[资料分享] linux下用文件控制gpio的输出电平
Aguilera   2019-11-12 21:20 楼主
在写使用spi过程中,需要用到GPIO3.21这个引脚的高电平输出信号。
在超级终端里面的输入方法:
# cd /sys/class/gpio
/sys/class/gpio# echo 117 >export
 /sys/class/gpio# echo out >gpio117/direction
这个固然可以实现引脚电平的输出,在使用中,还可以用文件操作方式使得电平升高。如下:
#include stdlib.h
#include stdio.h
#include string.h
#include unistd.h
#include fcntl.h
//芯片复位引脚:GPIO3.21
#define SYSFS_GPIO_EXPORT           "/sys/class/gpio/export"
#define SYSFS_GPIO_RST_PIN_VAL      "117"
#define SYSFS_GPIO_RST_DIR          "/sys/class/gpio/gpio117/direction"
#define SYSFS_GPIO_RST_DIR_VAL      "OUT"
#define SYSFS_GPIO_RST_VAL          "/sys/class/gpio/gpio117/value"
#define SYSFS_GPIO_RST_VAL_H        "1"
#define SYSFS_GPIO_RST_VAL_L        "0"
int main()
    int fd;
         //打开端口/sys/class/gpio# echo 117 > export
         fd = open(SYSFS_GPIO_EXPORT, O_WRONLY);
         if(fd == -1)
                   printf("ERR: Radio hard reset pin open error.\n");
                   return EXIT_FAILURE;
         write(fd, SYSFS_GPIO_RST_PIN_VAL ,sizeof(SYSFS_GPIO_RST_PIN_VAL));
         close(fd);
         //设置端口方向/sys/class/gpio/gpio117# echo out > direction
         fd = open(SYSFS_GPIO_RST_DIR, O_WRONLY);
         if(fd == -1)
                   printf("ERR: Radio hard reset pin direction open error.\n");
         write(fd, SYSFS_GPIO_RST_DIR_VAL, sizeof(SYSFS_GPIO_RST_DIR_VAL));
         close(fd);
         fd = open(SYSFS_GPIO_RST_VAL, O_RDWR);
         if(fd == -1)
                   printf("ERR: Radio hard reset pin value open error.\n");
         //输出高电平
         write(fd, SYSFS_GPIO_RST_VAL_H, sizeof(SYSFS_GPIO_RST_VAL_H));
         while(1)
         close(fd);
         printf("INFO: Radio hard reset pin value open error.\n");
         return 0;
回复评论
暂无评论,赶紧抢沙发吧
    写回复
