单片机
[单片机框架][bsp层][nrf51822][nrf51422][nrf51802][bsp_exti] GPIOE配置和使用
2022-09-06 来源:csdn
GPIO Task Event blocks (GPIOTE)
A GPIOTE block enables GPIOs on Port 0 to generate events on pin state change which can be used to carry out tasks through the PPI system. A GPIO can also be driven to change state on system events using the PPI system. Low power detection of pin state changes on Port 0 is possible when in System ON or System OFF.
GPIOTE块使端口0上的GPIOs能够在引脚状态变化上产生事件,这些事件可以用于通过PPI系统执行任务。 还可以使用PPI系统驱动GPIO来改变系统事件的状态。 当系统开启或系统关闭时,端口0上的引脚状态变化的低功耗检测是可能的。
GPIOTE提供了四个通道,四个通道通过GONFIG[0]——CONFIG[3]来配置,这四个通道可通过单独设置,分别和普通的GPIO绑定。当需要使用GPIOTE中断功能时可以设置相关寄存器的相应位让某个通道做为event,同时配置event触发动作。比如绑定的GPIO有上升沿或者下降沿触发event,然后配置中断使能寄存器,配置让其event时触发中断。
官方手册下载:
https://infocenter.nordicsemi.com/pdf/nRF51802_PS_v1.2.pdf
https://infocenter.nordicsemi.com/pdf/nRF51822_PS_v3.4.pdf
https://infocenter.nordicsemi.com/pdf/nRF51422_PS_v3.3.pdf
* @file    bsp_exti.c
* @author  jianqiang.xue
* @version V1.0.0
* @date    2021-04-09
* @brief   NULL
/* Includes ------------------------------------------------------------------*/
#include
#include
#include 'RTE_Components.h'
#include CMSIS_device_header
#include 'nrf_drv_gpiote.h'
/* Private Includes ----------------------------------------------------------*/
/* Private Define ------------------------------------------------------------*/
/* Private Variables ---------------------------------------------------------*/
bool bsp_exti_init = false;
typedef void(*bsp_gpio_exti_callback)(void *gpiox, uint16_t gpio_pin);
static bsp_gpio_exti_callback g_irq_callback;
/* Public Function Prototypes ------------------------------------------------*/
 * @brief  设置外部中断NVIC
 * @note   NULL
 * @param  irqn: 中断号(在typedef enum IRQn中,例如:USART1_IRQn)
 * @param  priority: 中断优先级
 * @retval None
void bsp_exit_set(uint8_t irqn, uint32_t priority)
    bsp_exti_init = true;
    nrf_drv_gpiote_in_event_enable(irqn, true);
 * @brief  清除外部中断设置
 * @note   NULL
 * @retval None
void bsp_exit_clear_set(uint8_t irqn)
    nrf_drv_gpiote_in_event_enable(irqn, false);
 * @brief  清除外部中断标志位
 * @note   NULL
 * @param  *gpiox: 预留
 * @param  pin: 引脚号
 * @retval None
void bsp_exit_clear_flag(void *gpiox, uint8_t pin)
 * @brief  注册外部中事件回调函数
 * @note   NULL
 * @param  *event: 事件函数
 * @retval None
bool bsp_gpio_exit_irq_register_callback(void *event)
    if (g_irq_callback != NULL)
        return false;
    else
        g_irq_callback = (bsp_gpio_exti_callback)event;
    return true;
void gpiote_event_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    if (g_irq_callback)
        g_irq_callback(NULL, pin);
* @file    bsp_exti.h
* @version V1.0.0
* @date    2021-04-09
* @brief   NULL
#ifndef __BSP_EXTI_H
#define __BSP_EXTI_H
#include
#include
void bsp_exit_set(uint8_t irqn, uint32_t priority);
void bsp_exit_clear_set(uint8_t irqn);
void bsp_exit_clear_flag(void *gpiox, uint8_t pin);
// 引脚外部中断回调
bool bsp_gpio_exit_irq_register_callback(void *event);
#endif
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • PIC单片机控制的遥控防盗报警器电路
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 开关电源的基本组成及工作原理
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
