目前demo是基于PC平台模拟,由于自己开发板内存太小,只进行了基础移植。
Screen1,是借鉴简书那位大神搭建的类似于旋转拨号的功能,增加了按键入口,根据不同的图标进入响应的界面
Clock和screen2页都是直接移植的官方例程,目的是实现Screen1的切页功能
EasingEquation页是自己从官方demo移植出来的graph功能,并进行修改,增加了接口
对graph功能进行了改写,实现了实时刷新的效果,应用于医疗心电的试用,增加了数据和图标的及时显示
这个graph是一个container,可以移植到任意界面上,由于采用的MVP架构,所以需要增加响应的接口函数,开始不适应,适应后发现真的很方便,container在调用前还需要分配内存,开始没注意,后来解决了。
代码上传至百度云,需要的自己下载,这里只贴出部分:
链接:
https://pan.baidu.com/s/1sVr8gSDbjf_WuR4ij5JCnA
提取码:elsj
视频链接:
void EasingEquationView::setupScreen()
EasingEquationViewBase::setupScreen();
statisticsContainer.setXY(200, 100);
statisticsContainer.setVisible(true);
add(statisticsContainer);
statisticsContainer.setup();
statisticsContainer.invalidate();
void EasingEquationView::icon021_Blink(uint8_t alpha)
//icon021.setAlpha(255*alpha/127);
if (alpha == 255)
alpha_value = 255;
alpha_value= alpha_value-2;
icon021.setAlpha(alpha_value);
icon021.invalidate();
void EasingEquationView::tearDownScreen()
EasingEquationViewBase::tearDownScreen();
void EasingEquationView::handleTickEvent()
tick++;
icon021_Blink(statisticsContainer.get_demo_value());
if(tick%60==0)
spo2_value = 99;
if (tick % 121 == 0)
spo2_value = 98;
Unicode::snprintf(textspo2Buffer, TEXTSPO2_SIZE, "%02d", spo2_value);
textspo2.invalidate();
int demo[] = {
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x81,0x81,0x81,
0x81,0x81,0x82,0x83,0x84,0x86,0x86,0x87,
0x87,0x88,0x88,0x89,0x89,0x89,0x89,0x89,
0x88,0x88,0x87,0x87,0x87,0x87,0x87,0x88,
0x88,0x88,0x87,0x86,0x85,0x84,0x84,0x83,
0x82,0x81,0x80,0x80,0x80,0x80,0x80,0x7f,
0x7f,0x7f,0x7f,0x7f,0x7f,0x7f,0x7f,0x7f,
0x7f,0x7f,0x7f,0x7f,0x7f,0x7f,0x7e,0x7e,
0x7e,0x7e,0x7f,0x7f,0x7f,0x7f,0x7f,0x7f,
0x7f,0x7f,0x7f,0x80,0x7f,0x80,0x80,0x80,
0x81,0x82,0x83,0x85,0x87,0x89,0x8b,0x8e,
0x90,0x91,0x92,0x92,0x90,0x8d,0x88,0x83,
0x7d,0x76,0x6e,0x67,0x61,0x5a,0x55,0x51,
0x4f,0x4f,0x52,0x56,0x5c,0x63,0x6b,0x72,
0x78,0x7e,0x81,0x83,0x84,0x83,0x83,0x82,
0x81,0x80,0x80,0x80,0x80,0x80,0x81,0x81,
0x81,0x81,0x81,0x80,0x81,0x80,0x81,0x81,
0x81,0x81,0x81,0x81,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x81,0x81,0x81,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x81,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80 };
int StatisticsContainer::yScale = 5;
StatisticsContainer::StatisticsContainer()
: numValues(0), statState(STAT_STATE_NONE)
setTouchable(true);
setWidth(HAL::DISPLAY_WIDTH);
setHeight(HAL::DISPLAY_HEIGHT - 80);
bgPainter.setColor(Color::getColorFrom24BitRGB(7, 35, 45));
painter[3].setBitmap(Bitmap(BITMAP_STATISTICS_GRADIENT_RED_LINE_ID));
graph[3].setPosition(5, 23, 690, 194);
graph[3].setup(painter[3], bgPainter);
graph[3].setRange(-10 * yScale, 110 * yScale);
add(graph[3]);
Application::getInstance()->registerTimerWidget(this);
StatisticsContainer::~StatisticsContainer()
void StatisticsContainer::setup()
statState = STAT_STATE_INIT;
numValues = 0;
graph[3].clear();
void StatisticsContainer::handleTickEvent()
#ifdef SIMULATOR
(void)Utils::randomNumberBetween(0, 1);
#endif
int temp;
//if ((tick_cnt++)%2 ==0)
temp = demo[tick_value * 5];
graph[3].addValue(tick_step, (int)(300-temp/3 * yScale + 0.5f));
set_demo_value((int)(255*temp/0x92));
Rect updatedRect1(tick_step + 2, 0, 8, graph[3].getHeight());//绘制区域
invalidateRect(updatedRect1);
//iconclass.icon021_Blink((uint8_t)(demo[tick_value * 5]/0x92*255));
if (tick_step++ > graph[4].get_NUMBER_OF_POINTS())
tick_step = 0;
if (tick_value++ > sizeof(demo)/sizeof(int)/5)
tick_value = 0;
void StatisticsContainer::handleClickEvent(const ClickEvent& evt)
if (statState == STAT_STATE_READY && evt.getY() <= upper.getRect().bottom())
// update(evt.getX());
void StatisticsContainer::handleDragEvent(const DragEvent& evt)
if (statState == STAT_STATE_READY && evt.getNewY() <= upper.getRect().bottom())
// update(evt.getNewX());
void StatisticsContainer::update(int x)
x &= ~1;
x = MAX(x, graph[0].getX());
x = MIN(x, graph[0].getRect().right());
verticalBar.invalidate();
verticalBar.setX(x - 1);
x -= graph[0].getX();
for (int i = 0; i < 3; i++)
graph
.setSelectedX(x);
int y = graph.getValue(x) / yScale;
if (y >= 0 && y <= 100)
circle.updateArcEnd(348 * y / 100 + 6);
Unicode::snprintf(buffer, 4, "%d", y);
pctValue.invalidate();
int StatisticsContainer:: get_demo_value()
return demo_value;
void StatisticsContainer::set_demo_value( int value)
demo_value =( 255-value);
