【改进】IMX257实现GPIO-IRQ中断按键获取键值驱动程序
2024-08-16 来源:cnblogs
一、使用struct pin_desc 管理按键的值
1.定义结构体
2.将前面我们申请中断时写的(void *)1修改为 &pins_desc[n]
在ioctl中,设置中断中修改
在key_release中释放中修改
3.在中断程序中利用我们定义的struc pins_desc判断并得到按键的值
4.得到按键键值后,唤醒程序,在read函数中返回键值
附上驱动源程序:
1 /******************************
2 linux key_query
3 *****************************/
4 #include 5 #include 6 #include 7 #include 8 #include 9 #include 10 #include 11 #include 12 #include 13 #include 14 #include 15 #include 16 #include 17 #include 18 19 #include 'mx257_gpio.h' 20 #include 'mx25_pins.h' 21 #include 'iomux.h' 22 23 #define Driver_NAME 'key_interrupt' 24 #define DEVICE_NAME 'key_interrupt' 25 26 #define GPIO2_21 MX25_PIN_CLKO 27 #define GPIO3_15 MX25_PIN_EXT_ARMCLK 28 #define GPIO2_10 MX25_PIN_A24 29 #define GPIO2_11 MX25_PIN_A25 30 #define GPIO2_8 MX25_PIN_A22 31 #define GPIO2_9 MX25_PIN_A23 32 #define GPIO2_6 MX25_PIN_A20 33 #define GPIO2_7 MX25_PIN_A21 34 //command 35 #define key_input 0 36 #define version 1 37 //定义各个按键按下的键值 38 struct pin_desc{ 39 unsigned int pin; 40 unsigned int key_val; 41 }; 42 //当按键按下时,键值分别为 以下值 43 struct pin_desc pins_desc[8] = { 44 {GPIO2_6, 0x01}, 45 {GPIO2_7, 0x02}, 46 {GPIO2_8, 0x03}, 47 {GPIO2_9, 0x04}, 48 {GPIO2_10, 0x05}, 49 {GPIO2_11, 0x06}, 50 {GPIO2_21, 0x07}, 51 {GPIO3_15, 0x08}, 52 }; 53 //定义一个全局变量,用于保存按下的键值 54 static unsigned int key_val; 55 56 //interrupt head 57 static DECLARE_WAIT_QUEUE_HEAD(key_interrupt_wait); 58 static volatile unsigned char ev_press; 59 60 static int major=0; 61 62 //auto to create device node 63 static struct class *drv_class = NULL; 64 static struct class_device *drv_class_dev = NULL; 65 66 67 /* 应用程序对设备文件/dev/key_query执行open(...)时, 68 * 就会调用key_open函数*/ 69 static int key_open(struct inode *inode, struct file *file) 70 { 71 printk('<0>function open!nn'); 72 73 return 0; 74 } 75 76 /* 中断程序key_irq */ 77 static irqreturn_t key_irq(int irq, void *dev_id) 78 { 79 struct pin_desc * pindesc = (struct pin_desc *)dev_id; 80 //发生了中断 81 //printk('<0>function interrupt key_irq!nn'); 82 //获取按键键值 83 if(gpio_get_value(IOMUX_TO_GPIO(pindesc->pin))){ 84 /* 按下 */ 85 key_val = pindesc->key_val; 86 }else{ 87 key_val = 0x80 | pindesc->key_val; 88 } 89 printk('<0>get key 0x%x',key_val); 90 ev_press = 1; 91 wake_up_interruptible(&key_interrupt_wait); 92 93 return IRQ_RETVAL(IRQ_HANDLED); 94 } 95 96 97 static int key_read(struct file *filp, char __user *buff, size_t count, loff_t *offp) 98 { 99 int ret; 100 //如果按键没有按下,没有中断,休眠 101 wait_event_interruptible(key_interrupt_wait,ev_press); 102 103 ret = copy_to_user(buff,&key_val,sizeof(key_val)); 104 if(ret){ 105 ; 106 } 107 ev_press = 0; 108 return sizeof(key_val); 109 110 //int cnt=0; 111 //unsigned char key_vals[8]; 112 113 /* 114 // reading the pins value 115 key_vals[0] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_6)) ? 1 : 0; 116 key_vals[1] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_7)) ? 1 : 0; 117 key_vals[2] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_8)) ? 1 : 0; 118 key_vals[3] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_9)) ? 1 : 0; 119 key_vals[4] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_10)) ? 1 : 0; 120 key_vals[5] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_11)) ? 1 : 0; 121 key_vals[6] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_21)) ? 1 : 0; 122 key_vals[7] = gpio_get_value(IOMUX_TO_GPIO(GPIO3_15)) ? 