1. 1. 专用寄存器include文件
例如8031、8051均为REG51.h其中包括了所有8051的SFR及其位定义,一般系统都必须包括本文件。
2. 2. 绝对地址include文件absacc.h
该文件中实际只定义了几个宏,以确定各存储空间的绝对地址。
3. 3. 动态内存分配函数,位于stdlib.h中4. 4. 缓冲区处理函数位于“string.h”中
其中包括拷贝比较移动等函数如:
memccpy memchr memcmp memcpy memmove memset
这样很方便地对缓冲区进行处理。
5. 5. 输入输出流函数,位于“stdio.h”中
流函数通8051的串口或用户定义的I/O口读写数据,缺省为8051串口,如要修改,比如改为LCD显示,可修改lib目录中的getkey.c及putchar.c源文件,然后在库中替换它们即可。
3. 第三节 Keil C51库函数原型列表
1. 1. CTYPE.H
bit isalnum(char c);
bit isalpha(char c);
bit iscntrl(char c);
bit isdigit(char c);
bit isgraph(char c);
bit islower(char c);
bit isprint(char c);
bit ispunct(char c);
bit isspace(char c);
bit isupper(char c);
bit isxdigit(char c);
bit toascii(char c);
bit toint(char c);
char tolower(char c);
char __tolower(char c);
char toupper(char c);
char __toupper(char c);
2. 2. INTRINS.H
unsigned char _crol_(unsigned char c,unsigned char b);
unsigned char _cror_(unsigned char c,unsigned char b);
unsigned char _chkfloat_(float ual);
unsigned int _irol_(unsigned int i,unsigned char b);
unsigned int _iror_(unsigned int i,unsigned char b);
unsigned long _irol_(unsigned long l,unsigned char b);
unsigned long _iror_(unsigned long L,unsigned char b);
void _nop_(void);
bit _testbit_(bit b);
3. 3. STDIO.H
char getchar(void);
char _getkey(void);
char *gets(char * string,int len);
int printf(const char * fmtstr[,argument]…);
char putchar(char c);
int puts (const char * string);
int scanf(const char * fmtstr.[,argument]…);
int sprintf(char * buffer,const char *fmtstr[;argument]);
int sscanf(char *buffer,const char * fmtstr[,argument]);
char ungetchar(char c);
void vprintf (const char *fmtstr,char * argptr);
void vsprintf(char *buffer,const char * fmtstr,char * argptr);
4. 4. STDLIB.H
float atof(void * string);
int atoi(void * string);
long atol(void * string);
void * calloc(unsigned int num,unsigned int len);
void free(void xdata *p);
void init_mempool(void *data *p,unsigned int size);
void *malloc (unsigned int size);
int rand(void);
void *realloc (void xdata *p,unsigned int size);
void srand (int seed);
5. 5. STRING.H
void *memccpy (void *dest,void *src,char c,int len);
void *memchr (void *buf,char c,int len);
char memcmp(void *buf1,void *buf2,int len);
void *memcopy (void *dest,void *SRC,int len);
void *memmove (void *dest,void *src,int len);
void *memset (void *buf,char c,int len);
char *strcat (char *dest,char *src);
char *strchr (const char *string,char c);
char strcmp (char *string1,char *string2);
char *strcpy (char *dest,char *src);
int strcspn(char *src,char * set);
int strlen (char *src);
char *strncat (char 8dest,char *src,int len);
char strncmp(char *string1,char *string2,int len);
