单片机
STM8S——8位基本定时器(TIM4)
2019-12-27 来源:eefocus
简介:该定时器由一个带可编程预分频器的8位自动重载的向上计数器所组成,它可以用来作为时基发生器,具有溢出中断功能。
主要功能:
(1)8位向上计数的自动重载计数器;
(2)3位可编程的预分配器(可在运行中修改),提供1、2、4、8、16、32、64、128这8种分频比例;
(3)中断产生:更新中断(溢出,计数器初始化)。
代码实现:
 1 /* Includes ------------------------------------------------------------------*/
 2 #include 'stm8s.h'
 4 /* Private define ------------------------------------------------------------*/
 5 #define TIM4_PERIOD       124
 6 /* Private variables ---------------------------------------------------------*/
 7 __IO uint32_t TimingDelay = 0;
 8 /* Private function prototypes -----------------------------------------------*/
 9 void Delay(__IO uint32_t nTime);
10 void TimingDelay_Decrement(void);
11 static void TIM4_Config(void);
13 /**
14   * @brief  Main program.
15   * @param  None
16   * @retval None
17   */
18 void main(void)
19 {
20   /* TIM4 configuration -----------------------------------------*/
21   TIM4_Config();
22
23   /* Insert 50 ms delay */
24   Delay(50);
25   }
26 }
27
28 /**
29   * @brief  Configure TIM4 to generate an update interrupt each 1ms
30   * @param  None
31   * @retval None
32   */
33 static void TIM4_Config(void)
34 {
35   /* TIM4 configuration:
36    - TIM4CLK is set to 16 MHz, the TIM4 Prescaler is equal to 128 so the TIM1 counter
37    clock used is 16 MHz / 128 = 125 000 Hz
38   - With 125 000 Hz we can generate time base:
39       max time base is 2.048 ms if TIM4_PERIOD = 255 --> (255 + 1) / 125000 = 2.048 ms
40       min time base is 0.016 ms if TIM4_PERIOD = 1   --> (  1 + 1) / 125000 = 0.016 ms
41   - In this example we need to generate a time base equal to 1 ms
42    so TIM4_PERIOD = (0.001 * 125000 - 1) = 124 */
43
44   /* Time base configuration */
45   TIM4_TimeBaseInit(TIM4_PRESCALER_128, TIM4_PERIOD);
46   /* Clear TIM4 update flag */
47   TIM4_ClearFlag(TIM4_FLAG_UPDATE);
48   /* Enable update interrupt */
49   TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE);
51   /* enable interrupts */
52   enableInterrupts();
53
54   /* Enable TIM4 */
55   TIM4_Cmd(ENABLE);
56 }
57
58
59 /**
60   * @brief  Inserts a delay time.
61   * @param  nTime: specifies the delay time length, in milliseconds.
62   * @retval None
63   */
64 void Delay(__IO uint32_t nTime)
65 {
66   TimingDelay = nTime;
67
68   while (TimingDelay != 0);
69 }
71 /**
72   * @brief  Decrements the TimingDelay variable.
73   * @param  None
74   * @retval None
75   */
76 void TimingDelay_Decrement(void)
77 {
78   if (TimingDelay != 0x00)
79   {
80     TimingDelay--;
81   }
82 }
TIM4
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 用数字电路CD4069制作的万能遥控轻触开关
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 开关电源的基本组成及工作原理
  • 如何构建一个触摸传感器电路
  • 基于ICL296的大电流开关稳压器电源电路
    相关电子头条文章