1 : 0; 123 124 //printk('<0>%04d key pressed: %d %d %d %d %d %d %d %dn',cnt++,key_vals[0],key_vals[1],key_vals[2],key_vals[3],key_vals[4],key_vals[5],key_vals[6],key_vals[7]); 125 */ 126 } 127 128 static ssize_t key_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos) 129 { 130 printk('<0>function write!nn'); 131 132 return 1; 133 } 134 135 static int key_release(struct inode *inode, struct file *filp) 136 { 137 printk('<0>function release!nn'); 138 //释放中断 139 free_irq(IOMUX_TO_IRQ(GPIO2_21), &pins_desc[6]); 140 //free_irq(IOMUX_TO_IRQ(GPIO3_15),&pins_desc[7]); 141 free_irq(IOMUX_TO_IRQ(GPIO2_11), &pins_desc[5]); 142 free_irq(IOMUX_TO_IRQ(GPIO2_10), &pins_desc[4]); 143 free_irq(IOMUX_TO_IRQ(GPIO2_9), &pins_desc[3]); 144 //free_irq(IOMUX_TO_IRQ(GPIO2_8), &pins_desc[2]); 145 free_irq(IOMUX_TO_IRQ(GPIO2_7), &pins_desc[1]); 146 free_irq(IOMUX_TO_IRQ(GPIO2_6), &pins_desc[0]); 147 return 0; 148 } 149 150 static int key_ioctl(struct inode *inode,struct file *flip,unsigned int command,unsigned long arg) 151 { 152 int ret; 153 printk('<0>function ioctl!nn'); 154 switch (command) { 155 case key_input: 156 //设置所有的引脚为输入 157 gpio_direction_input(IOMUX_TO_GPIO(GPIO2_21)); 158 gpio_direction_input(IOMUX_TO_GPIO(GPIO3_15)); 159 gpio_direction_input(IOMUX_TO_GPIO(GPIO2_10)); 160 gpio_direction_input(IOMUX_TO_GPIO(GPIO2_11)); 161 gpio_direction_input(IOMUX_TO_GPIO(GPIO2_8)); 162 gpio_direction_input(IOMUX_TO_GPIO(GPIO2_9)); 163 gpio_direction_input(IOMUX_TO_GPIO(GPIO2_6)); 164 gpio_direction_input(IOMUX_TO_GPIO(GPIO2_7)); 165 printk('<0>have setting all pins to gpio input mod !n'); 166 //设置GPIO引脚为上拉模式 167 mxc_iomux_set_pad(GPIO2_6, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 168 mxc_iomux_set_pad(GPIO2_7, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 169 //mxc_iomux_set_pad(GPIO2_8, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 170 mxc_iomux_set_pad(GPIO2_9, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 171 mxc_iomux_set_pad(GPIO2_10, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 172 mxc_iomux_set_pad(GPIO2_11, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 173 mxc_iomux_set_pad(GPIO2_21, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 174 //mxc_iomux_set_pad(GPIO3_15, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU); 175 176 //设置GPIO引脚中断 ,下降沿触发 177 request_irq(IOMUX_TO_IRQ(GPIO2_6), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_6', &pins_desc[0]); 178 request_irq(IOMUX_TO_IRQ(GPIO2_7), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_7', &pins_desc[1]); 179 request_irq(IOMUX_TO_IRQ(GPIO2_9), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_9', &pins_desc[3]); 180 request_irq(IOMUX_TO_IRQ(GPIO2_10), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_10', &pins_desc[4]); 181 request_irq(IOMUX_TO_IRQ(GPIO2_11), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_11', &pins_desc[5]); 182 request_irq(IOMUX_TO_IRQ(GPIO2_21), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_21', &pins_desc[6]); 183 //request_irq(IOMUX_TO_IRQ(GPIO3_15), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO3_15', &pins_desc[7]); 184 //request_irq(IOMUX_TO_IRQ(GPIO2_8), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_8', &pins_desc[2]); 185 printk('<0>have setting all pins to gpio interrupt mod by IRQF_TRIGGER_FALLING !n'); 186 187 break; 188 case version: 189 printk('<0>hello,the version is 0.1.0nn'); 190 break; 191 default: 192 printk('<0>command error n'); 193 printk('<0>ioctl(fd, (unsigned int)command, (unsigned long) arg;n'); 194 printk('<0>command: 195 return -1; 196 } 197 return 0; 198 } 199 200 /* 这个结构是字符设备驱动程序的核心 201 * 当应用程序操作设备文件时所调用的open、read、write等函数, 202 * 