单片机
嵌入式stm32学习:DMA-存储到外设
2019-06-21 来源:eefocus
bsp_usart_dma.h
#ifndef __USART_DMA_H
#define __USART_DMA_H
#include 'stm32f4xx.h'
#include
//USART
#define DEBUG_USART                       USART1
#define DEBUG_USART_CLK                   RCC_APB2Periph_USART1
#define DEBUG_USART_RX_GPIO_PORT          GPIOA
#define DEBUG_USART_RX_GPIO_CLK           RCC_AHB1Periph_GPIOA
#define DEBUG_USART_RX_PIN                GPIO_Pin_10
#define DEBUG_USART_RX_AF                 GPIO_AF_USART1
#define DEBUG_USART_RX_SOURCE             GPIO_PinSource10
#define DEBUG_USART_TX_GPIO_PORT          GPIOA
#define DEBUG_USART_TX_GPIO_CLK           RCC_AHB1Periph_GPIOA
#define DEBUG_USART_TX_PIN                GPIO_Pin_9
#define DEBUG_USART_TX_AF                 GPIO_AF_USART1
#define DEBUG_USART_TX_SOURCE             GPIO_PinSource9
#define DEBUG_USART_BAUDRATE              115200
//DMA
#define DEBUG_USART_DR_BASE               (USART1_BASE+0x04)
#define SENDBUFF_SIZE                     5000              //发送的数据量
#define DEBUG_USART_DMA_CLK               RCC_AHB1Periph_DMA2
#define DEBUG_USART_DMA_CHANNEL           DMA_Channel_4
#define DEBUG_USART_DMA_STREAM            DMA2_Stream7
void Debug_USART_Config(void);
void USART_DMA_Config(void);
#endif /* __USART1_H */
bsp_usart_dma.c
  * 重定义C库函数printf到USART端口,使用DMA模式发送数据
#include './usart/bsp_usart_dma.h'
uint8_t SendBuff[SENDBUFF_SIZE];
  * @brief  USART GPIO 配置,工作模式配置。115200 8-N-1
  GPIO_InitTypeDef GPIO_InitStructure;
  USART_InitTypeDef USART_InitStructure;----------------------------
  RCC_AHB1PeriphClockCmd( DEBUG_USART_RX_GPIO_CLK|DEBUG_USART_TX_GPIO_CLK, ENABLE);
  /* Enable UART clock */
  RCC_APB2PeriphClockCmd(DEBUG_USART_CLK, ENABLE);
  /* Connect PXx to USARTx_Tx*/
  GPIO_PinAFConfig(DEBUG_USART_RX_GPIO_PORT,DEBUG_USART_RX_SOURCE, DEBUG_USART_RX_AF);
  /* Connect PXx to USARTx_Rx*/
  GPIO_PinAFConfig(DEBUG_USART_TX_GPIO_PORT,DEBUG_USART_TX_SOURCE,DEBUG_USART_TX_AF);
  /* Configure USART Tx as alternate function  */
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Pin = DEBUG_USART_TX_PIN  ;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(DEBUG_USART_TX_GPIO_PORT, &GPIO_InitStructure);
  /* Configure USART Rx as alternate function  */
  GPIO_InitStructure.GPIO_Pin = DEBUG_USART_RX_PIN;
  GPIO_Init(DEBUG_USART_RX_GPIO_PORT, &GPIO_InitStructure);
  /* USART mode config */
  USART_InitStructure.USART_BaudRate = DEBUG_USART_BAUDRATE;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No ;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(DEBUG_USART, &USART_InitStructure);
  USART_Cmd(DEBUG_USART, ENABLE);
///重定向C库函数printf到USART1
int fputc(int ch, FILE *f)
        /* 发送一个字节数据到USART1 */
        USART_SendData(DEBUG_USART, (uint8_t) ch);
        /* 等待发送完毕 */
        while (USART_GetFlagStatus(DEBUG_USART, USART_FLAG_TXE) == RESET);
        return (ch);
///重定向C库函数scanf到USART1
int fgetc(FILE *f)
        /* 等待串口输入数据 */
        while (USART_GetFlagStatus(DEBUG_USART, USART_FLAG_RXNE) == RESET);
        return (int)USART_ReceiveData(DEBUG_USART);
  * @brief  USART1 TX DMA 配置,内存到外设(USART1->DR)
  DMA_InitTypeDef DMA_InitStructure;
  /*开启DMA时钟*/
  RCC_AHB1PeriphClockCmd(DEBUG_USART_DMA_CLK, ENABLE);
  /* 复位初始化DMA数据流 */
  DMA_DeInit(DEBUG_USART_DMA_STREAM);
  /* 确保DMA数据流复位完成 */
  while (DMA_GetCmdStatus(DEBUG_USART_DMA_STREAM) != DISABLE)  {
  /*USART tx对应DMA2,通道4,数据流7*/
  DMA_InitStructure.DMA_Channel = DEBUG_USART_DMA_CHANNEL;
  /*设置DMA源,串口数据寄存器地址*/
  DMA_InitStructure.DMA_PeripheralBaseAddr = DEBUG_USART_DR_BASE;
  /*内存地址(要传输的变量的指针)*/
  DMA_InitStructure.DMA_Memory0BaseAddr = (u32)SendBuff;
  /*方向:内存到外设*/
  DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  /*传输大小DMA_BufferSize=SENDBUFF_SIZE*/
  DMA_InitStructure.DMA_BufferSize = SENDBUFF_SIZE;
  /*外设地址不增*/
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  /*内存地址自增*/
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  /*外设数据单位*/
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  /*内存数据单位 8bit*/
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  /*DMA模式:循环*/
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  /*优先级:中*/
  DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
  /*禁用FIFO*/
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  /*存储器突发传输16个节拍*/
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  /*外设突发传输1个节拍*/
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  /*配置DMA2的数据流7*/
  DMA_Init(DEBUG_USART_DMA_STREAM, &DMA_InitStructure);
  /*使能DMA*/
  DMA_Cmd(DEBUG_USART_DMA_STREAM, ENABLE);
  /*等待DMA数据流有效*/
  while(DMA_GetCmdStatus(DEBUG_USART_DMA_STREAM) != ENABLE)
/*********************************************END OF FILE**********************/
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 红外线探测报警器
  • 短波AM发射器电路设计图
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
