LTC2311特性及演示板2425A主要特性
2018-04-29 来源:社区化
Linear公司的LTC2311-16是低噪音高速16位SAR5MspsADC,差分输入和宽输入共模范围,单电源3.3V或5V工作,差分输入范围8VP-P,fIN = 2.2MHz时的SNR为81dB,THD为-90dB,16位时±3LSB INL,不会丢失码,主要用在高速数据采集系统,通信,遥控数据采集,图像,光网络,汽车电子和对相马达控制。本文介绍了LTC2311特性,框图,应用电路以及演示板2425A主要特性,连接图,电路图,材料清单和PCB元件布局图。
The LTCR2311-16 is a low noise, high speed 16-bitsuccessive approximaTIon register (SAR) ADC withdifferenTIal inputs and wide input common mode range.
OperaTIng from a single 3.3V or 5V supply, the LTC2311-16 has an 8VP-P differenTIal input range, making it idealfor applications which require a wide dynamic range withhigh common mode rejection. The LTC2311-16 achieves±3LSB INL typical, no missing codes at 16 bits and 81dBSNR typical.
The LTC2311-16 has an onboard low drift (20ppm/℃ max)2.048V or 4.096V temperature-compensated reference andprovides an external 1.25V buffered reference input. TheLTC2311-16 also has a high speed SPI-compatible serialinterface that supports CMOS or LVDS. The fast 5Mspsthroughput with one-cycle latency makes the LTC2311-16ideally suited for a wide variety of high speed applications.
The LTC2311-16 dissipates only 50mW with a 5V supplyand offers nap and sleep modes to reduce the powerconsumption to 5μW for further power savings duringinactive periods.
LTC2311特性:
5Msps Throughput Rate
±3LSB INL (Typ), ±8LSB INL Guaranteed
Guaranteed 16-Bit, No Missing Codes
8VP-P Differential Inputs with Wide Input CommonMode Range
81dB SNR (Typ) at fIN = 2.2MHz
–90dB THD (Typ) at fIN = 2.2MHz
Guaranteed Operation –40℃ to 125℃
Single 3.3V or 5V Supply
Low Drift (20ppm/℃ Max) 2.048V or 4.096V InternalReference with 1.25V External Reference Input
1.8V to 2.5V I/O Voltages
CMOS or LVDS SPI-Compatible Serial I/O
Power Dissipation 50mW at VDD = 5V (Typ)
Small 16-Lead (4mm × 5mm) MSOP Package
LTC2311应用:
High Speed Data Acquisition Systems
Communications
Remote Data Acquisition
Imaging
Optical Networking
Multiphase Motor Control
图1.LTC2311框图:CMOS I/O模式
图2.LTC2311框图:LVDS I/O模式
图3.LTC2311全差分应用电路
演示板2425A
Demonstration circuit 2425A features the LTC®2311 family.With up to 5Msps, these differential, single channel, 16-bit,serial, high speed successive approximation register(SAR) ADCs are available in a 16-lead MSOP package.
The LTC2311 family has an internal 20ppm/°C maximumdrift reference and an SPI-compatible serial interface thatsupports CMOS and LVDS logic. Note the demo board isconfigured for CMOS operation by default; see the noteunder JP3 for LVDS operation. The following text refersto the LTC2311, but applies to all members of the family,the only difference being the sample rate and/or thenumber of bits. The DC2425A demonstrates the DC andAC performance of the LTC2311 in conjunction with theDC890 PScope™ data collection board.
Alternatively, byconnecting the DC2425A into a customer application, theperformance of the LTC2311 can be evaluated directly inthat circuit.
图4.演示板2425A连接示意图
图5.演示板2425A电路图(1)
图6.演示板2425A电路图(2)
演示板2425A材料清单(BOM):
图7.演示板2425A PCB元件布局
- ADI 旗下凌力尔特公司推出宽范围 I2C 系统监视器 LTC2992
- 凌力尔特公司推出多拓扑电流模式 PWM 控制器 LT8711
- ADI旗下凌力尔特公司推出双平衡混频器 LTC5553
- ADI旗下凌力尔特公司推出寄存器ADC LTC2358-18
- 凌力尔特公司推出µModule® (电源模块) 降压型稳压器 LTM8073
- ADI公司完成对凌力尔特公司的收购
- ADI公司完成对凌力尔特公司的收购
- ADI公司明日完成收购凌力尔特 已获得全部法律批复
- ADI公司已获收购凌力尔特公司所需的全部法律批复
- 瑞萨推出包括先进可编程14位SAR ADC在内的 全新AnalogPAK可编程混合信号IC系列
