单片机
RT-Thread开发GD32F450添加adc外设
2024-11-15 来源:elecfans
开发板使用的是gd32f450zk,env工具使用的版本是1.3.5,rtthread版本是5.0.0
添加adc外设的步骤如下:
步骤1: 查看开发板的电路原理图,确定adc的使用引脚,使用的是引脚PF6,即adc012_IN4,如下图:
步骤2: 使用env工具开启adc外设,并选择配置相应的adc外设,如下如
步骤3:打开drv_adc.c文件,修改代码
修改后代码如下,也可以全部修改为GET_PIN(F, 6)
#ifdef BSP_USING_ADC2
ADC2,
RCU_ADC2,
GET_PIN(A, 0), GET_PIN(A, 1), GET_PIN(A, 2), GET_PIN(A, 3),
GET_PIN(F, 6), GET_PIN(A, 5), GET_PIN(A, 6), GET_PIN(A, 7),
GET_PIN(B, 0), GET_PIN(B, 1), GET_PIN(C, 0), GET_PIN(C, 1),
GET_PIN(C, 2), GET_PIN(C, 3), GET_PIN(C, 4), GET_PIN(C, 5),
&adc2,
'adc2',
#endif
还需要修改的函数有:
static rt_err_t gd32_adc_enabled(struct rt_adc_device *device, rt_uint32_t channel, rt_bool_t enabled);
static rt_err_t gd32_adc_convert(struct rt_adc_device *device, rt_uint32_t channel, rt_uint32_t *value);
提示ADC_REGULAR_CHANNEL 未定义。改为ADC_ROUTINE_CHANNEL,同时将其余报错进行修改,修改后的代码如下:
@brief ADC enable
This function enable adc.
@param device, channel, enabled
@retval None
static rt_err_t gd32_adc_enabled(struct rt_adc_device device, rt_uint32_t channel, rt_bool_t enabled)
uint32_t adc_periph;
struct gd32_adc * adc = (struct gd32_adc )device->parent.user_data;
if (channel >= MAX_EXTERN_ADC_CHANNEL)
LOG_E('invalid channel');
return -RT_EINVAL;
adc_periph = (uint32_t )(adc->adc_periph);
if (enabled == ENABLE)
gd32_adc_gpio_init(adc->adc_clk, adc->adc_pins[channel]);
adc_channel_length_config(adc_periph, ADC_ROUTINE_CHANNEL, 1);
adc_data_alignment_config(adc_periph, ADC_DATAALIGN_RIGHT);
#if defined SOC_SERIES_GD32F4xx
adc_external_trigger_source_config(adc_periph, ADC_ROUTINE_CHANNEL, ADC_EXTTRIG_ROUTINE_EXTI_11);
#else
adc_external_trigger_source_config(adc_periph, ADC_REGULAR_CHANNEL, ADC0_1_2_EXTTRIG_REGULAR_NONE);
#endif
adc_external_trigger_config(adc_periph, ADC_ROUTINE_CHANNEL, ENABLE);
adc_routine_channel_config(adc_periph, 0, channel, ADC_SAMPLETIME_480);
#else
adc_regular_channel_config(adc_periph, 0, channel, ADC_SAMPLETIME_13POINT5);
#endif
adc_enable(adc_periph);
/ ADC calibration and reset calibration /
adc_calibration_enable(adc_periph);
else
adc_disable(adc_periph);
return 0;
@brief convert adc.
This function get adc value.
@param device, channel, value
@retval None
struct gd32_adc * adc = (struct gd32_adc *)(device->parent.user_data);
if (!value)
LOG_E('invalid param');
return -RT_EINVAL;
adc_software_trigger_enable(adc_periph, ADC_ROUTINE_CHANNEL);
while(!adc_flag_get(adc_periph, ADC_FLAG_EOC)){};
// clear flag
adc_flag_clear(adc_periph, ADC_FLAG_EOC);
*value = adc_routine_data_read(adc_periph);
return 0;
步骤4:编译正常,下载到开发板,进行测试,测试指令如下:
msh />adc
Usage:
adc probe - probe adc by name
adc read - read adc value on the channel
adc disable - disable adc channel
adc enable - enable adc channel
步骤5:测试发现输入并无变化的情况下,读取的值一直在变,并且变化太大,读取到的值快速减小。
说明配置的有问题,查找原因,发现再使能adc外设的时候,没有对引脚的时钟进行使能,再static void gd32_adc_gpio_init(rcu_periph_enum adc_clk, rt_base_t pin)函数中增加使能引脚时钟,修改如下:
rcu_periph_clock_enable(RCU_GPIOF);
修改之后测试,测试结果
读取的值不会变化很大,而是再一定的范围内变化。
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
最新器件
精选电路图
  • 简洁的过零调功器电路设计与分析
  • 永不缺相启动运行的电动机控制电路
  • IGBT模块通过控制门极阻断过电流
  • MT3608构成3.7V转12V的升压电路图
  • 基于M66T旋律发​​生器的电路图解析
  • 一个简单的红外耳机电路
    相关电子头条文章
