单片机
stvd+stm8l051F3(2): 外部中断
2020-03-03 来源:eefocus
stvd+stm8l051F3(一): 外部中断
stvd: ST Visual Develop Version 4.3.9
ic:stm8l051F3
1、原理图
按键接在stm8l051F3的PB1脚,LED接在stm8l051F3的PD0脚
2、建立stvd key项目
打开stvd新建stm8l051_key项目,并将stm8l15x.h,stm8l15x_it.h,stm8l15x_it.c,stm8l15x_conf.h,stm8l15x_exti.c,stm8l15x_gpio.c文件加入项目;
stm8l15x_gpio.c:io相关源文件;
stm8l15x_exti.c:中断相关源文件;
3、修改代码
main.c:
/* MAIN.C file
 * Copyright (c) 2002-2005 STMicroelectronics
#include 'stm8l15x.h'
//定义LED、按键端口
#define LED_PORT GPIOD
#define LED_PINS GPIO_Pin_0
#define KEY_PORT GPIOB
#define KEY_PINS GPIO_Pin_1
****入口参数:无
****出口参数:无
****函数备注:不精确延时函数
void Delay(__IO uint16_t nCount)
    /* Decrement nCount value */
    while (nCount != 0)
        nCount--;
****函数说明:主函数
****入口参数:无
****出口参数:无
****函数备注:按键按下后在外部中断1中将LED亮灭变换
void main(void)
  GPIO_Init(LED_PORT,LED_PINS,GPIO_Mode_Out_PP_Low_Slow);//初始化LED端口
  GPIO_Init(KEY_PORT, KEY_PINS, GPIO_Mode_In_PU_IT);//初始化按键,上拉输入,带中断
  EXTI_DeInit (); //恢复中断的所有设置
  EXTI_SetPinSensitivity (EXTI_Pin_1,EXTI_Trigger_Falling);//外部中断1,下降沿触发,向量号9
  enableInterrupts();//使能中断
  while (1)//等待中断
stm8l15x.h:
打开芯片型号宏定义
/* Uncomment the line below according to the target STM8L15x device used in your
   application
/* #define STM8L15X_LD */ /*!< STM8L15X_LD: STM8L15x Low density devices */
/* #define STM8L15X_MD */ /*!< STM8L15X_MD: STM8L15x Medium density devices */
/* #define STM8L15X_MDP */ /*!< STM8L15X_MDP: STM8L15x Medium density plus devices */
/* #define STM8L15X_HD */ /*!< STM8L15X_HD: STM8L15x/16x High density devices */
 #define STM8L05X_LD_VL */ /*!< STM8L05X_LD_VL: STM8L051xx3 Low density value line devices */
/* #define STM8L05X_MD_VL */ /*!< STM8L05X_MD_VL: STM8L052xx6 Medium density value line devices */
/* #define STM8L05X_HD_VL */ /*!< STM8L05X_HD_VL: STM8L052xx8 High density value line devices */
/* #define STM8AL31_L_MD */ /*!< STM8AL31_L_MD: STM8AL3x Medium density devices */
stm8l15x_conf.h:
关闭USE_FULL_ASSERT宏
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* Uncomment the line below to expanse the 'assert_param' macro in the
   Standard Peripheral Library drivers code */
/* #define USE_FULL_ASSERT (1) */
/* Exported macro ------------------------------------------------------------*/
stm8l15x_it.c:
修改中断向量9响应函数INTERRUPT_HANDLER(EXTI1_IRQHandler,9),在该函数中添加自定义中断处理函数
    /* In order to detect unexpected events during development,
       it is recommended to set a breakpoint on the following instruction.
    EXTI_ClearITPendingBit (EXTI_IT_Pin1);//清除中断标志
    GPIO_ToggleBits(GPIOD, GPIO_Pin_0);//翻转LED端口电平
stm8_interrupt_vector.c:
注释@far @interrupt void NonHandledInterrupt (void)函数,添加#include 'stm8l15x_it.h',解决重定义拨错问题,
将_vectab中irq9的中断处理函数由NonHandledInterrupt修改为EXTI1_IRQHandler
/*    BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
 *    Copyright (c) 2007 STMicroelectronics
/* 添加stm8l15x_it.h头文件 */
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
    unsigned char interrupt_instruction;
    interrupt_handler_t interrupt_handler;
/* 注释掉NonHandledInterrupt */
#if 0
    /* in order to detect unexpected events during development,
    return;
#endif
extern void _stext(); /* startup routine */
struct interrupt_vector const _vectab[] = {
    {0x82, (interrupt_handler_t)_stext}, /* reset */
    {0x82, NonHandledInterrupt}, /* trap */
    {0x82, NonHandledInterrupt}, /* irq0 */
    {0x82, NonHandledInterrupt}, /* irq1 */
    {0x82, NonHandledInterrupt}, /* irq2 */
    {0x82, NonHandledInterrupt}, /* irq3 */
    {0x82, NonHandledInterrupt}, /* irq4 */
    {0x82, NonHandledInterrupt}, /* irq5 */
    {0x82, NonHandledInterrupt}, /* irq6 */
    {0x82, NonHandledInterrupt}, /* irq7 */
    {0x82, NonHandledInterrupt}, /* irq8 */
    {0x82, EXTI1_IRQHandler}, /* irq9 */
    {0x82, NonHandledInterrupt}, /* irq10 */
    {0x82, NonHandledInterrupt}, /* irq11 */
    {0x82, NonHandledInterrupt}, /* irq12 */
    {0x82, NonHandledInterrupt}, /* irq13 */
    {0x82, NonHandledInterrupt}, /* irq14 */
    {0x82, NonHandledInterrupt}, /* irq15 */
    {0x82, NonHandledInterrupt}, /* irq16 */
    {0x82, NonHandledInterrupt}, /* irq17 */
    {0x82, NonHandledInterrupt}, /* irq18 */
    {0x82, NonHandledInterrupt}, /* irq19 */
    {0x82, NonHandledInterrupt}, /* irq20 */
    {0x82, NonHandledInterrupt}, /* irq21 */
    {0x82, NonHandledInterrupt}, /* irq22 */
    {0x82, NonHandledInterrupt}, /* irq23 */
    {0x82, NonHandledInterrupt}, /* irq24 */
    {0x82, NonHandledInterrupt}, /* irq25 */
    {0x82, NonHandledInterrupt}, /* irq26 */
    {0x82, NonHandledInterrupt}, /* irq27 */
    {0x82, NonHandledInterrupt}, /* irq28 */
    {0x82, NonHandledInterrupt}, /* irq29 */
编译项目通过
4、测试
设置断点单步调试,按下按键led点亮,再按led熄灭。
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 红外线探测报警器
  • 短波AM发射器电路设计图
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 开关电源的基本组成及工作原理
  • 用NE555制作定时器
    相关电子头条文章