最终会调用这个结构中指定的对应函数 203 */ 204 static struct file_operations key_fops = { 205 .owner = THIS_MODULE, /* 这是一个宏,推向编译模块时自动创建的__this_module变量 */ 206 .open = key_open, 207 .read = key_read, 208 .write = key_write, 209 .release= key_release, 210 .ioctl = key_ioctl, 211 }; 212 213 /* 214 * 执行insmod命令时就会调用这个函数 215 */ 216 static int __init key_irq_init(void) 217 { 218 printk('<0>nHello,this is %s module!nn',Driver_NAME); 219 //register and mknod 220 major = register_chrdev(0,Driver_NAME,&key_fops); 221 drv_class = class_create(THIS_MODULE,Driver_NAME); 222 drv_class_dev = device_create(drv_class,NULL,MKDEV(major,0),NULL,DEVICE_NAME); /*/dev/key_query*/ 223 224 //set all pins to GPIO mod ALF5 225 mxc_request_iomux(GPIO2_21, MUX_CONFIG_ALT5); 226 mxc_request_iomux(GPIO3_15, MUX_CONFIG_ALT5); 227 mxc_request_iomux(GPIO2_10, MUX_CONFIG_ALT5); 228 mxc_request_iomux(GPIO2_11, MUX_CONFIG_ALT5); 229 mxc_request_iomux(GPIO2_8, MUX_CONFIG_ALT5); 230 mxc_request_iomux(GPIO2_9, MUX_CONFIG_ALT5); 231 mxc_request_iomux(GPIO2_6, MUX_CONFIG_ALT5); 232 mxc_request_iomux(GPIO2_7, MUX_CONFIG_ALT5); 233 //request IOMUX GPIO 234 gpio_request(IOMUX_TO_GPIO(GPIO2_21), 'GPIO2_21'); 235 gpio_request(IOMUX_TO_GPIO(GPIO3_15), 'GPIO3_15'); 236 gpio_request(IOMUX_TO_GPIO(GPIO2_10), 'GPIO2_10'); 237 gpio_request(IOMUX_TO_GPIO(GPIO2_11), 'GPIO2_11'); 238 gpio_request(IOMUX_TO_GPIO(GPIO2_8), 'GPIO2_8'); 239 gpio_request(IOMUX_TO_GPIO(GPIO2_9), 'GPIO2_9'); 240 gpio_request(IOMUX_TO_GPIO(GPIO2_6), 'GPIO2_6'); 241 gpio_request(IOMUX_TO_GPIO(GPIO2_7), 'GPIO2_7'); 242 243 return 0; 244 } 245 246 /* 247 * 执行rmmod命令时就会调用这个函数 248 */ 249 static void __exit key_irq_exit(void) 250 { 251 printk('<0>nGoodbye,%s!nn',Driver_NAME); 252 253 unregister_chrdev(major,Driver_NAME); 254 device_unregister(drv_class_dev); 255 class_destroy(drv_class); 256 257 /* free gpios */ 258 mxc_free_iomux(GPIO2_21, MUX_CONFIG_ALT5); 259 mxc_free_iomux(GPIO3_15, MUX_CONFIG_ALT5); 260 mxc_free_iomux(GPIO2_10, MUX_CONFIG_ALT5); 261 mxc_free_iomux(GPIO2_11, MUX_CONFIG_ALT5); 262 mxc_free_iomux(GPIO2_8, MUX_CONFIG_ALT5); 263 mxc_free_iomux(GPIO2_9, MUX_CONFIG_ALT5); 264 mxc_free_iomux(GPIO2_6, MUX_CONFIG_ALT5); 265 mxc_free_iomux(GPIO2_7, MUX_CONFIG_ALT5); 266 267 gpio_free(IOMUX_TO_GPIO(GPIO2_21)); 268 gpio_free(IOMUX_TO_GPIO(GPIO3_15)); 269 gpio_free(IOMUX_TO_GPIO(GPIO2_10)); 270 gpio_free(IOMUX_TO_GPIO(GPIO2_11)); 271 gpio_free(IOMUX_TO_GPIO(GPIO2_8)); 272 gpio_free(IOMUX_TO_GPIO(GPIO2_9)); 273 gpio_free(IOMUX_TO_GPIO(GPIO2_6)); 274 gpio_free(IOMUX_TO_GPIO(GPIO2_7)); 275 276 } 277 /* 这两行指定驱动程序的初始化函数和卸载函数 */ 278 module_init(key_irq_init); 279 module_exit(key_irq_exit); 280 281 /* 描述驱动程序的一些信息,不是必须的 */ 282 MODULE_AUTHOR('Lover雪'); 283 MODULE_VERSION('0.1.0'); 284 MODULE_DESCRIPTION('IMX257 key Driver'); 285 MODULE_LICENSE('GPL'); 附上应用程序代码: 1 #include 2 #include 3 #include 4 #include 5 #include 6 #include 7 #include 8 #include 9 #include 10 #include 11 #include 12 #include 13 14 #include 'mx257_gpio.h' 15 16 #define key_input 0 17 #define version 1 18 19 20 int main(int argc, char **argv) 21 { 22 int fd; 23 int i=0,cnt=0; 24 unsigned char key_val[1]; 25 26 fd = open('/dev/key_interrupt',O_RDWR); 27 if(fd < 0){ 28 printf('can't open !!!n'); 29 } 30 ioctl(fd,version,NULL); 31 ioctl(fd,key_input,NULL); 32 while(1){ 33 read(fd,key_val,sizeof(key_val)); 34 printf('%04d key pressed: 0x%xn',cnt++,key_val[0]); 35 } 36 return 0; 37 } 结果如图所用 insmod key_interrupt.ko 后台运行应用程序 ./test/key_test & 查看中断 cat /proc/interrupts ps,查看我们后台的进程号,使用kill函数时,驱动程序会自动进入release函数,释放中断号。
