单片机
基于STM32的MS5540c压强温度传感器的应用
2018-10-15 来源:eefocus
3.5的库函数,stm32f10x系列的mcu,网上这个芯片的实例较少,而官方的代码an510这个文档找不到下载,datasheet写的也不甚明了。下面贴上我的基本程序给大家一个参考:
#include 'main.h'
#include 'Flash_LED.h'
#include 'SPI_MS5540C.h'
#include 'SysTick.h'
vu32 led_timer = 0;
extern vu32 global_timer;
uint8_t detect_timer=0;
vu16 var_D1=0,var_D2=0;
int main()
 SystemInit();
 NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3); //8 preemption priority
  Init_Flash_LED();
 Init_SPI_Device_Clk();
 Init_SPI_Device();
 Compute_Para();
 while(1)
  if(((global_timer > led_timer) && (global_timer - led_timer  >= 200))||((global_timer < led_timer) && (0xffffffff - led_timer + global_timer >= 200)))
          toggle_led();
          led_timer=global_timer;
         detect_timer++;
    SPI_Control_Byte(0);
  Delay_ms(20);
  SPI_Control_Byte(1);
  Delay_ms(100);
  var_D1=SPI_Read();
  Delay_ms(20);
  SPI_Control_Byte(2);
  Delay_ms(100);
  var_D2=SPI_Read();
  Compute_value(var_D1,var_D2);
    //while(1);
时间来不及仔细整理,spi_ms5540c.c  如下,头文件里面就是些声明就不写了 另外main函数里面用到的延时是随便写的,官方datasheet是33ms的转换时间
uint16_t Control_D1=0x0f40;//0x03d0 // pressure conversion control_words
uint16_t Control_D2=0x0f20;//0x03c8 // temperature conversion control_words
uint16_t Control_read_word1=0x1d50;//0x0ea8;//
uint16_t Control_read_word2=0x1d60;//0x0eb0;//
uint16_t Control_read_word3=0x1d90;//0x0ec8;//
uint16_t Control_read_word4=0x1da0;//0x0ed0;//
uint16_t Control_Reset1=0x0015;  //the funtion 'SPI_I2S_SendData' only could supply 8bit or 16bit send,and the chip ms5540c could start up with three high bits
uint16_t Control_Reset2=0x5540;
uint16_t Blank=0x9249;//1001 0010 0100 1001 send it to read the coversion result and avoid the wrong operation
vu16 pressure_value=0,temp_value=0;
vu16 para_C1=0,para_C2=0,para_C3=0,para_C4=0,para_C5=0,para_C6=0;
vu16 data1=0,data2=0,data3=0,data4=0;
void Init_SPI_Device(void)
   SPI_InitTypeDef SPI_InitStructure;
   GPIO_InitTypeDef GPIO_InitStructure;
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1|RCC_APB2Periph_GPIOA,ENABLE);//??SP1I?GPIOA??
   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//MOSI SCK??
   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;//??????
   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
   GPIO_Init(GPIOA,&GPIO_InitStructure);
   //GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4;//SPI_CS
   //GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;//????
   //GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
   //GPIO_Init(GPIOA,&GPIO_InitStructure);
   SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;//??SPI???????????:SPI??????????
   SPI_InitStructure.SPI_Mode=SPI_Mode_Master;//??SPI????:????SPI
   SPI_InitStructure.SPI_DataSize=SPI_DataSize_16b;//??SPI?????:SPI????8????
   SPI_InitStructure.SPI_CPOL=SPI_CPOL_Low; //??????????:?????
   SPI_InitStructure.SPI_CPHA=SPI_CPHA_1Edge;//???????????
   SPI_InitStructure.SPI_NSS=SPI_NSS_Soft;//SPI_NSS_Soft;//NSS?????(NSS??)????(??SSI?)??:??NSS???SSI???
   SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_256;  //??????????:????????256
   SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB; //???????MSB???LSB???:?????MSB???
   //SPI_InitStructure.SPI_CRCPolynomial=7;//CRC???????
   SPI_Init(SPI1,&SPI_InitStructure);//??SPI_InitStruct???????????SPIx???
