单片机
GPIO学习笔记
2024-10-17 来源:cnblogs
 用汇编点亮一个led
  1 看原理图 GPK4=0 ,led亮   GPK4=1,led灭
  2  怎么让GPK4输出高低电平 (看芯片手册,操作寄存器实现)
       配置功能:输入/输出/其他
       设置其输出高/低电平
  3 查看芯片手册
   GPK4 [19:16]
0000 = Input            0001 = Output
0010 = Host I/F DATA[4]  0011 = HSI TX READY
0100 = Reserved  0101 = DATA_CF[4]
0110 = Reserved  0111 = Reserved
 GPKDAT 在第4位写写0 就对应GPK4
GPK[15:0] [15:0]
When the port is configured as input port, the corresponding bit is the pin state.
When the port is configured as output port, the pin state is the same as the
corresponding bit. When the port is configured as functional pin, the undefined
value will be read.
Register    Address        R/W    Description Reset              Value
GPKCON0  0x7F008800     R/W  Port K Configuration Register 0   0x22222222
GPKCON1  0x7F008804     R/W  Port K Configuration Register 1   0x22222222
GPKDAT   0x7F008808      R/W  Port K Data Register            Undefined
GPKPUD  0x7F00880C      R/W  Port K Pull-up/down Register     0x55555555
WTCON 0x7E004000 R/W Watchdog timer control register  0x8021
示例代码如下:
start.S文件
..globl _start
_start:
/*硬件的相关设置:把外设的基地址告诉cpu*/
        ldr r0, =0x70000000
        orr r0,r0,#0x13
        mcr p15,0,r0,c15,c2,4
/*关闭看门狗*/
        ldr r0,=0x7E004000
        mov r1,#0
        str r1,[r0]
/*设置GPKCON GPK4作为输出引脚*/
        ldr r1, =0x7F008800
        mov r0,#0x10000000
        str r0,[r1]
/*设置GPKDAT让GPK4输出0*/
        ldr r1, =0x7F008808
        mov r0,#0
        str r0,[r1]
halt:
        b halt
Makefile文件
led.bin: start.o
        arm-linux-ld -Ttext 0 -o led.elf start.o
        arm-linux-objcopy -O binary led.elf led.bin
        arm-linux-objdump -D led.elf > led.dis
start.o : start.S
        arm-linux-gcc -o start.o start.S -c
clean:
        rm *.o led.elf led.bin led.dis
编译 make
将led_on.bin烧写到nand flash中,如同烧写linux类似,将led_on.bin放到images目录下
修改friendlyARM.ini
   Action=install
       OS=UserBin
       UserBin-Image=led_on.bin
点亮四个led灯,示例代码如下:
start.S文件
.globl _start
_start:
/*硬件相关设置*/
ldr r0,=0x70000000
orr r0,r0,#0x13
/*关闭看门狗*/
ldr r0,=0x7e004000
mov r1,#0
str r1,[r0]
/*设置GPKCON GPK4/5/6/7作为输出*/
ldr r1,=0x7F008800
ldr r0,=0x11110000
str r0,[r1]
ldr r1,=0x7F0088080
mov r0,#0
loop:
str r0,[r1]
add r0,r0,#1
cmp r0,#16
moveq r0,#0
bl delay
b loop
delay:
mov r2,#0x10000000
delay_loop:
sub r2,r2,#1
cmp r2,#0
bne delay_loop
mov pc,lr
halt:
b halt
Makefile文件同上
用c语言来实现点灯
1 硬件相关设置
2 调用c函数
示例代码如下:
void delay(){
        volatile int i=0x10000000;
        while (i--);
int main(){
        int i=0;
        volatile unsigned long *gpkcon = (volatile unsigned long *)0x7F008800;
        volatile unsigned long *gpkdat = (volatile unsigned long *)0x7F008808;
        *gpkcon=0x11110000;
        while(1){
                *gpkdat=i;
                i++;
                if(i==16)
                        i=0;
                delay();
        return 0;
.globl _start
_start:
/*硬件相关设置*/
        ldr r0,=0x70000000
        orr r0,r0,#0x13
/*关看门狗*/
        ldr r0,=0x7E004000
        mov r1,#0
        str r1,[r0]
        /*设置栈*/
        ldr sp,=8*1024
        bl main
Halt:
B halt
led.bin: start.o led.o
        arm-linux-ld -Ttext 0 -o led.elf start.o led.o
start.o : start.S
led.o:led.c
        arm-linux-gcc -o led.o led.c -c
clean:
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 红外线探测报警器
  • 短波AM发射器电路设计图
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 开关电源的基本组成及工作原理
  • 带有短路保护系统的5V直流稳压电源电路图
    相关电子头条文章
