#include "ENC28J60.h"
#include "spi.h"
#include "lcd.h"
static uint8_t Enc28j60Bank;
static uint16_t gNextPacketPtr;
static uint8_t erxfcon;
unsigned char ENC28J60_SendByte(unsigned char dt)
while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
SPI_I2S_SendData(SPI1, dt);
while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
return SPI_I2S_ReceiveData(SPI1);
uint8_t enc28j60ReadOp(uint8_t op, uint8_t address)
uint8_t temp;
enableChip;
// issue read command
ENC28J60_SendByte(op | (address & ADDR_MASK));
temp = ENC28J60_SendByte(0xFF);
if (address & 0x80)
// release CS
disableChip;
return temp;
void enc28j60WriteOp(uint8_t op, uint8_t address, uint8_t data)
enableChip;
ENC28J60_SendByte(data);
disableChip;
void enc28j60PowerDown() {
enc28j60WriteOp(ENC28J60_BIT_FIELD_CLR, ECON1, ECON1_RXEN);
while(enc28j60Read(ESTAT) & ESTAT_RXBUSY);
while(enc28j60Read(ECON1) & ECON1_TXRTS);
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON2, ECON2_PWRSV);
void enc28j60PowerUp() {
enc28j60WriteOp(ENC28J60_BIT_FIELD_CLR, ECON2, ECON2_PWRSV);
while(!enc28j60Read(ESTAT) & ESTAT_CLKRDY);
void enc28j60ReadBuffer(uint16_t len, uint8_t* data)
enableChip;
ENC28J60_SendByte(ENC28J60_READ_BUF_MEM);
while (len--) {
*data++ = ENC28J60_SendByte(0x00);
disableChip;
// Remove next line suggested by user epam - not needed
// *data='\0';
static uint16_t enc28j60ReadBufferWord() {
uint16_t result;
enc28j60ReadBuffer(2, (uint8_t*) &result);
return result;
void enc28j60WriteBuffer(uint16_t len, uint8_t* data)
enableChip;
ENC28J60_SendByte(ENC28J60_WRITE_BUF_MEM);
while (len--)
ENC28J60_SendByte(*data++);
disableChip;
void enc28j60SetBank(uint8_t address)
if ((address & BANK_MASK) != Enc28j60Bank) {
enc28j60WriteOp(ENC28J60_BIT_FIELD_CLR, ECON1, ECON1_BSEL1|ECON1_BSEL0);
Enc28j60Bank = address & BANK_MASK;
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON1, Enc28j60Bank>>5);
uint8_t enc28j60Read(uint8_t address)
// set the bank
enc28j60SetBank(address);
// do the read
return enc28j60ReadOp(ENC28J60_READ_CTRL_REG, address);
void enc28j60WriteWord(uint8_t address, uint16_t data) {
enc28j60Write(address, data & 0xff);
enc28j60Write(address + 1, data >> 8);
// read upper 8 bits
uint16_t enc28j60PhyReadH(uint8_t address)
// Set the right address and start the register read operation
enc28j60Write(MIREGADR, address);
enc28j60Write(MICMD, MICMD_MIIRD);
delay_us(15);
// wait until the PHY read completes
while(enc28j60Read(MISTAT) & MISTAT_BUSY);
// reset reading bit
enc28j60Write(MICMD, 0x00);
return (enc28j60Read(MIRDH));
void enc28j60Write(uint8_t address, uint8_t data)
// set the bank
// do the write
enc28j60WriteOp(ENC28J60_WRITE_CTRL_REG, address, data);
void enc28j60PhyWrite(uint8_t address, uint16_t data)
// set the PHY register address
// write the PHY data
enc28j60Write(MIWRL, data);
enc28j60Write(MIWRH, data>>8);
// wait until the PHY write completes
while(enc28j60Read(MISTAT) & MISTAT_BUSY){
delay_us(15);
static void enc28j60PhyWriteWord(byte address, word data) {
//enc28j60WriteByte(MIREGADR, address);
enc28j60WriteWord(MIWRL, data);
while (enc28j60ReadByte(MISTAT) & MISTAT_BUSY)
void enc28j60clkout(uint8_t clk)
//setup clkout: 2 is 12.5MHz:
enc28j60Write(ECOCON, clk & 0x7);
void enc28j60Init( uint8_t* macaddr )
enableChip; // ss=0
// perform system reset
enc28j60WriteOp(ENC28J60_SOFT_RESET, 0, ENC28J60_SOFT_RESET);
delay_ms(50);
// check CLKRDY bit to see if reset is complete
// The CLKRDY does not work. See Rev. B4 Silicon Errata point. Just wait.
