[分享] 分享一些飞行时间测距、成像方面的资料
littleshrimp   2019-7-28 09:52 楼主
    THE SPATIAL CROSS-CORRELATION COEFFICIENT AS AN ULTRASONIC DETECTION STATISTIC.pdf
    ABSOLUTE TRANSIT TIME DETECTION FOR ULTRASONIC GAS FLOWMETERS BASED ON TIME AND PHASE DOMAIN CHARACTERISTICS.pdf
    A NEW METHOD FOR HIGH RESOLUTION ULTRASONIC RANGING IN AIR.pdf
    A QUALITY-GUIDED DISPLACEMENT TRACKING ALGORITHM FOR ULTRASONIC ELASTICITY IMAGING.pdf
    Accuracy and resolution of ultrasonic distance measurement with high-time-resolution cross-correlation function obtained by single-bit signal processing.pdf
    Advanced Methods for Time-Of-Flight Estimation with Application to Lamb Wave Structural Health Monitoring.pdf
    Advanced Methods for Time-Of-Flight Estimation with Application to.pdf
    Application of Autocorrelation and Crosscorrelation Analyses in Human Movement and Rehabilitation Research.pdf
    Characterization of tissue microstructure using ultrasonic backscatter  Theory and technique for optimization using a Gaussian form factor.pdf
    Deep End-to-End Time-of-Flight Imaging.pdf
    Identification and distance detection for ultrasonic sensor by correlation method.pdf
    Imaging in scattering media using correlation image sensors and sparse convolutional coding.pdf
    Nonlinear ultrasonic measurements based on cross-correlation filtering techniques.pdf
    Phasor Imaging A Generalization of Correlation-Based.pdf
    SIGNAL PROCESSING FOR ADVANCED CORRELATION ULTRASONIC VELOCITY PROFILER.pdf
    Three-Dimensional Sensors Lecture 3  Time of Flight Cameras (Continuous Wave Modulation).pdf
    Ultrasonic attenuation measurements at very high SNR  Correlation, information theory and performance.pdf
    Ultrasonic Tissue Reflectivity Function Estimation Using Correlation Constrained Multichannel FLMS Algorithm with Missing RF Data.pdf
    Wavelet based harmonics decomposition of ultrasonic signal in assessment of plastic strain in aluminum.pdf
作为超声波检测统计的空间交叉相关系数.pdf
    基于时域和相域特征的超声气体流量绝对过渡时间检测.pdf
    一种新的高分辨率超声波测距方法.pdf
    一种用于超声弹性成像的质量引导位移跟踪算法.pdf
    通过单比特信号处理获得具有高时间分辨率互相关函数的超声波测距精度和分辨率.pdf
    应用于兰姆波结构健康监测的飞行时间估计的先进方法.pdf
    应用于.pdf的飞行时间估计的先进方法
    自相关和交叉相关分析在人体运动与康复研究中的应用.pdf
    使用超声反向散射表征组织微结构使用高斯形状因子进行优化的理论和技术.pdf
    深度端到端飞行时间成像.pdf
    超声波传感器的识别和距离检测的相关方法.pdf
    使用相关图像传感器和稀疏卷积编码在散射介质中成像.pdf
    基于互相关滤波技术的非线性超声测量.pdf
    相量成像基于相关的推广.pdf
    用于高级相关超声波速度轮廓的信号处理.pdf
    三维传感器第3讲飞行时间相机(连续波调制).pdf
    在非常高的SNR相关性,信息理论和性能的超声衰减测量.pdf
    超声组织反射率函数估计使用相关约束多通道FLMS算法与丢失RF数据.pdf
    基于小波的超声信号谐波分解评估铝中塑性应变.pdf
1.THE SPATIAL CROSS-CORRELATION COEFFICIENT AS AN ULTRASONIC DETECTION STATISTIC.pdf (884.54 KB)
(下载次数: 8, 2019-7-28 09:46 上传)
3.ABSOLUTE TRANSIT TIME DETECTION FOR ULTRASONIC GAS FLOWMETERS BASED ON TIME AN.pdf (267.43 KB)
(下载次数: 9, 2019-7-28 09:46 上传)
A NEW METHOD FOR HIGH RESOLUTION ULTRASONIC RANGING IN AIR.pdf (239.33 KB)
(下载次数: 4, 2019-7-28 09:46 上传)
Application of Autocorrelation and Crosscorrelation Analyses in Human Movement a.pdf (409.88 KB)
Deep End-to-End Time-of-Flight Imaging.pdf (4.02 MB)
(下载次数: 7, 2019-7-28 09:46 上传)
Imaging in scattering media using correlation image sensors and sparse convoluti.pdf (23.71 MB)
(下载次数: 28, 2019-7-28 09:46 上传)
Phasor Imaging A Generalization of Correlation-Based.pdf (17.57 MB)
(下载次数: 23, 2019-7-28 09:46 上传)
SIGNAL PROCESSING FOR ADVANCED CORRELATION ULTRASONIC VELOCITY PROFILER.pdf (350.6 KB)
(下载次数: 3, 2019-7-28 09:46 上传)
Three-Dimensional Sensors Lecture 3 Time of Flight Cameras (Continuous Wave Mod.pdf (260.55 KB)
Ultrasonic attenuation measurements at very high SNR Correlation, information t.pdf (906.46 KB)
(下载次数: 6, 2019-7-28 09:46 上传)
虾扯蛋,蛋扯虾,虾扯蛋扯虾
回复评论
暂无评论,赶紧抢沙发吧
    写回复
