s3c2440之按键中断驱动
2022-10-25 来源:csdn
前言
本文记录的是S3C2440按键中断驱动程序,在查询方式按键驱动程序基础下修改。
一、代码
1.按键中断驱动程序
key_drv.c代码如下(示例):
#include #include #include #include #include #include #include #include #include #include #include static struct class *keydrv_class; static struct class_device *keydrv_class_dev; volatile unsigned long *GPFCON; volatile unsigned long *GPFDAT; volatile unsigned long *GPGCON; volatile unsigned long *GPGDAT; static DECLARE_WAIT_QUEUE_HEAD(button_waitq); /* 中断事件标志, 中断服务程序将它置1,third_drv_read将它清0 */ static volatile int ev_press = 0; struct pin_desc { unsigned int pin; unsigned int key_val; }; static unsigned char key_val; /* 键值: 按下时:0x01, 0x02, 0x03, 0x04 */ /* 键值: 松开时:0x81, 0x82, 0x83, 0x84 */ struct pin_desc pins_desc[4] = { {S3C2410_GPF0, 0x01}, {S3C2410_GPF2, 0x02}, {S3C2410_GPG3, 0x03}, {S3C2410_GPG11, 0x04}, }; static irqreturn_t buttons_irq(int irq, void *dev_id) { struct pin_desc * pindesc = (struct pin_desc *)dev_id; unsigned int pinval; pinval = s3c2410_gpio_getpin(pindesc->pin); if(pinval){ /* 松开 */ key_val = 0x80 | pindesc->key_val; } else { /* 按下 */ key_val = pindesc->key_val; } ev_press = 1; /* 表示中断发生了 */ wake_up_interruptible(&button_waitq); /* 唤醒休眠的进程 */ return IRQ_RETVAL(IRQ_HANDLED); } static int key_drv_open(struct inode* inode, struct file *file){ /* 配置 GPF0,GPF2为输入引脚(置0) */ /* 配置 GPG3,GPG11为输入引脚(置0) */ request_irq(IRQ_EINT0, buttons_irq, IRQT_BOTHEDGE, 'S2', &pins_desc[0]); request_irq(IRQ_EINT2, buttons_irq, IRQT_BOTHEDGE, 'S3', &pins_desc[1]); request_irq(IRQ_EINT11, buttons_irq, IRQT_BOTHEDGE, 'S4', &pins_desc[2]); request_irq(IRQ_EINT19, buttons_irq, IRQT_BOTHEDGE, 'S5', &pins_desc[3]); return 0; } static ssize_t key_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos) { if(size != 1) { return -EINVAL; } /* 如果没有按键动作, 休眠 */ wait_event_interruptible(button_waitq, ev_press); /* 如果有按键动作, 返回键值 */ copy_to_user(buf, &key_val, 1); ev_press = 0; return 1; } int key_drv_close (struct inode* inode, struct file *file) { free_irq(IRQ_EINT0, &pins_desc[0]); free_irq(IRQ_EINT2, &pins_desc[1]); free_irq(IRQ_EINT11, &pins_desc[2]); free_irq(IRQ_EINT19, &pins_desc[3]); return 0; } static struct file_operations key_drv_fops = { .owner = THIS_MODULE, .open = key_drv_open, .read = key_drv_read, .release = key_drv_close, }; int major; static int key_drv_init(void) { major = register_chrdev(0, 'key_drv', &key_drv_fops); //注册驱动程序,告诉内核 keydrv_class = class_create(THIS_MODULE, 'key_drv'); keydrv_class_dev = class_device_create(keydrv_class, NULL, MKDEV(major, 0), NULL, 'buttons'); /* /dev/buttons */ GPFCON = (volatile unsigned long *)ioremap(0x56000050, 16); //物理地址映射成虚拟地址 GPFDAT = GPFCON + 1; GPGCON = (volatile unsigned long *)ioremap(0x56000060, 16); //物理地址映射成虚拟地址 GPGDAT = GPGCON + 1; return 0; } static void key_drv_exit(void) { unregister_chrdev(major, 'key_drv'); //卸载驱动 class_device_unregister(keydrv_class_dev); class_destroy(keydrv_class); iounmap(GPFCON); //解除映射关系 iounmap(GPGCON); //解除映射关系 } module_init(key_drv_init); module_exit(key_drv_exit); MODULE_LICENSE('GPL'); //让linux识别定义的类 2.测试程序 keydrvtest.c代码如下(示例): #include #include #include #include /* keydrvtest */ int main(int argc, char **argv) { int fd; unsigned char key_val; fd = open('/dev/buttons', O_RDWR); if (fd < 0) { printf('can't open!n'); } while (1) { read(fd, &key_val, 1); printf('key_val = 0x%xn', key_val); //sleep(5); } return 0; } 3.Makefile keydrvtest.c代码如下(示例): KERN_DIR = /home/book/work/system/linux-2.6.22.6 all: make -C $(KERN_DIR) M=`pwd` modules clean: make -C $(KERN_DIR) M=`pwd` modules clean rm -rf modules.order obj-m += key_drv.o 二、结果显示
上一篇:JZ2440挂载nfs
下一篇:s3c2440之外部中断
