电源管理
FairchildFL7701智能LED灯驱动解决方案
2012-07-19 来源:21ic
Fairchild公司的FL7701是带PFC功能的智能LED灯驱动器,内置了高压自偏置电路,输入电压范围80VAC ~ 308VAC,带自动重起模式的AOCP功能,内置超温保护功能,主要用于装饰LED灯和低功率LED灯.本文介绍了FL7701主要特性,方框图,典型和高压应用电路以及带和不带电解电容的应用电路,2.4W LED镇流器电路图,材料清单和PCB布局图.
The FL7701 LED lamp driver is a simple IC with PFC function. The special “adopted digital” technique of the IC can automatically detect input voltage condition and send an internal reference signal for achieving high power factor. When AC input is applied to the IC, PFC function is automatically enabled. Otherwise, when DC input is applied to the IC, PFC function is automatically disabled. The FL7701 does not need a bulk capacitor(electrolytic capacitor) for supply rail stability, which can significantly affect to LED lamp system.
FL7701主要特性:
 Digitally Implemented Active PFC Function (No Additional Circuit Necessary for High PF)
 Built-in HV Supplying Circuit: Self Biasing
 Application Input Range :80VAC ~ 308VAC
 AOCP Function with Auto-Restart Mode
 Built-in Over-Temperature Protection Function
 Cycle-by-Cycle Current Limit
 Current-Sense Pin Open Protection
 Low Operating Current: 0.85mA (Typical)
 Under-Voltage Lockout with 5V Hysteresis
 Programmable Oscillation Frequency
 Programmable LED Current
 Analog Dimming Function
 Soft-Start Function
 Precise Internal Reference: ±3%
FL7701应用:
 LED Lamp for Decorative Lighting
 LED Lamp for Low-Power Lighting
图1.FL7701方框图
图2.FL7701典型应用电路图
图3.FL7701高压应用电路图
图4.FL7701无电解电容的应用电路
图5.FL7701带电解电容的应用电路
采用FL7701的2.4W LED镇流器
This document describes the proposed solution for a universal-input 2.4W LED ballast using the FL7701. The input voltage range is 90VRMS – 265VRMS and there is one DC output with a constant current of 85mA at 28VMAX. This document contains general description of FL7701, the power supply specification, schematic, bill of materials, and the typical operating characteristics.
图6.2.4W LED镇流器外形图
图7.2.4W LED镇流器电路图
2.4W LED镇流器材料清单:
图8.2.4W LED镇流器PCB布局图
详情请见:
http://www.fairchildsemi.com/ds/FL/FL7701.pdf
http://www.fairchildsemi.com/products/evaluationboards/FEBFL7701_L30U003A.pdf?user-guide=
进入电源管理查看更多内容>>
相关视频
  • MIT 6.622 Power Electronics
  • 下世代能量转换技术
  • 开关电源之Buck变换器的环路分析与补偿
  • 自激振荡开关电源电路构成特点及工作原理介绍
  • 开关电源入门视频(BUCK)
  • 电源小白到实战
最新器件
精选电路图
  • 单稳态控制电路设计与分析
  • MT3608构成3.7V转12V的升压电路图
  • 比较常见的功率整流器和滤波电路
  • 基于M66T旋律发​​生器的电路图解析
  • 一个简单的红外耳机电路
  • 基于TDA1554的立体声放大器电路
    相关电子头条文章
