单片机
stm32专题五:时钟树(二)系统配置时钟函数分析
2021-10-15 来源:eefocus
分析stm32的系统时钟函数,对于我们实现自定义时钟配置非常重要,以下是标准库函数中的时钟配置函数。
static void SetSysClockTo72(void)
    __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
    /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
    /* Enable HSE */
    // 使能HSE
    RCC->CR |= ((uint32_t)RCC_CR_HSEON);
    /* Wait till HSE is ready and if Time out is reached exit */
    // 等待HSE就绪并做超时处理
    do
        HSEStatus = RCC->CR & RCC_CR_HSERDY;
        StartUpCounter++;
    } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
    /* 分析:当不超过超时时间时,后面这部分一直为1;因此,只要HSERDY了,立马跳出循环
       如果HSE故障,则会一直等到设定的超时时间,然后跳出 */
    // 上面只是跳出循环,这里判断HSE是否真正启动成功
    if ((RCC->CR & RCC_CR_HSERDY) != RESET)
        HSEStatus = (uint32_t)0x01;
    else
        HSEStatus = (uint32_t)0x00;
    // HSE启动成功,程序继续往下执行
    if (HSEStatus == (uint32_t)0x01)
        /* Enable Prefetch Buffer */
        // 使能预取指,CPU运行过程:取指令-执行指令-取指令-执行指令
        // 预取指类似于8086的指令队列,会取出当前和接下来要执行的多条指令,送入指令队列缓冲
        FLASH->ACR |= FLASH_ACR_PRFTBE;
        /* Flash 2 wait state */
        /* CPU从Flash取指令的时间间隔,72MHz时要等待两个时钟周期
           等待的原因时,flash运行速度慢,CPU如果一直等待flash就绪,则会浪费很多时间效率低下
           因此等待两个时钟周期,待flash就绪然后读取指令到预取指缓存 */
        FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
        FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
        // 配置AHB APB1 APB2总线的分频因子
        /* HCLK = SYSCLK = 72M*/
        RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
        /* PCLK2 = HCLK = 72M */
        RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
        /* PCLK1 = HCLK = 36M */
        RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
        /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
// 配置锁相环输入为HSE不分频
        RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
                                            RCC_CFGR_PLLMULL));
// 配置PLL倍频因子为9
        RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
        /* Enable PLL */
        // 使能PLL锁相环
        RCC->CR |= RCC_CR_PLLON;
        /* Wait till PLL is ready */
// 等待锁相环准备就绪
        while((RCC->CR & RCC_CR_PLLRDY) == 0)
        /* Select PLL as system clock source */
// 选择PLLCLK作为系统时钟
        RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
        RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
        /* Wait till PLL is used as system clock source */
// 等待PLLCLK切换成功
        while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
    // 如果HSE启动失败,在这里填入错误处理代码
    else
    {   /* If HSE fails to start-up, the application will have wrong clock
             configuration. User can add here some code to deal with this error */
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 短波AM发射器电路设计图
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
