单片机
STM32中ADC的使用/printf函数重定向串口显示内部温度传感器测量值
2022-04-21 来源:eefocus
STM32F334C8T6这款MCU中有两个12位ADC(模数转换器),ADC1的通道16连接到内置的一个温度传感器,本文使用该温度传感器测量MCU和周围的环境温度,并且通过串口发送到PC的串口助手进行显示。
1. ADC的使用
1. select the ADC clock using the function RCC_ADCCLKConfig()
2. Enable the ADC interface clock using RCC_AHBPeriphClockCmd();
3. ADC pins configuration
 Enable the clock for the ADC GPIOs using the following function: RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOx, ENABLE);
 Configure these ADC pins in analog mode using GPIO_Init();
4. Configure the ADC conversion resolution, data alignment, external trigger and edge,
sequencer lenght and Enable/Disable the continuous mode using the ADC_Init() function.
5. Activate the ADC peripheral using ADC_Cmd() function.
To configure the ADC channels features, use ADC_Init(), ADC_InjectedInit() and ADC_RegularChannelConfig() functions or/and ADC_InjectedChannelConfig()
2. 内部温度传感器的使用
To use the sensor:
1. Select the ADC1_IN16 input channel.
2. Select a sample time of 2.2 μs.
3. Set the TSEN bit in the ADC1_CCR register to wake up the temperature sensor from power-down mode.
4. Start the ADC conversion.
5. Read the resulting VTS data in the ADC data register.
6. Calculate the temperature using the following formula:
Temperature (in °C) = {(V25 – VTS) / Avg_Slope} + 25
Where:
– V25 = VTS value for 25° C
– Avg_Slope = average slope of the temperature vs. VTS curve (given in mV/°C or μV/°C)
Refer to the datasheet electrical characteristics section for the actual values of V25 and Avg_Slope.
(截图自 STM32F334 datasheet)
所以取  Avg_Slope=4.3, ,  V25=1.43 ,此处注意单位的不同
则有
Temperature (in °C) = {(1430 – VTS) /4.3 } + 25
3. printf()函数重定向
printf()函数是向显示器输出数据的函数,功能非常强大,使用非常方便,为了能方便的使用printf()函数,对该函数进行重定向,使其能向串口打印数据,则可以直接使用printf()函数将数据发到串口,极大方便了信息的输出。
通过重新实现int fputc(int ch,FILE *f)函数来实现这些功能。
4. 部分代码:
//在主函数中调用ADC,USART配置函数,实现延时函数,再调用下面的测试函数
#include 'ADConverter.h'
void ADC_Config(void)
     ADC_InitTypeDef       ADC_InitStructure;
        ADC_CommonInitTypeDef ADC_CommonInitStructure;
     GPIO_InitTypeDef      GPIO_InitStructure;
  //select ADC colock
        RCC_ADCCLKConfig(RCC_ADC12PLLCLK_Div6);
    //enable peripheral colock
 RCC_AHBPeriphClockCmd(ADC_PORT_CLK,ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_ADC12,ENABLE);
     //配置GPIO为模拟输入模式
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
       //GPIO_InitStructure其他成员初始化
        //GPIO_Init(GPIO_TypeDef * GPIOx, GPIO_InitTypeDef * GPIO_InitStruct);
         ADC_StructInit(&ADC_InitStructure);
    ADC_VoltageRegulatorCmd(ADC1, ENABLE);
     delay_us(10);
  //添加Calibration
        //Common Init
      ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
   //ADC_CommonInitStructure其他成员初始化
   ADC_CommonInit(ADC1,&ADC_CommonInitStructure);
         //ADC Init
 ADC_InitStructure.ADC_ContinuousConvMode = ADC_ContinuousConvMode_Enable;
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
     ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
     ADC_InitStructure.ADC_NbrOfRegChannel = 1;
 //ADC_InitStructure其他成员初始化
  ADC_Init(ADC1,&ADC_InitStructure);
     //配置ADC的通道,采样周期等
   ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 1, ADC_SampleTime_19Cycles5);
       //打开温度传感器
  ADC_TempSensorCmd(ADC1, ENABLE);
   //打开ADC
    ADC_Cmd(ADC1,ENABLE);
  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_RDY));
     //开始转换
     ADC_StartConversion(ADC1);
//获取温度值函数
uint16_t GetTemperature(void)
 u16 t,temp,Temperature;
  t=ADC_GetConversionValue(USING_ADC);//读取ADC数值
  temp = t*3300/0xFFF;//将读取的数值转换为电压值
 Temperature = (1430-temp)*10/43+25;//将电压值转换为温度值(℃)
     return Temperature;
//测试函数,每隔0.5秒读取一次测试值
//并把测试到的温度通过串口打印到PC的串口助手显示出来
void TempSensortest(void)
   u16 tmp=0;
  while(1)
                  delay_ms(500);
                     tmp = GetTemperature();
                    printf('The Temperature = %d ℃n',tmp);
//printf()函数的重定向,使其能向串口打印数据
  USART_SendData(USART2, ch);
  while(USART_GetFlagStatus(USART2, USART_FLAG_TC)==RESET) ;
  return(ch);
实际效果如下:
(将手指按在MCU上,温度在逐渐升高)
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • 用NE555制作定时器
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何调制IC555振荡器
    相关电子头条文章