char strncpy (char *dest,char *src,int len);
char *strpbrk (char *string,char *set);
int strpos (const char *string,char c);
char *strrchr (const char *string,char c);
char *strrpbrk (char *string,char *set);
int strrpos (const char *string,char c);
int strspn(char *string,char *set);
6. 第六章 Keil C51例子:Hello.c
Hello位于\C51\excmples\Hello\目录,其功能是向串口输出“Hello,world”整个程序如下:
#pragma DB OE CD
#indule
#include
void main(void)
SCOn=0x50;
TMOD=0x20
TH1=0xf3;
Tri=1;
TI=1;
printf(“Hello,world \n”);
while(1) { }
1. 第一节 uVision for Windows的使用步骤
(1) file_new新建一个hello.c文件,输入如上内容或直接用目录下源文件。
(2) file_save或工具栏将文件存盘。
(3) project_new project创建一个project名为hello,并在其中加入hello.c。
这时该project已是打开状态,或用open project打开已存在的project。
(4) option_C51 compiler中选出至少包括两项DB OE。
(5) option_dscope Debugger选中hello\DS51.INI
查看DS51.INI看其是否为:
“load…\…\BIN\8051.DLL
map 0, 0xffff”
否则修改。
(6) 在option_make选make文件顺序。
(7) project选Build project,看是否有语法错误,若无则生成HEX文件,若有则修改源文件后重复以上部分步骤。
(8) run_dScope debugger进入dScope51后装入hello则可用go直接运行看serial窗口有无输出,正常每系统运行一次,serial窗口均出现一个“Hello,world”表明运行无误。
2. 第二节 Ishell for Dos使用步骤
(1) 进入Ishell 用Setup editer选择编辑器。
然后单击Edit或用Edit命令编辑hello.c源文件,存盘,也可以在files窗口中直接选中hello.c。
(2) 用cd改换project目录至hello目录。
(3) 在setup_target一项目选8051。
(4) 在setup_C51中输出DB OE。
(5) 在setup_project输入project名hello。
(6) 在setup_save保存Ishell.CFG文件。
(7) 编辑一个Link文件hello.lin中有“hell.obj”一行。
(8) 由光标落在files菜单中的Hello.c上,单击“translate”,如无语法错,再击“link”,则Hex文件生成。
(9) 单击Simulate如在8051.CDF中选Simulate为dScope则进入dScope调试直接“Go”,看serial窗口输出为“Hello.world”。
(10) 如程序有误修改源代码后不必再translate或link了,只要一步Amake即可。
若project中包括不止一个文件,在DOS的Ishell中不能用Translate编译,而应建立bat文件,直接在命令窗编译,然后link连接。
如还需用Translate则只能多个文件分别编译,然后连接。
7. 第七章 Keil C51的代码效率
C51程序编译生成汇编代码的效率,是由许多因素共同决定的,对于Keil C51,主要受以下两种因素影响:
1. 第一节 存储模式的影响
存储模式决定了缺省变量的存储空间,而访问各空间变量的汇编代码的繁简程度决定了代码率的高低。
例如:一个整形变量i,如放于内存18H、19H空间,则++i的操作编译成四条语句:
INC 0x19
MOV A,0x19
JNZ 0x272D
INC 0x18
0x272D:
而如果放于外存空间0000H、0001H则++i的操作编译成九条语句:
MOV DPTR,0001
MOVX A,@ DPTR
INC A
MOVX @ DPTR,A
JNz #5
MOV OPTR,#0000
MOVX A,@DPTR
INC A
MOVX @ DPTR,A
就汇编之后的语句而言,对外部存储器的操作较内部存储器操作代码率要低得多,生成的语句为内存的两倍以上,而程序中有大量的这种操作,可见存储模式对代码率的响了。
因此程序设计的原则是
1、存储模式从small-Compact-large依次选择,实在是变量太多,才选large模式。
2、即使选择了large模式,对一些常用的局部的或者可放于内存中的变量,最好放于内存中,以尽量提高程序的代码率。
2. 第二节 程序结构的影响
程序的结构单元包括模块、函数等等。同样的功能,如果结构越复杂,其所涉及的操作、变量、功能模块函数等就越多,较之结构性好,代码简单的程序其代码率自然就低得多。
此外程序的运行控制语句,也是影响代码率的关键因素,例如:switch -case语句,许多编译器都把它们译得非常复杂,Keil C51也不例外,相对较为简易的Switch-case语句,编译成跳转指令形式,代码率较高,但对较为复杂的Switch-Case,则要调用一个系统库函数?C?ICASE进行处理,非常复杂。
再如if( ),while( ),等语句也是代码相对较低的语句,但编译以后比switch-case要高得多。
因此建议设计者尽量少用switch-case之类语句来控制程序结构,以提高代码率。
除以上两点外,其它因素也会对代码率产生影响,例如:
是否用寄存器传递参数 即NOAREGS选项是否有
是否包括调试信息:即DEBUG选项
是否包括扩展的调试信息:即BJECTEXTEND
