[求助] MKL26 加速器debug 出错,哪位大神帮看一下
samhuang8204   2019-12-3 21:30 楼主
MKL26 加速器debug 出错,哪位大神帮看一下。
log 如下:
C:\Users\sam\workspace\UART_AT\FLASH/../Project_Settings/Startup_Code/__arm_start.c:279: undefined reference to `main'
mingw32-make: *** [UART_AT.elf] Error 1
源码是红色字体那里:
#include <string.h>
#include <stdlib.h>
#include <runtime_configuration.h>
_EWL_BEGIN_EXTERN_C
#if SUPPORT_SEMIHOST_ARGC_ARGV
#define __MAX_CMDLINE_ARGS 10
static char *argv[__MAX_CMDLINE_ARGS] = { 0 };
#else
static char *argv[] = { 0 };
#endif
#if __GNUC__
#define __call_static_initializers __init_cpp
#endif
extern int __argc_argv(int, char **);
#endif /* SUPPORT_SEMIHOST_ARGC_ARGV */
extern void __call_static_initializers(void);
extern int main(int, char **);
#ifdef __VFPV4__
extern void __fp_init(void);
#endif /* __VFPV4__ */
extern void __init_registers();
extern void __init_hardware();
extern void __init_user();
#if defined(__APCS_ROPI)
extern void __init_pic();
#endif
#if defined(__APCS_RWPI)
extern void __init_pid();
#endif
#if defined(__APCS_ROPI) || defined(__APCS_RWPI)
extern void __load_static_base();
#endif
#if defined(__SEMIHOSTING)
extern void __init_semihost(void) _EWL_WEAK;
#endif
#if SUPPORT_ROM_TO_RAM
extern void __copy_rom_sections_to_ram(void);
extern char __S_romp[];
#endif
static void zero_fill_bss(void)
    extern char __START_BSS[];
    extern char __END_BSS[];
    memset(__START_BSS, 0, (__END_BSS - __START_BSS));
#ifndef __thumb // Thumb version
#error Thumb startup
#endif
// To keep iar debugger happy
void __iar_program_start(void) _EWL_NAKED;
void __thumb_startup(void);
void __iar_program_start()
    __thumb_startup();
void __thumb_startup(void) _EWL_NAKED;
        // Setup registers
        __init_registers();
        // setup hardware
        __init_hardware();
        //    static base register initialization
#endif
        //    -pid
        //    setup static base for SB relative position independent data
        //    perform runtime relocation
        __init_pid();
#endif
        //    -pic
        //    perform runtime relocation for position independent code
        __init_pic();
#endif
        //    zero-fill the .bss section
        zero_fill_bss();
        if (__S_romp != 0L)
            __copy_rom_sections_to_ram();
#endif
        //      initialize the floating-point library
#ifdef __VFPV4__
        __fp_init();
#endif
        //    call C++ static initializers
        __call_static_initializers();
        // initializations before main, user specific
        __init_user();
        // semihost initializations
        __init_semihost();
#endif
        //    call main(argc, &argv)
        exit(main(__argc_argv(__MAX_CMDLINE_ARGS, argv), argv));
#else
        exit(main(0, argv));
#endif
    UART_AT.zip (2019-12-3 21:27 上传)
    167.75 KB, 下载次数: 0
    源码
真正的幸福不是靠加法,而是靠减法,生活从来都是越简单,越幸福。
回复评论 (2)
没main入口啊
点赞  2019-12-3 21:57
引用: freebsder 发表于 2019-12-3 21:57 没main入口啊
tks
点赞  2019-12-4 22:34
    写回复
