本文作者:ST工程师Joshua Zhu
点击下载pdf文档查看:
关键词:S2-lp, TCXO
问题: 一些客户不得不在他们的方案设计中使用TCXO,原因如下:
1).Customer Required Configuration DR = 2.4Kpbs Fdev = 1.2KhZ Frequency Point: 492.08M GFSK Modulation
2).Passive crystal oscillators are difficult to control frequency offset accuracy according to customers' low-speed requirements. The frequency offset accuracy of some better passive crystal oscillators are 10 ppm at room temperature .
3).
a.EXS00A-CS08403 with S2-LP reference design as an example Normal temperature deviation: +10 ppm Variation of whole temperature range: +15 ppm Looking at the frequency of customer use : Frequency offset at room temperature: +4.92 Khz Full Temperature Range Frequency Offset: +7.38 Khz
b. Active crystal oscillator DSB221SDB provided by customers Normal temperature deviation: +1.5 ppm Change of whole temperature range: +1 ppm Looking at the frequency of customer use Frequency offset at room temperature: +0.738 Khz Full Temperature Range Frequency Offset: +0.492 Khz
ST工程师解答:
1. 关于crystal的选择,从datasheet 14页我们可以获得如下信息:
关于 TCXO, 以下更多的信息需要考虑(参考 the mantis:3213):
1) DC coupling with a minimum 0.2 VDC level
2) Minimum AC amplitude of 400 mVpp
3) The instantaneous level at input cannot exceed the 0 – 1.4 V range.
2. 这是在我们STEVAL-FKI512V1平台板子上测试验证ok的TCXO型号:
NDK, NT1612AB 50MHz END5348A;
