单片机
s3c6410下移植sqlite3.7.8
2024-09-23 来源:cnblogs
1、下载源代码http://www.sqlite.org/download.html
2、tar -zxvf sqlite-amalgamation-3.6.23.1.tar.gz
3、进入sqlite-3.6.23.1
4、mkdir build
5、cd build
6、../configure --host=arm-linux --prefix=/usr/local/sqlite3 注意:使用arm-linux-gcc 3.4.5时出现如下错误 checking for C compiler default output file name... configure: error: C compiler cannot create executables See `config.log' for more details.
怀疑没有写权限,使用如下配置通过 sudo ../configure --host=arm-linux --prefix=/usr/local/sqlite3 移植到开发板上无法运行,使用下面配置 ../configure --host=arm-unknown-linux-gnu --prefix=/usr/local/sqlite3
7、make
出现问题: arm-none-linux-gnueabi-gcc: 3.6.23.1': No such file or directory < command-line>: warning: missing terminating ' character ^Cmake: *** [sqlite3.lo] 错误 1
解决:
Makefile中 -DPACKAGE_STRING='sqlite 3.6.23.1' 改为: -DPACKAGE_STRING='sqlite_3.6.23.1'
8、sudo make install
出现问题: arm-linux-ranlib /usr/local/sqlite3/lib/libsqlite3.a ./libtool: line 6619: arm-linux-ranlib: command not found make[1]: *** [install-libLTLIBRARIES] 错误 127 make[1]:正在离开目录 `/work/development/sqlite/sqlite-3.6.23.1/build' make: *** [install-am] 错误 2
原因:root权限的时候没有设置arm-linux 的PATH
解决: su 根用户登录 export PATH=$PATH:/work/tools/arm/bin
make install
9、cd /usr/local/sqlite3
10、cp -arf bin include lib /work/nfs_root/sqlite/ 复制到nfs共享文件夹下
11、mount -t nfs -o intr,nolock,rsize=1024,wsize=1024 192.168. 0.128:/work/nfs_root /mnt/nfs/ mount nfs文件系统
12、cp /mnt/nfs/sqlite/bin/* /usr/bin/ mkdir /usr/lib cp -arf /mnt/nfs/sqlite/lib/* /usr/lib/ mkdir /usr/include cp /mnt/nfs/sqlite/include/* /usr/include/
13、开发板上创建数据库 # /usr/bin/sqlite3 demo SQLite version 3.6.23.1 Enter '.help' for instructions Enter SQL statements terminated with a ';' sqlite> create table tbl_demo(uid int, uname varchar(20)); sqlite> insert into tbl_demo values(1, 'jimmy'); sqlite> insert into tbl_demo values(2, 'srp'); sqlite> .quit
14、编写测试程序test.c
#include
#include
#include 'sqlite3.h'
static int callback(void *NotUsed, int argc, char **argv, char **azColName)
int i;
for(i=0; iprintf('%s = %sn', azColName[i], argv[i] ? argv[i] : 'NULL');
printf('n');
return 0;
int main(int argc, char **argv)
sqlite3 *db;
char *zErrMsg = 0;
int rc;
if( argc!=3 ){
fprintf(stderr, 'Usage: %s DATABASE SQL-STATEMENTn', argv[0]);
exit(1);
rc = sqlite3_open(argv[1], &db);
if( rc ){
fprintf(stderr, 'Can't open database: %sn', sqlite3_errmsg(db));
sqlite3_close(db);
exit(1);
rc = sqlite3_exec(db, argv[2], callback, 0, &zErrMsg);
if( rc!=SQLITE_OK ){
fprintf(stderr, 'SQL error: %sn', zErrMsg);
sqlite3_free(zErrMsg);
sqlite3_close(db);
return 0;
#include
#include
int i;
printf('n');
return 0;
sqlite3 *db;
char *zErrMsg = 0;
int rc;
if( argc!=3 ){
exit(1);
if( rc ){
sqlite3_close(db);
exit(1);
sqlite3_close(db);
return 0;
15、编译 arm-linux-gcc test.c -I /usr/local/sqlite3/include -L /usr/local/sqlite3/lib -lsqlite3 -o test
16、将test拷贝到开发板与数据库demo同一个目录下 sqlite demo test
17、运行 # ./test demo 'select * from tbl_demo' uid = 1 uname = jimmy
uid = 2 uname = srp
18、sqlite移植成功
注意: #gcc test.c -I /usr/local/sqlite3/include -L /usr/local/sqlite3/lib -lsqlite3 -o test
/usr/bin/ld: skipping incompatible /usr/local/sqlite3/lib/libsqlite3.so when searching for -lsqlite3 /usr/bin/ld: skipping incompatible /usr/local/sqlite3/lib/libsqlite3.a when searching for -lsqlite3 /usr/bin/ld: cannot find -lsqlite3 collect2: ld 返回 1
原因:sqlite是使用arm-linux-gcc编译的,所以使用的gcc与arm-linux-gcc不兼容
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 红外线探测报警器
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 用NE555制作定时器
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 基于ICL296的大电流开关稳压器电源电路
    相关电子头条文章
