单片机
MSP430 flash写入(二)
2022-09-07 来源:csdn
/* --COPYRIGHT--,BSD_EX
 * Copyright (c) 2012, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS 'AS IS'
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *                       MSP430 CODE EXAMPLE DISCLAIMER
 * MSP430 code examples are self-contained low-level programs that typically
 * demonstrate a single peripheral function or device feature in a highly
 * concise manner. For this the code may rely on the device's power-on default
 * register values and settings such as the clock configuration and care must
 * be taken when combining code from several examples to avoid potential side
 * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
 * for an API functional library-approach to peripheral configuration.
 * --/COPYRIGHT--*/
//  MSP430F552x 例程 - Flash In-System Programming w/ 在地址0x1800长字写入
// 这段程序首先擦除flash seg D, 然后在地址0x1800写入一个32-bit的数据
//  ACLK = REFO = 32kHz, MCLK = SMCLK = default DCO 1048576Hz
//                MSP430x552x
//        /||              XIN|-
//         --|RST          XOUT|-
//   Bhargavi Nisarga
//   Texas Instruments Inc.
//   April 2009
//   Built with CCSv4 and IAR Embedded Workbench Version: 4.21
#include
int main(void)
  unsigned long * Flash_ptrD;               // 初始化Seg D指针
  unsigned long value;
  WDTCTL = WDTPW+WDTHOLD;                   // 关闭看门狗
  Flash_ptrD = (unsigned long *) 0x1800;    // 初始化Flash pointer
  value = 0x12345678;                       // 初始化Value
  FCTL3 = FWKEY;                            // Clear Lock bit
  FCTL1 = FWKEY+ERASE;                      // Set Erase bit
  *Flash_ptrD = 0;                          // Dummy write to erase Flash seg
  FCTL1 = FWKEY+BLKWRT;                     // Enable long-word write
  *Flash_ptrD = value;                      // Write to Flash
  FCTL1 = FWKEY;                            // Clear WRT bit
  FCTL3 = FWKEY+LOCK;                       // Set LOCK bit
  while(1);                                 // Loop forever, SET BREAKPOINT HERE
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何构建一个触摸传感器电路
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
    相关电子头条文章
