单片机
S3c2410裸板程序入门---串口
2019-12-24 来源:elecfans
流水灯跑起来了,是不是有点小兴奋,一鼓作气再来玩玩其他的,用PC机写程序,出了问题可以用perror等打印出信息,给调试带来了很大方便,可是板子上没有显示屏,没法打印怎么办?这次就写一个通过串口向PC机串口调试终端打印信息的小程序,方便以后的调试。串口通信的基本知识就不说了哈,网上很多的,直接上代码:
uart.c
 1 #include 's3c2410.h'
 3 void uart_sendchar(char a)
 4 {
 5     if(a == 'n'){
 6         while( !(UTRSTAT0 & (0x1<<2)) );
 7         UTXH0 = 'r';
 8     }
 9     while( !(UTRSTAT0 & (0x1<<2)) );
10     UTXH0 = a;
11 }
13 void sendstring(const char *str)
14 {
15     while(*str){
16         uart_sendchar(*str);
17         str++;
18     }
19 }
21 void uart_init()
22 {
23     GPHCON = (GPHCON & ~(0xf<<4)) | (0xa<<4);
24
25     ULCON0 = 0x3;
26     UCON0 = 0x5;
27
28     UBRDIV0 = (int)(PCLK/(115200*16)) - 1;
29
30 }
GPHCON配置使用串口0, ULCON0 = 0X3配置串口使用8位数据位,一位停止位,无校验,UCON0 = 0X5设置传输模式,默认时钟使用PCLK。UTXH0为发送buffer, 往其中写数据后发送,UTRSTAT0检测数据线上有无数据,从而控制在一个字符发送完成后再发下一个。
还有注意n的处理,因为windows的回车是rn,所以有单独的判断。
哦,你可能会问这个s3c2410.h在哪里,哦,这个其实是板子带的,就是定义了一堆寄存器地址,完全也可以自己定义。向这种格式:
s3c2410.h
 1 /* WOTCH DOG register */
 2 #define     WTCON       (*(volatile unsigned long *)0x53000000)
 3 #define     WTDAT       (*(volatile unsigned long *)0x53000004)
 4 #define     WTCNT       (*(volatile unsigned long *)0x53000008)
39 /*UART registers*/
40 #define ULCON0      (*(volatile unsigned long *)0x50000000)
41 #define UCON0       (*(volatile unsigned long *)0x50000004)
42 #define UFCON0      (*(volatile unsigned long *)0x50000008)
43 #define UMCON0      (*(volatile unsigned long *)0x5000000c)
44 #define UTRSTAT0    (*(volatile unsigned long *)0x50000010)
45 #define UTXH0       (*(volatile unsigned char *)0x50000020)
46 #define URXH0       (*(volatile unsigned char *)0x50000024)
47 #define UBRDIV0     (*(volatile unsigned long *)0x50000028)
48
49
50 /*interrupt registes*/
51 #define SRCPND      (*(volatile unsigned long *)0x4A000000)
52 #define INTMOD      (*(volatile unsigned long *)0x4A000004)
53 #define INTMSK      (*(volatile unsigned long *)0x4A000008)
54 #define PRIORITY        (*(volatile unsigned long *)0x4A00000c)
55 #define INTPND      (*(volatile unsigned long *)0x4A000010)
56 #define INTOFFSET       (*(volatile unsigned long *)0x4A000014)
57 #define SUBSRCPND       (*(volatile unsigned long *)0x4A000018)
58 #define INTSUBMSK       (*(volatile unsigned long *)0x4A00001c)
59
60 /*external interrupt registers*/
61 #define EINTMASK        (*(volatile unsigned long *)0x560000a4)
62 #define EINTPEND        (*(volatile unsigned long *)0x560000a8)
63
64 #define EXTINT2     (*(volatile unsigned long *)0x56000090)
65
66 /*clock registers*/
67 #define LOCKTIME        (*(volatile unsigned long *)0x4c000000)
68 #define MPLLCON     (*(volatile unsigned long *)0x4c000004)
69 #define UPLLCON     (*(volatile unsigned long *)0x4c000008)
70 #define CLKCON      (*(volatile unsigned long *)0x4c00000c)
71 #define CLKSLOW     (*(volatile unsigned long *)0x4c000010)
72 #define CLKDIVN     (*(volatile unsigned long *)0x4c000014)
73
74
75 /*PWM & Timer registers*/
76 #define TCFG0       (*(volatile unsigned long *)0x51000000)
77 #define TCFG1       (*(volatile unsigned long *)0x51000004)
78 #define TCON        (*(volatile unsigned long *)0x51000008)
79 #define TCNTB0      (*(volatile unsigned long *)0x5100000c)
80 #define TCMPB0      (*(volatile unsigned long *)0x51000010)
81 #define TCNTO0      (*(volatile unsigned long *)0x51000014)
82 /* frequecy */
^M
83 #define FCLK        (202800000)
84 #define HCLK        (FCLK/2)
85 #define PCLK        (FCLK/4)
注意要用volatile 和 unsigned 来保证优化和移位不会处差错。
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • CCD图像传感器在微光电视系统中的应用
  • 离子检测器电路分析
  • 一个简单的立体声平衡指示器电路
  • 分享一个电网倾角计电路
  • 电谐波图形均衡器示意图
  • 一种构建12V和230V双直流电源的简单方法
    相关电子头条文章
