
__HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI); //½«HSIʱÖÓ×÷Ϊ»½ÐѺóµÄÖ÷ʱÖÓ
//½«ËùÓÐÒý½Å¶¼ÅäÖÃΪģÄâÊäÈëģʽ
    __HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
GPIO_InitStructure.Pin = GPIO_PIN_All;
GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
GPIO_InitStructure.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
__HAL_RCC_GPIOA_CLK_DISABLE();
__HAL_RCC_GPIOB_CLK_DISABLE();
__HAL_RCC_GPIOC_CLK_DISABLE();
__HAL_RCC_GPIOD_CLK_DISABLE();
__HAL_RCC_GPIOH_CLK_DISABLE();
    RTC设置相关程序如下:
CRtc::CRtc(void)
  this->hRTC.Instance = RTC;
pRTC = &this->hRTC;
this->hRTC.Init.HourFormat = RTC_HOURFORMAT_24;
this->hRTC.Init.AsynchPrediv = 124;
this->hRTC.Init.SynchPrediv = 295;
this->hRTC.Init.OutPut = RTC_OUTPUT_DISABLE;
this->hRTC.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE; //²»½øÐÐÊä³öÒý½ÅÖØÓ³Éä
this->hRTC.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
this->hRTC.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&this->hRTC) != HAL_OK)
    程序运行后,5秒为正常功耗,4秒为低功耗,测得实际功耗2.4uA,手册中指出的STOP_RTC模式为1uA,产生差错的原因在《STM32L0低功耗设计3: Stop模式下的真实功耗》中已经介绍过,2.4uA已经能够满足项目本身的设计了,还算不错。
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 红外线探测报警器
  • 短波AM发射器电路设计图
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