   SPI_Cmd(SPI1,ENABLE);//??SPI??
void SPI_Control_Byte(u8 xx)
  SPI_Cmd(SPI1,DISABLE);
   //SPI_InitStructure.SPI_CPHA=SPI_CPHA_2Edge;//???????????
 if(xx==0)
  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
    SPI_I2S_SendData(SPI1, Control_Reset1);
   while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
    SPI_I2S_ReceiveData(SPI1);
    SPI_I2S_SendData(SPI1, Control_Reset2);
if(xx==1)
  while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE)==RESET);
    SPI_I2S_SendData(SPI1, Control_D1);
if(xx==2)
  while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
    SPI_I2S_SendData(SPI1, Control_D2);
if(xx==11)
    SPI_I2S_SendData(SPI1,Control_read_word1);
if(xx==12)
    SPI_I2S_SendData(SPI1,Control_read_word2);
if(xx==13)
    SPI_I2S_SendData(SPI1, Control_read_word3);
if(xx==14)
    SPI_I2S_SendData(SPI1, Control_read_word4);
uint16_t SPI_Read(void)
//    SPI_InitTypeDef SPI_InitStructure;
//  SPI_Cmd(SPI1,DISABLE);
 //  SPI_InitStructure.SPI_CPHA=SPI_CPHA_2Edge;//???????????
  // SPI_Init(SPI1,&SPI_InitStructure);//??SPI_InitStruct???????????SPIx???
  // SPI_Cmd(SPI1,ENABLE);//??SPI??
// vu8 data1 = 0;
// vu8 data2 = 0;
 SPI_I2S_SendData(SPI1, Blank);
  return SPI_I2S_ReceiveData(SPI1);
u16 Read_Factory_words(void)
// vu8 data1 = 0;
// vu8 data2 = 0;
void TIM2_GPIO_Config(void)
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);      //enable the TIM2 CLK
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);    // enable the GPIOa CLK
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_3 ;   //TIM2 CH4
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  //GPIO_PinRemapConfig(GPIO_FullRemap_TIM4, ENABLE);  // if use the remap ,afio is need
  //GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
  //GPIO_Init(GPIOB, &GPIO_InitStructure);
void TIM2_Mode_Config(u16 CCR4_Val)
 TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
 TIM_OCInitTypeDef  TIM_OCInitStructure;
  TIM_TimeBaseStructure.TIM_Period = 2197;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;     //the PWM period is 20Hz
  TIM_TimeBaseStructure.TIM_ClockDivision =0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
 // PWM1 Mode configuration: Channel4
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR4_Val;   //????4??????,??????????PWM
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);   //????4
  TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM2, ENABLE);    // ??TIM4?????ARR
  // TIM4 enable counter
   TIM_Cmd(TIM2, ENABLE);                   //?????4
void Init_SPI_Device_Clk(void)
  TIM2_GPIO_Config();
  TIM2_Mode_Config(1099);
void Compute_Para(void)
 u16 tmp=0;
   //SPI_Control_Byte(0);
  // Delay_ms(100);
   //Temperature_Value=SPI_Read();
  SPI_Control_Byte(11);
  //Delay_ms(1000);
  data1=SPI_Read();
   SPI_Control_Byte(12);
   //Delay_ms(1000);
  data2=SPI_Read();
  SPI_Control_Byte(13);
  //Delay_ms(1000);
  data3=SPI_Read();
  SPI_Control_Byte(14);
  //Delay_ms(1000);
  data4=SPI_Read();
  Delay_ms(20);
    tmp=data1&0xfffe;
    para_C1=tmp>>1;
    tmp=data3&0x003f;
    para_C2=tmp<<6;
    tmp=data4&0x003f;
    para_C2+=tmp;
    tmp=data4&0xffc0;
    para_C3=tmp>>6;
    tmp=data3&0xffc0;
    para_C4=tmp>>6;
    tmp=data1&0x0001;
    para_C5=tmp<<10;
    tmp=data2&0xffc0;
    para_C5+=tmp>>6;
    para_C6=data2&0x003f;
void Compute_value(u16 var_d1,u16 var_d2)
  double var_dt,var_x,var_off,var_sense,temp_value1,pressure_value1,var_t2,var_p2;
  var_dt=var_d2-20224-8*para_C5;
  var_off=para_C2*4+(para_C4-512)*var_dt/4096;
  var_sense=para_C1+para_C3*var_dt/1024+24576;
  var_x=var_sense*(var_d1-7168)/16384-var_off;
  temp_value1=(var_dt*(para_C6+50)/1024+200);
  pressure_value1=(var_x*10/32+2500);
 if(temp_value1<200)
   var_t2=11*(para_C6+24)*(200-temp_value1)*(200-temp_value1)/1048576;
   var_p2=3*var_t2*(pressure_value1-3500)/16384;
 else if(temp_value1>450)
   var_t2=3*(para_C6+24)*(450-temp_value1)*(450-temp_value1)/1048576;
  var_p2=2*var_t2*(pressure_value1-10000)/16384;
 else
   var_t2=0;
   var_p2=0;
 temp_value=(int)(temp_value1-var_t2);
  pressure_value=(int)(pressure_value1-var_p2);
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 短波AM发射器电路设计图
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
