[讨论] Ek314 视频测试问题
明远智睿Lan   2019-2-18 11:11 楼主
系统:Ubuntu 12.04.
按照测试手册的说明,启动后在终端里面输入命令,但是无视频输出,提示有错误,命令输出如下:
linaro@myimx6ek314:/unit_tests$ gplay akiyo.mp4
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=akiyo.mp4
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0]state change failed from 2 to 4
try to play failed
Debug: gstbasesrc.c(2625): gst_base_src_loop (): /GstPlayBin2:playbin0/GstURIDecodeBin:uridecodebin0/GstFileSrc:source:
streaming task paused, reason not-negotiated (-4)
Error: Internal data flow error.
FSL_PLAYER_01.00_LINUX build on Jul 30 2013 23:38:32
        [h]display the operation Help
        [p]Play
        Stop
        [e]Seek
        [a]Pause when playing, play when paused
        [v]Volume
        [m]Switch to mute or not
        [>]Play next file
        [<]Play previous file
        [r]Switch to repeated mode or not
        [f]Set full screen or not
        [z]resize the width and height
        [t]Rotate
        [c]Setting play rate
        Display the metadata
        [x]eXit
fsl_player_stop()
FSL_PLAYER_UI_MSG_INTERNAL_ERROR: internal error message received.
fsl_player_stop()
player_exit(): No more multimedia files, exit.
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0]g_main_loop_thread_fun() quit!
fsl_player_deinit
安装了VLC后,VLC也不能播放视频,直接退出。上传一个MP4文件到开发板上,使用gplay和VLC播放都不行,现象一样。
装了一个 mplayer 后,能够播放视频,但是视频极其卡顿,非常不流畅,我的板子是EK314 6Q-2G
回复1:ubuntu 没有对板子进行适配,会有不可预知的问题。不建议板子上跑 ubuntu
如果有更好的建议,期待您的回复
回复评论
暂无评论,赶紧抢沙发吧
    写回复
