MSP430(G2553)用看门狗定时器来产生周期信号
2020-01-28 来源:eefocus
#include #include volatile unsigned int i = 0; // 中断服务子程序中所用到的全局变量, 最好定义成 volatile 型, 具体原因和用法可以参考我的其他博文介绍 void main (void) { WDTCTL = WDT_MDLY_0_5; // 周期 0.5ms, 设置可参考下面头文件中的截段 IE1 |= WDTIE; // 使能WDT中断 P2DIR |= BIT2; // P2.2输出 _EINT(); // 使能全局中断 for (;;) { LPM0; // 进入LPM0 _NOP(); } } // 看门狗中断服务子程序 #pragma vector=WDT_VECTOR __interrupt void WDT_Timer_ISR(void) { if (i++ > 1) { P2OUT ^= BIT2; // 取反 } } ============================================================================================================================== //========================================================================================================================== // 相关头文件中的定义 /************************************************************ * WATCHDOG TIMER ************************************************************/ #define __MSP430_HAS_WDT__ /* Definition to show that Module is available */ #define WDTCTL_ (0x0120u) /* Watchdog Timer Control */ DEFW( WDTCTL , WDTCTL_) /* The bit names have been prefixed with 'WDT' */ #define WDTIS0 (0x0001u) #define WDTIS1 (0x0002u) #define WDTSSEL (0x0004u) #define WDTCNTCL (0x0008u) #define WDTTMSEL (0x0010u) #define WDTNMI (0x0020u) #define WDTNMIES (0x0040u) #define WDTHOLD (0x0080u) #define WDTPW (0x5A00u) /* WDT-interval times [1ms] coded with Bits 0-2 */ /* WDT is clocked by fSMCLK (assumed 1MHz) */ #define WDT_MDLY_32 (WDTPW+WDTTMSEL+WDTCNTCL) /* 32ms interval (default) */ #define WDT_MDLY_8 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0) /* 8ms ' */ #define WDT_MDLY_0_5 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1) /* 0.5ms ' */ #define WDT_MDLY_0_064 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms ' */ /* WDT is clocked by fACLK (assumed 32KHz) */ #define WDT_ADLY_1000 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL) /* 1000ms ' */ #define WDT_ADLY_250 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms ' */ #define WDT_ADLY_16 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms ' */ #define WDT_ADLY_1_9 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms ' */ /* Watchdog mode -> reset after expired time */ /* WDT is clocked by fSMCLK (assumed 1MHz) */ #define WDT_MRST_32 (WDTPW+WDTCNTCL) /* 32ms interval (default) */ #define WDT_MRST_8 (WDTPW+WDTCNTCL+WDTIS0) /* 8ms ' */ #define WDT_MRST_0_5 (WDTPW+WDTCNTCL+WDTIS1) /* 0.5ms ' */ #define WDT_MRST_0_064 (WDTPW+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms ' */ /* WDT is clocked by fACLK (assumed 32KHz) */ #define WDT_ARST_1000 (WDTPW+WDTCNTCL+WDTSSEL) /* 1000ms ' */ #define WDT_ARST_250 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms ' */ #define WDT_ARST_16 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms ' */ #define WDT_ARST_1_9 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms ' */
