单片机
STM32双定时器测频率源程序
2020-07-12 来源:51hei
最近在准备八月份的全国大学生电子设计大赛,就做了几道往年的电赛真题,其中有一题是测频率,要求测量频率10Hz—2MHz,误差小于0.1%,当时也是一脸懵,就在论坛找资料,发现论坛中使用的基本都是输入捕获方法测频率,但是这种方法不能测高频,最多测几百千赫兹,达不到题目要求。经过和小伙伴们的一天讨论,最终创造了一种程序,它可以测量1Hz-22MHz,并且误差小于0.1%。下面是验证通过的程序,算是作为一种在论坛潜伏一年多对论坛的回报吧。
单片机源程序如下:
#include 'led.h'
#include 'delay.h'
#include 'key.h'
#include 'sys.h'
#include 'usart.h'
#include 'timer.h'
u32 count_s;
u32 count_ms;
extern u32 count_i;
extern u32 count_over;
int main(void)
                NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);                  //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
          uart_init(9600);         //串口初始化为9600
        TIM3_External_Clock_CountingMode();
        TIM4_timer_Init();
    while(1)
                if(count_i>1000)
                        count_ms = TIM3->CNT;
                        count_s = count_over*65536 + count_ms;
                        printf('%d rn ',count_s);        //打印数据
                        count_i=0;
                        count_over=0;
                        TIM3->CNT=0;
#include 'timer.h'
#include 'led.h'
//通用定时器3中断初始化
//这里时钟选择为APB1的2倍,而APB1为36M
//arr:自动重装值。
//psc:时钟预分频数
//这里使用的是定时器3!
void TIM3_External_Clock_CountingMode(void)
          GPIO_InitTypeDef GPIO_InitStructure;
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
          NVIC_InitTypeDef NVIC_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    TIM_DeInit(TIM3);
    TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
    TIM_TimeBaseStructure.TIM_Prescaler = 0;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
          TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM4中断
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占优先级0级
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;  //从优先级3级
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
        NVIC_Init(&NVIC_InitStructure);  //初始化NVIC寄存器
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能指定的TIM4中断
        TIM_ETRClockMode2Config(TIM3, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);//2分频,上升沿有效
        TIM_SetCounter(TIM3, 0);   // 清零计数器CNT
        TIM_Cmd(TIM3,ENABLE);
void TIM4_timer_Init(void)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);  //时钟使能
        TIM_TimeBaseStructure.TIM_Period = 9;         //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =7199;         //设置用来作为TIMx时钟频率除数的预分频值
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
        TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx的时间基数单位
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;  //TIM4中断
        TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE ); //使能指定的TIM4中断
        TIM_SetCounter(TIM4, 0);   // 清零计数器CNT
        TIM_Cmd(TIM4, ENABLE);  //使能TIM4
u32 count_i = 0;
void TIM4_IRQHandler(void)
        if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)  //检查TIM4更新中断发生与否
                TIM_ClearITPendingBit(TIM4, TIM_IT_Update);                 //注意清除标志位
                count_i++;
u32 count_over = 0;
void TIM3_IRQHandler(void)
        if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)  //检查TIM4更新中断发生与否
                TIM_ClearITPendingBit(TIM3, TIM_IT_Update);                 //注意清除标志位
                count_over++;
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • 红外线探测报警器
  • 短波AM发射器电路设计图
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 开关电源的基本组成及工作原理
  • 带有短路保护系统的5V直流稳压电源电路图
    相关电子头条文章
