单片机
STM8S MAX7219点阵模块驱动芯片程序
2019-11-08 来源:51hei
以下为.h文件:
#ifndef __MAX7219_H
#define __MAX7219_H
#include 'stm8s_gpio.h'
#include 'stm8s.h'
#include
#include
#include 'tim1.h'
#define uchar unsigned char
#define uint  unsigned int
#define count 8
void Init_MAX7219(void);
void MAX7219_Init(void);
void Write_Max7219_byte(uchar Data);
void Write_Max7219(u8 address1,u8 dat1,u8 address2,u8 dat2);
#define High 1
#define Low 0
#define Din(High_Low) if(High_Low == 0)GPIO_WriteLow(GPIOC, GPIO_PIN_4);
else GPIO_WriteHigh(GPIOC, GPIO_PIN_4);
#define Cs(High_Low) if(High_Low == 0)GPIO_WriteLow(GPIOC, GPIO_PIN_3);
else GPIO_WriteHigh(GPIOC, GPIO_PIN_3);
#define Clk(High_Low) if(High_Low == 0)GPIO_WriteLow(GPIOC, GPIO_PIN_2);
else GPIO_WriteHigh(GPIOC, GPIO_PIN_2);
#endif
以下为.c文件:
#include 'main.h'
GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_OUT_PP_HIGH_FAST);//PC4高速推挽输出高电平控制DIN
GPIO_Init(GPIOC, GPIO_PIN_3, GPIO_MODE_OUT_PP_HIGH_FAST);//PC3高速推挽输出高电平控制CS
GPIO_Init(GPIOC, GPIO_PIN_2, GPIO_MODE_OUT_PP_HIGH_FAST);//PC2高速推挽输出高电平控制CLK
//功能:向MAX7219(U3)写入字节
//入口参数:DATA
//出口参数:无
//说明:
    uchar i;
Cs(0);
   for(i=8;i>=1;i--)
Clk(0);
if(Data&0x80)
Din(1);
else
Din(0);
Data=Data<<1;
Clk(1);
delay_us(10);
Clk(0);
//功能:向MAX7219写入数据
//入口参数:address、dat
//出口参数:无
//说明:
     Cs(0);
     Write_Max7219_byte(address1);           //写入地址,即数码管编号
     Write_Max7219_byte(dat1);              //写入数据,即数码管显示数字
     Write_Max7219_byte(address2);           //写入地址,即数码管编号
     Write_Max7219_byte(dat2);      //写入数据,即数码管显示数字
     nop();
     Cs(1);
  Write_Max7219(0x09, 0x00,0x09, 0x00);       //译码方式:BCD码
  Write_Max7219(0x0a, 0x03,0x0a, 0x03);       //亮度
Write_Max7219(0x0b, 0x07,0x0b, 0x07);       //扫描界限;8个数码管显示
  Write_Max7219(0x0c, 0x01,0x0c, 0x01);       //掉电模式:0,普通模式:1
  Write_Max7219(0x0f, 0x00,0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
u8  i;
Cs(0);
for(i=0;i {
 Write_Max7219_byte(0x09); //译码方式:BCD码
 Write_Max7219_byte(0x00);
Cs(1);
nop();
Cs(0);
for(i=0;i {
 Write_Max7219_byte(0x0a); //亮度
 Write_Max7219_byte(0x03);
Cs(1);
nop();
Cs(0);
for(i=0;i {
 Write_Max7219_byte(0x0b); // //扫描界限;8个数码管显示
 Write_Max7219_byte(0x07);
Cs(1);
nop();
Cs(0);
for(i=0;i {
 Write_Max7219_byte(0x0c); //   //掉电模式:0,普通模式:1
 Write_Max7219_byte(0x01);
Cs(1);
nop();
Cs(0);
for(i=0;i {
 Write_Max7219_byte(0x0f); //显示测试:1;测试结束,正常显示:0
Cs(1);
nop();
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 用NE555制作定时器
  • 如何构建一个触摸传感器电路
  • 基于ICL296的大电流开关稳压器电源电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