//while(!(enc28j60Read(ESTAT) & ESTAT_CLKRDY));
// do bank 0 stuff
// initialize receive buffer
// 16-bit transfers, must write low byte first
// set receive buffer start address
gNextPacketPtr = RXSTART_INIT;
// Rx start
enc28j60WriteWord(ERXSTL, RXSTART_INIT);
// set receive pointer address
enc28j60WriteWord(ERXRDPTL, RXSTART_INIT);
// RX end
enc28j60WriteWord(ERXNDL, RXSTOP_INIT);
// TX start
enc28j60WriteWord(ETXSTL, TXSTART_INIT);
// TX end
enc28j60WriteWord(ETXNDL, TXSTOP_INIT);
// do bank 1 stuff, packet filter:
// For broadcast packets we allow only ARP packtets
// All other packets should be unicast only for our mac (MAADR)
// The pattern to match on is therefore
// Type ETH.DST
// ARP BROADCAST
// 06 08 -- ff ff ff ff ff ff -> ip checksum for theses bytes=f7f9
// in binary these poitions are:11 0000 0011 1111
// This is hex 303F->EPMM0=0x3f,EPMM1=0x30
//enc28j60Write(ERXFCON, ERXFCON_UCEN|ERXFCON_CRCEN|ERXFCON_PMEN);
//Change to add ERXFCON_BCEN recommended by epam
//enc28j60Write(ERXFCON, ERXFCON_UCEN|ERXFCON_CRCEN|ERXFCON_PMEN|ERXFCON_BCEN);
erxfcon = ERXFCON_UCEN|ERXFCON_CRCEN|ERXFCON_PMEN|ERXFCON_BCEN;
enc28j60Write(ERXFCON, erxfcon );
enc28j60WriteWord(EPMM0, 0x303f);
enc28j60WriteWord(EPMCSL, 0xf7f9);
// do bank 2 stuff
// enable MAC receive
enc28j60Write(MACON1, MACON1_MARXEN|MACON1_TXPAUS|MACON1_RXPAUS);
// bring MAC out of reset
enc28j60Write(MACON2, 0x00);
// enable automatic padding to 60bytes and CRC operations
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, MACON3, MACON3_PADCFG0|MACON3_TXCRCEN|MACON3_FRMLNEN); //|MACON3_FULDPX);
// set inter-frame gap (non-back-to-back)
enc28j60WriteWord(MAIPGL, 0x0C12);
// set inter-frame gap (back-to-back)
enc28j60Write(MABBIPG, 0x12);
// Set the maximum packet size which the controller will accept
// Do not send packets longer than MAX_FRAMELEN:
enc28j60WriteWord(MAMXFLL, MAX_FRAMELEN);
// do bank 3 stuff
// write MAC address
// NOTE: MAC address in ENC28J60 is byte-backward
enc28j60Write(MAADR5, macaddr[0]);
enc28j60Write(MAADR4, macaddr[1]);
enc28j60Write(MAADR3, macaddr[2]);
enc28j60Write(MAADR2, macaddr[3]);
enc28j60Write(MAADR1, macaddr[4]);
enc28j60Write(MAADR0, macaddr[5]);
// no loopback of transmitted frames
enc28j60PhyWrite(PHCON2, PHCON2_HDLDIS);
// switch to bank 0
enc28j60SetBank(ECON1);
// enable interrutps
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, EIE, EIE_INTIE|EIE_PKTIE);
// enable packet reception
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON1, ECON1_RXEN);
LCD_String(20,80,"Mac Init",GREEN);
// read the revision of the chip:
uint8_t enc28j60getrev(void)
uint8_t rev;
rev=enc28j60Read(EREVID);
// microchip forgot to step the number on the silcon when they
// released the revision B7. 6 is now rev B7. We still have
// to see what they do when they release B8. At the moment
// there is no B8 out yet
if (rev>5) rev++;
return(rev);
// A number of utility functions to enable/disable broadcast and multicast bits
void enc28j60EnableBroadcast( void ) {
erxfcon |= ERXFCON_BCEN;
enc28j60Write(ERXFCON, erxfcon);
void enc28j60DisableBroadcast( void ) {
erxfcon &= (0xff ^ ERXFCON_BCEN);
void enc28j60EnableMulticast( void ) {
erxfcon |= ERXFCON_MCEN;
void enc28j60DisableMulticast( void ) {
erxfcon &= (0xff ^ ERXFCON_MCEN);
// link status
uint8_t enc28j60linkup(void)
// bit 10 (= bit 3 in upper reg)
return(enc28j60PhyReadH(PHSTAT2) && 4);
void enc28j60PacketSend(uint16_t len, uint8_t* packet)
// Check no transmit in progress
while (enc28j60ReadOp(ENC28J60_READ_CTRL_REG, ECON1) & ECON1_TXRTS)
// Reset the transmit logic problem. See Rev. B4 Silicon Errata point 12.
if( (enc28j60Read(EIR) & EIR_TXERIF) ) {
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON1, ECON1_TXRST);
enc28j60WriteOp(ENC28J60_BIT_FIELD_CLR, ECON1, ECON1_TXRST);
// Set the write pointer to start of transmit buffer area
enc28j60WriteWord(EWRPTL, TXSTART_INIT);
// Set the TXND pointer to correspond to the packet size given
enc28j60WriteWord(ETXNDL, (TXSTART_INIT+len));
// write per-packet control byte (0x00 means use macon3 settings)
enc28j60WriteOp(ENC28J60_WRITE_BUF_MEM, 0, 0x00);
// copy the packet into the transmit buffer
enc28j60WriteBuffer(len, packet);
// send the contents of the transmit buffer onto the network
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON1, ECON1_TXRTS);
// just probe if there might be a packet
//uint8_t enc28j60hasRxPkt(void)
// return enc28j60ReadByte(EPKTCNT) > 0;
// Gets a packet from the network receive buffer, if one is available.
// The packet will by headed by an ethernet header.
// maxlen The maximum acceptable length of a retrieved packet.
// packet Pointer where packet data should be stored.
// Returns: Packet length in bytes if a packet was retrieved, zero otherwise.
uint16_t enc28j60PacketReceive(uint16_t maxlen, uint8_t* packet)
uint16_t rxstat;
uint16_t len;
// check if a packet has been received and buffered
//if( !(enc28j60Read(EIR) & EIR_PKTIF) ){
// The above does not work. See Rev. B4 Silicon Errata point 6.
if( enc28j60Read(EPKTCNT) ==0 ){
return(0);
// Set the read pointer to the start of the received packet
enc28j60WriteWord(ERDPTL, gNextPacketPtr);
//enc28j60Write(ERDPTL, (gNextPacketPtr &0xFF));
//enc28j60Write(ERDPTH, (gNextPacketPtr)>>8);
// read the next packet pointer
gNextPacketPtr = enc28j60ReadBufferWord();
//gNextPacketPtr = enc28j60ReadOp(ENC28J60_READ_BUF_MEM, 0);
//gNextPacketPtr |= enc28j60ReadOp(ENC28J60_READ_BUF_MEM, 0)<<8;
// read the packet length (see datasheet page 43)
len = enc28j60ReadBufferWord() - 4;
//len = enc28j60ReadOp(ENC28J60_READ_BUF_MEM, 0);
//len |= enc28j60ReadOp(ENC28J60_READ_BUF_MEM, 0)<<8;
//len-=4; //remove the CRC count
// read the receive status (see datasheet page 43)
rxstat = enc28j60ReadBufferWord();
//rxstat = enc28j60ReadOp(ENC28J60_READ_BUF_MEM, 0);
//rxstat |= ((uint16_t)enc28j60ReadOp(ENC28J60_READ_BUF_MEM, 0))<<8;
// limit retrieve length
if (len>maxlen-1){
len=maxlen-1;
// check CRC and symbol errors (see datasheet page 44, table 7-3):
// The ERXFCON.CRCEN is set by default. Normally we should not
// need to check this.
if ((rxstat & 0x80)==0){
// invalid
len=0;
}else{
// copy the packet from the receive buffer
enc28j60ReadBuffer(len, packet);
// Move the RX read pointer to the start of the next received packet
// This frees the memory we just read out
enc28j60WriteWord(ERXRDPTL, gNextPacketPtr );
//enc28j60Write(ERXRDPTL, (gNextPacketPtr &0xFF));
//enc28j60Write(ERXRDPTH, (gNextPacketPtr)>>8);
// However, compensate for the errata point 13, rev B4: enver write an even address!
if ((gNextPacketPtr - 1 < RXSTART_INIT)
|| (gNextPacketPtr -1 > RXSTOP_INIT)) {
enc28j60WriteWord(ERXRDPTL, RXSTOP_INIT);
//enc28j60Write(ERXRDPTL, (RXSTOP_INIT)&0xFF);
//enc28j60Write(ERXRDPTH, (RXSTOP_INIT)>>8);
} else {
enc28j60WriteWord(ERXRDPTL, (gNextPacketPtr-1));
//enc28j60Write(ERXRDPTL, (gNextPacketPtr-1)&0xFF);
//enc28j60Write(ERXRDPTH, (gNextPacketPtr-1)>>8);
// decrement the packet counter indicate we are done with this packet
enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON2, ECON2_PKTDEC);
return(len);
